Question about Health & Beauty
How to grease oster Titan clippers - Health & Beauty
2 Suggested Answers
  • 5 Answers
SOURCE: OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Posted on Jan 07, 2010
Where do i grease a oster shearmaster
Undo the 2 screws from the FRONT that go through the aluminium housing into the yellow housing. They are either side of the blade tension thumb screw. Pull the housing off and that will allow you to squirt the grease into the gear assembly.
Jul 19, 2012 | Oster Corporation Shearmaster, Color:...
Tip
When should you change the grease on your Oster A5 or 76 clipper
Oster A5 or 76 clipper need to be grease at lease every 4 month so they can run quiet and cool. when changing and removing the grease, You need to remove the old grease completely, or You are doing more harm than good. By doing this on a routine base, You are saving wear and tear on your gear,lever,link and blades. and the clipper motor will run cooler.
on Mar 30, 2010 | Kitchen Appliances - Others
I have oster titan clippers. The brass anchors for the blade mounting mechanism are pulling out of the plastic housing. How do I fix this?
ok if the brass inserts are allowing the hinge to move away from the clipper this will obviously cause a few problems, you will need to replace the body housing (new housing comes with a different design) you can view the clipper parts here
Aug 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
I have not used my Oster Golden A5 dog clippers in a few years and the blades look rusty. How can I clean them? Also, where do you put the lubricating grease and where the oil?
ok rush can be removed with wire wool or a wire brush and will be prevented by the application of oil.
Grease should be inserted into the gearbox which is located under the name plate, for clipper oil have a look at the page.
Jul 19, 2011 | Oster Golden A5 2-Speed Universal Motor...
Where do you grease and oil clippers at?
The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device (if they are worn, they should be replaced. They, and the Bakelite gear, are available from various dealers through Amazon under Oster Parts). The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). Check it for worn or missing teeth.
If you don’t have a tube of oster grease, a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The small pads on each side of the lever (in the case) are oiled, not greased.
The bearings for the Oster are sleeve bearings that require oil (the one closest to the blade is served by the oil port; the little round chrome looking thing with the spring loaded ball in it). The other end is more difficult and would require disassembly, at which time it probably should be replaced.
Oster clippers, by the way, are known for getting pretty warm. Oster blade wash will help with that, as well as oiling the blades.
Hope this helps you.
Nov 20, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oiling
there is a silver oiling nipple next to the name plate depress the centre and oil, also clippers must be greased in the gearbox underneath the name plate.
Aug 30, 2009 | Oster Golden A5 2-Speed Universal Motor...
THE SWITCH IS BROKEN OSTER TITAN CLIPPER.
If the clippers are less than a year old send them back too your supplier, if not you can send them to our servicing department or alternatively fit a replacement switch.
Feb 02, 2009 | Oster 76076-040 Hair Trimmer
Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Jan 10, 2009 | Oster 76076-010 Hair Trimmer
Apr 08, 2008 | Oster 76076-040 Hair Trimmer
Health & Beauty Logo
65 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
