Question about Cobra 29 LTD CB Radio
Needle sticks when you key up the mic
Just when you key up
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If your talking about the VU meter, take the top off, access the VU meter and spray it with WD40
Posted on Jan 10, 2009
My galaxy 98vhp radio cb don't keyed?
One of the wires in the mic plug is probably broken off. Probably the wire on pin 3. Pin 3 should be transmit. Could also be the wire(s) on pin 1 depending on what mic you have.
Feb 10, 2014 | Radio Communications
CB is in transmit mode with no mic connected
Got a short either at the mic socket or the keying circuit--try first to disconnect leads at the socket one at a time.
Jun 12, 2012 | Radio Communications
Got a connex 3300HP has a ranger board and chipset won't modulate recieves fine keys up relay clicks needle doesn't move no voice either cant find schematics
You may have a dead meter.
Modulation is audio's affect on swing wattage or pep. Notice that needle moving more with your voice.
Dead key or carrier wattage is without your voice enhancing the power only with mic keyed.
I can only assume that the chipset you are referring to is an ic chip audio or pll which must be working if you are receiving audio.
Check your mic cord................ transmit and modulation and even your receive volume can be affected by the cord/mic plug solder joints or broken wires here.
http://www.cbtricks.com/radios/galaxy/dx33hp2/graphics/dx_33hp2_sch.pdf this is a similar radio the General Lee, Connex 3300hp and Galaxy hp2 share boards i believe dont hold me to that thou.
Aug 20, 2011 | Connex 3300 240-Channels Base CB Radio
When people ring me i can hear them but they can't hear me. Also if I record a sound I can't hear that either.
It may be mic problem in your mobile .
you can test whether mic is working or not with the help of menu that appear by pressing following keys
> means press joystick or arrow keys to right
< means press joystick or arrow keys to left
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
you will get a service test menu in that select microphone option to test it
Jun 02, 2010 | Sony Ericsson W910i Cellular Phone
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
How do i calibrate an Aries swr 420 meter for a cb radio
To calibrate the meter set the switch to FWD/CAL/REF and key the microphone without speaking into it. then turn the control until the needle is on CAL. Unkey the mic, set the switch to SWR and then key the mic to read the SWR.
Thanks,
Dodgem250.com
Apr 16, 2010 | Radio Communications
Dont know how to use the swr meter on my radio
With radio turned on
1. Switch the first switch (S/RF SWR CAL) to CAL setting
2. Key mic up &
3. Turn SWR CAL knob while still keying mic until the needle is on the red CAL arrow at the far end of the meter scale. Unkey mic.
4. Switch the first switch back to SWR setting.
5. Key mic up again and record SWR reading and adjust as needed.
6. When done adjusting put switch back in the S/RF setting for normal operation.
Do not flip the switch with the mic keyed up.
Jan 19, 2010 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
77 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
