Question about Acer Aspire Computers & Internet
ACER 7750Z-4623wont boot up
Windows boot manager ask for windows installation disk to restart
  • 198 Answers
SOURCE: Acer Aspire 5610
You are still in warranty, so call Aspire at (800) 816-2237 for live help. If the "helper" doesn't address your problem, or just tells you just tells you to reinstall everything, demand to speak to a supervisor. It's their problem, not yours. They are open until 5:30 PM CST
Posted on Jan 02, 2008
  • 145 Answers
SOURCE: i want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
Posted on May 02, 2009
  • 987 Answers
SOURCE: acer 290 notebook can't boot up
Check the RAM modules ..remove and reinsert ...then check if the problem persists or not ...
Posted on Sep 19, 2009
Ricky_Critic
  • 119 Answers
SOURCE: my acer aspire 5520 keeps shutting down on boot
Insert your restore CD if errors are found and not fixed by the checkdisk function listed above. Turn your computer off and then back on. You'll beasked to hit any button to boot from your CD; press any key. You will then beasked if you want to install a fresh version of your OS or "Repair" acurrent copy. Choose the "Repair" option.
Posted on Dec 24, 2009
SOURCE: blue screen, launch manager, and empowering acer with windows 7 os
how can i setup the lunch manager in windows 7
Posted on Mar 10, 2010
My bootmanager is gone how to fix I did try windows xp acer recovery disk but nothing help. where can I find the boot manager file many thanks
Did you see a blue screen at all? If so, your HD is bad. No disk will fix it. you would need to reload everything on a new Hard drive. Boot managers are not a simple program that is loaded. They are 'built' by windows and are not replaceable in the way you are asking.
The way to fix this is to replace the hard drive and reload the computer with the original disks.
To be blunt, I would replace the computer unless there is a reason you need XP. XP is not safe to use online anymore.
Jan 10, 2018 | Acer Computers & Internet
How to fix my acer extensa 4630z? Its boot manager is missing or corrupted.
First you need:
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, just restart and try to boot to the Windows XP CD again.
  1. Enter Windows XP Recovery Console. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
When you reach the command line (detailed in Step 6 in the link above), type the following command and then press Enter.
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Apr 01, 2015 | Acer Extensa 4630z
Can not boot from Win XP Pro without an auto restart
Hi Jeff,
I see you are having issue installing windows, getting an error the the Boot Manager is missing...
The windows Disc that you have is this a burnt copy? possible that the installation files on the Windows you have is incomplete.
But if I may ask before you tried installing this Windows what windows did you have on your computer?
Have you tried booting the disc directly from the CD drive instead of installing it from within windows.
Go into BIOS and change the boot configuration of you Computer make sure the the CD/DVD drive is selected as the primary boot option before the hard drive, once that is done restart your computer make sure that you Windows disc is in the cd/dvd drive, you should get a prompt on the upper left saying to boot from cd press any key - press Enter right away once you see that prompt this should boot from the disc for the installation to continue but if still it looks for the Boot Manager the copy of your installation disc maybe incomplete.
Also you can try to wipe clean you hard drive and try again again with the installation.
Jul 30, 2012 | Microsoft Windows XP Professional
Acer ferrari gives boot mgr is compressed press cont alt del to restart and it will not boot from windows dvd
you should still be able to boot from the windows disk. just out of curiosity did you save the changes when you changed the boot order?
If you manage to get it to boot from the disk you can try the repair option.
Jul 19, 2012 | Acer Aspire Ferrari 3000LMi Notebook
Need to reset acer aspire 1200 desktop
The Aspire One is a netbook produced by Acer; it does not come equipped with a CD ROM drive, so a traditional hard drive reformat and Windows reinstallation is not possible without a peripheral storage device. An external USB CD or flash drive will suffice, however.Difficulty:Moderate
Instructions
    • 1 Plug in the external CD drive, then turn on your netbook and let it boot to your operating system.
    • 2 Open your web browser and go to the BootDisk website (see link in Resources). Download the Windows XP Fresh Install Bootable CD, then burn these files to a blank CD via your external CD drive.
    • 3 Ensure the files have burned to your bootable CD, then restart the netbook with the CD still in the drive.
    • 4 The netbook should boot to the CD upon the restart. Follow the instructions prompted for installation. Upon completion you will have a clean installation of Windows XP on your Acer Aspire One.
Oct 27, 2011 | Acer Computers & Internet
Hii..I Am Having An Acer Aspire 5050...Well I Installed Windows Vista Ultimate On It But Originally It Was Windows Visa,Therefore,After Installing Windows Vista Ultimate I Tried To Upgrade The...
If you place your Win7 disk in the DVD drive boot the laptop from the disk and choose to install a new system.
Follow the menu and prompts.
When it has installed download the drivers from Acer.com otherwise you will get problems.
Hope that helps.
Jan 08, 2011 | Acer Aspire 5050-3242 Notebook
I formatted my Acer Aspire One and installed Fedora Linux, but I need to re-install Windows 7 Starter. The shop I purchased it from gave me 3 Acer Aspire D255 Windows 7 Starter DVD disks which I...
To reinstall you need an external DVDROM drive and run directly the windows 7 installer as boot up disk. Because it need to run alone as boot up disk and surely it will not run when you just copy the files to external HDD.
Jan 04, 2011 | Acer Aspire One PC Notebook
How do I do a full recovery with the disc
Turn your computer on.
Insert the Disk and choose to enter BIOS, should be F2 but watch the screen to see the right function key.
Change the boot device order to: CD-ROM, HDD in that order.
Save changes and restart the computer.
The Recovery Disk would boot up and a wizard will guide you through the recovery process.
Follow the instructions to recover your computer.
Apr 03, 2010 | Acer Aspire 3050-1733 Notebook
Bootmgr is missing
Insert the original CD-ROM that you used to install Windows XP.
Restart the computer, and tell it to "boot" from the CD-ROM,
instead of the usual disk-drive.
Eventually, you'll get to a screen that asks "install" or "repair".
Choose "repair", to see if Windows will repair the 'BOOT-MANAGER' file.
Jan 04, 2010 | Acer Aspire 5536-5224 Notebook
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
