Question about Kingston DataTraveler Mini Fun G2 4GB USB 2.0 Flash Drive
I have a 16GB Kingston DataTraveler that display a 0 bytes capacity, how to repair it? I have a MacBook Pro. Nathan
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: I have a 4GB Kingston DataTraveler that display a 0 bytes capacity, how to repair it?
Click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
this may vary depending on your operating system
if you need more help with this post a reply
hope it helps
Posted on Nov 05, 2012
Kingston Datatraveler G3 8GB VID=04F2 PID=B026 Can't Format, 0 byte yongkowidjaya@ymail.com
click start click on my computer you should see your usb drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
Oct 24, 2013 | Kingston Computers & Internet
Please insert disk into removable disk
have you tried other a different flash drive of something like a usb charger etc? If it works then then the problem is with the flash drive, if not them its with your USB port
Apr 28, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
restore defaults
In XP
hope it helps
Nov 05, 2012 | Kingston DataTraveler Mini Fun G2 4GB USB...
Kingston 16gb, when i try to open it is showing access denied
Try to format your datatraveler it may help you to fix the problem
Oct 08, 2010 | Kingston Technologies 512MB DataTraveler I...
16GB USB Memory Stick not readable by Macbook
It's possible it was just subjected to a static shock and got scrambled. As long as the data previously on it was not important to you, you can re-initialize the unit (provided it has not been physically damaged).
In Applications/Utilities, launch Disk Utility. Plug in the USB stick. Choose the stick by name in the left side panel, and click the Partition tab. Choose 1 partition. In Options, choose GUID Partition Table. Click Apply. This should reinitialize your stick.
Mar 31, 2010 | Apple MacBook Pro Notebook
I can not format my usb and the total capasity
Format the Data Traveler:
Warning! All data will be lost.
1. Insert the DataTraveler into a USB port.
2. Right click the Start button via the Windows Start menu and slect Explore.
3. Locate and right click the Kingston removable drive.
4. Select Format from the pop-up menu.
Note: Always use standard FAT for drives 2GB and smaller. Always use FAT32 for drives 4GB and larger.
5. Click the Start button. A format Removable Disk Warning will come up. Choose OK if you want to format your drive. After the drive has been formated you will receive a Format Complete box. Click the OK button.
Hope that helps.
Jan 12, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
Jul 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Kingston DataTraveler Mini Fun G2 4GB USB 2.0 Flash Drive Logo
19 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Computer Links
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
