Question about Canon P1-DHV Calculator
Adds on screen not printing whats on the screen
When I add it will show it correct on the screen, but when I go to print it will not print what I added. For exampl I put 5.06 +5.06 it will look like ..060E
9
..06* I just want it set for simlple addtion. I haven't used it in 1 1/2 years
  • 73 Answers
Call Canon at 800-828-4040. Select technical support. You actually get a live person.
They can e-mail you the manual in PDF format. It takes about 5 minutes.
Posted on Feb 06, 2009
I have a sam4s ER-5200M. Today it started printing a 4 in front of all prices on the receipt. The screen says the correct amount.
http://cashregisterguys.com/files/Samsung_5200_40M_man.pdf
i saw this on page 116,it looks relevant,,,,,,,,,21.. Display add price of linked item? When Y, the customer display shows a total of the item and linked item. For example, if PLU is $1.00 and is linked to PLU2, which is $0.25, the display will show $1.25.
it doesnt add 40 dollars so that leads me to believe that there is an error with the printer,you might need to reset and start over or call the company,good luck.
Apr 21, 2015 | Retail Supplies
Tip
How To Add Page Numbers to Prints / Copies on a Sharp Copier
This is a simple question that I am often asked, and I decided to put together a little guide on how to add page numbers in various programs/applications as well as from the copier's touch screen. Originally I thought this was something that could be dictated from a Sharp print driver, but it's not. It's accomplished by adjusting the settings of the actual document before you print it out.
Print Page Numbers Onto Copied Documents
1. On the Home screen, touch Copy
2. On the Copy screen, touch Others at the bottom-left
3. On the Others Screen, touch Stamp
4. On the Stamp screen, move to the Page No. tab, then choose the location of the page where you want the page number. You can also choose the pattern or text style that you want the page number to be on the left side of the menu.
5. Touch OK. Your copies will have the page number stamped in the position you chose.
Printing Page Numbers from Microsoft Word or Excel on a Windows PC
1. Open your document
2. Once you're ready to print the document, move to the Insert Tab, and choose Page Number, then choose the position where you'd like the page number printed, and the type/style of the numbering.
3. Your print outs will now have the page number printed on them.
Printing Page Numbers from Adobe Acrobat / Adobe Reader
First of all, Adobe Reader cannot add page numbers to PDF print outs. It's a READ ONLY tool incapable of editing documents. You'll need either Adobe Acrobat Pro, or software similar to what BatesNumberer.com offers.
There is a great video on tv.adobe.com that details how to add page numbers via Adobe Acrobat.
In Conclusion
Make the necessary changes to your document to add page numbering before you print it, or before you copy it. There are a ton of other great tutorials for Sharp copiers/printers at www.youtube.com/equipmybiz
Copier Collin Houston TX Copier and Imaging Expert
on Feb 09, 2015 | Sharp Office Equipment & Supplies
Tip
General Printer Troubleshooting: Make sure the printer has power and is ...
<b>General Printer Troubleshooting:</b> <ul> <li>Make sure the printer has power and is on-line. If you are using a manual printer sharing device, make sure the switch is set to activate the correct printer.</li> <li>Turn it off and on again to reinitialize any internal settings that may have gone astray.</li> <li>Ensure that the tape that seals the cartridge ink port is removed prior to installing the cartridge.</li> <li>Use the printer's own self-test, according to the manufacturer's recommendation. If it fails, you have verified that the problem is within the printer. If the print head is not moving at all, the transport motor may have failed.</li> <li>If the printer that you are using is not set as the default printer in Windows or the printer driver is not installed, the printer may print garbled characters. You may also receive errors when you attempt to print from applications.</li> <li>If the printer passes the self-test, try a test print using the Print Screen capability within DOS. If the Print Screen fails, you know the problem is in the relationship between the printer and the computer. Inspect the cable and the cable connections. Replacing the cable with a known good cable is worth trying since cables are so frequently the source of printer problems. Cables can fail with broken wires, loose or broken pins, or incorrect pin-outs.</li> <li>If the printer is connected to the computer through an add-in device, remove the add-in device and connect the parallel cable to the printer and then directly to the port on the back of the computer. Some examples of add-in devices are: switchboxes, parallel port scanners, external disk drives, external tape drives, security lock keys, or external CD-ROM drives. Some add-in devices may interfere with proper communications with the printer. Try printing again. If the printer prints successfully, the cable may not have been connected properly, or the add-in device may have been interrupting communication with the printer.</li> <li>If the combined length of the cables connecting the add-in device and the printer exceeds 10 feet, communication can also be disrupted. In addition, the software that controls some add-in devices may take control of the printer port interfering with any other device attempting to use the same port. In some cases, the software for the add-in device should be disabled or uninstalled. Remove any add-in devices and uninstall the software for those devices, then try printing again.</li> <li>The message "out of paper" is sometimes erroneously reported when there is plenty of paper, and can indicate a physical problem with the printer.</li> <li>If the printer port is not properly identified in CMOS, the printer may not function properly and you may receive errors when trying to print. Check your User's Guide on how to enter CMOS. Once in the Setup utility, locate the LPT1 settings. The address setting for the LPT1 port should be 3BCh or 378h depending on what kind of video card you have. The IRQ setting for the port should be 7 and LPT1 should be enabled in order for the printer to print correctly.</li></ul>
on Mar 31, 2011 | Office Equipment & Supplies
How do I add my iPad to my printer?
