How to set the channel of sanyo lcd-32R40
After we done auto & manual scan still we dont have any channel available
rlamkin
  • 44 Answers
SOURCE: cant get channels to program manual or auto
i have one in the shop like this now - the main board tuner is bad - i could get this one to work by using the composite input and an digital convertor box for the tuner.
Posted on May 19, 2009
SOURCE: LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
Posted on Jun 21, 2009
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
emissionwiz
  • 76164 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Posted on Jul 28, 2009
bschilz
  • 2049 Answers
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-062_DX-R32TV_WEB.pdf
Posted on Sep 04, 2009
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Keeps telling me to scan for channels
most sets its done in the setup menu--select if cable or antenna and then select auto program, set will scan and store all available channels it can find.
May 19, 2012 | Toshiba Regza 32LV67U 32 in. LCD HDTV
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
I have a sanyo lcd 32"the problem i have is my dtv chanels go from 6 to 69 theres new chanels coming here i need channel 1 and channel 88 how do i get them help please.
G into the menu function and look for channel search.Usually pretty easy to find .Manual add and auto settings. Use auto if new channels are already operating.Otherwise use manual
Aug 08, 2009 | Sanyo DP32746 32 in. LCD Television
Manual needed for Sanyo CP29ST3 - I need to tune in TV channels! I lost the manual!
Sanyo has two parts distributors in the U.S. Both are listed below. You'll need to contact the one closest to you and inquire about purchasing a replacement manual. In the meantime, if you're just trying to program the channels into your TV, you need to bring up the TV's menu and select the screen that has the channel or setup options. All TV menus follow the same general format: you should see icons or words going across the top of the screen or down the left side indicating the different menus that are available. On some older TVs you have to press the menu button more than once to cycle through the different menus. Each menu has different options such as picture options (brightness, color, tint, etc) audio options, setup options, and channel options. Use the arrow keys on the TV remote to manipulate what you see once the menu is on the screen. Once you find the channel options, you need to perform what's called a channel scan. On the screen it may say auto scan, auto program, or channel scan. Once you start the scan, you're done. The TV will scan for all available channels and the menu will disappear once it's finshed.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 22, 2009 | Televison & Video
Lost certain channels on Eurovox
run auto scan......please make sure you dont run power scan.....once scan is done you should get all the missing channels back.
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
