Question about Cameras
I have just purchased a philips styleshaver pro QS6140 and am charging it as instructed before my first use. However, the battery light continues to flash and I do not know if that means it is fully
Don't think there is anything more to add. just let me know if the light stops flashing when the battery is fully charged!
SOURCE: charging battery
i have m853and i dont know how to tell if my battery is charging or not. i charge my m853 using usb computer, theres no light flashing..what is this mean..
Posted on Mar 15, 2008
SOURCE: Sony Cyber-Shot DSC-F707 ...No flash.
Mine started to do that too. I charged the battery and then played with it taking the battery out and placing it back in and it just started to work again. Try placing it in manual mode as in shutter or appeture, rather that automatic and see if it makes a difference. These are things i played with before it started to work again.
Posted on Apr 16, 2008
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
IrishDruid
  • 2712 Answers
SOURCE: I have a samsung L200
You may have to replace the rechargeable lithium ion battery. (Even rechargeable batteries have a life-span :)
Posted on Dec 03, 2008
  • 998 Answers
SOURCE: Inspiron 1200 battery light continually flashing orange
If your battery LED flashes or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Thank You.
Posted on Jan 19, 2009
The battery icon which shows battery is full, keeps flashing continuously on Philips CD565 Duo
I would return it to the manufacture, you have described two different problems, this is clearly a manufacture defect.
Mar 29, 2012 | Computers & Internet
My mac book pro keeps shutting down
Do you have all the latest software updates on your system?
Does this happen when it's plugged into the power supply?
If not, then it could be the battery. If it's an old computer, the battery might not be holding the charge very long.
Have you tried resetting the PRAM? Start with the notebook powered off, turn it on and press and hold Command-Option-P-R. Continue holding until you've heard 3 system tones. Then allow the system to boot.
See if that helps. If not, you may have a problem with your power supply, charging system or the battery. This would necessitate a call to AppleCare.
I recommend speaking to someone at an Apple store, or wherever you purchased it.
Mar 07, 2011 | Apple MacBook Pro with 17" Display
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Purchased Norelco shaver 7810XL. Instructions state to charge for 4 hours prior to first use. Green lights began blinking, indicating full charge, after less than 2 hours. Do I continue charging after...
Simply follow the instructions and charge for a full 4 hours the first time. On subsequent charges, unplug when the light blinks after about 1 hour
Dec 26, 2010 | Norelco Health & Beauty
Phillips 990 shaver new batteries
shaver batteries can be purchased at shaveroutlet.com
Dec 21, 2009 | Philips Philishave HQ7780 Electric Shaver
My phones (philips cd445) will not hold a charge for more than a few hours off the cradle...yes I have replaced the batteries, twice. once with disposables, once with rechargeables
You might have what is called "memory'. If you continue to replace the phone on it's charger after each call the battery will "think" it's empty, giving you s short charge time. Next time you replace the batteries (rechargeable) FULLY charge them then leave the phone off the charger until you go to bed at night.
Sep 18, 2009 | Philips CD4452S/05 Digital Telephone and...
Htc tpuch pro keyboard doesnt work,, it did it just stoped ,, it lights up for about 3 to 4 seconds and then goes out ,, how do i fix this problem for good
Try removing and re-inserting the battery.
It is also possible that the battery is not properly charged or not charging properly.
Try to charge the phone completely and check if it is getting charged properly.
If nothing works... purchase a new battery.
I am sure the problem is with the battery.
Please inform me if the problem is solved or not.
Aug 26, 2009 | HTC Touch Pro Smartphone
When i try to power on my son's DS Lite, the red light is on, and both screens power on for about 2-3 seconds max and then the system shuts off. It also wont charge when connected to the wall.
You may need to get a replacement battery pack when the battery is below 30% the light will turn red, the battery requires 4 hours to charge, and when the battery is fully charged the amber colored light will turn off. If you still need to purchase a new battery contact nintendo cust serv at 800-255-3700 or you can order online at nintendo.com You will need a #00 philips screw driver to remove the battery cover, install the battery with the 2 tabs in first, close compartment and allow battery to fully charge before use. The average battery will last for about 500 charges. Hope this helps
Aug 05, 2009 | Nintendo DS Lite Console
I lost the instructions and it continually says low battery
I had the same problem and discovered from the instructions it will only charge the battery if in the "off" position on the side ie it is not charging if it is plugged in to a power source and being used.
Jan 24, 2009 | Philips PET702 Portable DVD Player
Cameras Logo
73 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
