Question about Landice L7 L8 L9 Drive Motor, 3hp, 110v Parts Baldor Dc
Landice L7 trreadmill motor very loud - Landice L7 L8 L9 Drive Motor, 3hp, 110v Parts Baldor Dc
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Posted on Feb 28, 2010
  • 20 Answers
SOURCE: Motor or belt sqeals -
this may require proper troubleshooting but it is either the belts on the motor needs changing or the track belt ihas come to the end of it's usage life... but check thorougly.
Posted on Apr 09, 2011
I have a landice l7 treadmill that is vibrating even when the drive belt is removed, any ideas?
Check the motor for its stability .
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 15, 2016 | Landice Exercise & Fitness
My landice L7 pro Trainer is not working when you press the start button the motor jolts a little the L5 shows is the display screen
It needs a lower board, does your machine have a life time warranty? Part should be covered just not the labor.
Apr 02, 2015 | Landice Exercise & Fitness
Landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
May 08, 2012 | Landice L7 Executive Trainer Treadmill...
Motor or belt sqeals - adjusting running belt does nothing. Also the tension on the belt from electric motor to running belt roller appears to be correct set with approx. 40 degree twist occurring. What...
Apr 04, 2011 | Landice Exercise & Fitness
The treadmill comes on but but the belt doesnt turn & L7 comes up on the display
At first glance, It looks like a lower control board issue and/or motor issue (more likely lower control board).
Before calling Landice I would check all the connections to the Lower control board. I would also check under the display overlay if all the connections are good.
I know it is not much, but I hope it helps.
Mar 05, 2011 | Landice L770 Club Series Treadmill
With the L7 plugged in, and after pressing the start button, nothing lights up and the belt does not move.
looking for a qualified technician to check the connectors on the lower board specifically where the motor wires connected.
this part of the lower board overheats and sometimes there are false contact.
Aug 25, 2010 | Landice L7 LTd Pro Sports Trainer...
Feb 12, 2010 | Landice L7 LTd Pro Sports Trainer...
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
Sep 19, 2017 | Landice L8 LTD Cardio Trainer Treadmill
Landice L7 L8 L9 Drive Motor, 3hp, 110v Parts Baldor Dc Logo
69 people viewed this question
Top Landice Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Brian Woods
Level 1 Expert
Treadmill Repair...
Treadmill Repair...
Level 1 Expert
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