other way around - you need add printer to your ipad, you did not write what printer model and name, you did not supply information if it is this on wireless network or it is wireless printer, without that information help is not possible...
telepathy is overrated... work only in the movies...
Dec 28, 2014 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Trying to add cannon mp450 printer to my mac and error 9672 shows up it will not print
Click OK on the message prompt to close the message.
Uninstall the Epson Printer software that came with your printer using the uninstaller. Follow the on-screen prompts to uninstall the product.
From the hard drive, click Applications, then click Utilities and select the Printer Setup utility.
Click Add.
If your printer shows up in the printer list, select Printer. If the printer does not show up in the list, choose either Bonjour or Rendezvous as the connection type and then select the printer from the list.
Under the Print Using list, select epson stylus CX5000.
In the list of available drivers, select the epson stylus CX5000 - Gimp-Print driver.
Click Add
Using the Gimp-print driver might provide basic print-only functionality. This driver is a built-in driver in the Macintosh Operating System and will not provide all of the features that are provided using a direct USB connection.
Jan 03, 2013 | Canon Pixma MP450 All-In-One InkJet...
Tip
How to troubleshoot printer issues?
<p><b>General Printer Troubleshooting:</b><br /> <ul> <li> Make sure the printer has power and is on-line. If you are using a manual printer sharing device, make sure the switch is set to activate the correct printer.<br /> <li> Turn it off and on again to reinitialize any internal settings that may have gone astray.<br /> <li> Ensure that the tape that seals the cartridge ink port is removed prior to installing the cartridge. <br /> <li> Use the printer's own self-test, according to the manufacturer's recommendation. If it fails, you have verified that the problem is within the printer. If the print head is not moving at all, the transport motor may have failed.<br /> <li> If the printer that you are using is not set as the default printer in Windows or the printer driver is not installed, the printer may print garbled characters. You may also receive errors when you attempt to print from applications.<br /> <li> If the printer passes the self-test, try a test print using the Print Screen capability within DOS. If the Print Screen fails, you know the problem is in the relationship between the printer and the computer. Inspect the cable and the cable connections. Replacing the cable with a known good cable is worth trying since cables are so frequently the source of printer problems. Cables can fail with broken wires, loose or broken pins, or incorrect pin-outs.<br /> <li> If the printer is connected to the computer through an add-in device, remove the add-in device and connect the parallel cable to the printer and then directly to the port on the back of the computer. Some examples of add-in devices are: switchboxes, parallel port scanners, external disk drives, external tape drives, security lock keys, or external CD-ROM drives. Some add-in devices may interfere with proper communications with the printer. Try printing again. If the printer prints successfully, the cable may not have been connected properly, or the add-in device may have been interrupting communication with the printer.<br /> <li> If the combined length of the cables connecting the add-in device and the printer exceeds 10 feet, communication can also be disrupted. In addition, the software that controls some add-in devices may take control of the printer port interfering with any other device attempting to use the same port. In some cases, the software for the add-in device should be disabled or uninstalled. Remove any add-in devices and uninstall the software for those devices, then try printing again.<br /> <li> The message "out of paper" is sometimes erroneously reported when there is plenty of paper, and can indicate a physical problem with the printer.<br /> <li> If the printer port is not properly identified in CMOS, the printer may not function properly and you may receive errors when trying to print. Check your User's Guide on how to enter CMOS. Once in the Setup utility, locate the LPT1 settings. The address setting for the LPT1 port should be 3BCh or 378h depending on what kind of video card you have. The IRQ setting for the port should be 7 and LPT1 should be enabled in order for the printer to print correctly.<br /> <li> If the Print Screen succeeds, the problem may be with your application or its configuration. For example, your application may be set up to direct output to a file instead of the printer, or you might be directing the output to the wrong communications port.<br /> <li> Try connecting a different printer to this computer or try connecting the printer to a different computer and print a test page. If this printer works when connected to another computer, there may be a problem with the port on your PC. If this printer does not work when connected to another computer, there may be a physical problem with the printer. </li></ul>
on Jan 21, 2011 | Office Equipment & Supplies
I recently loaded windows 7 and now I cannot print word documents through the print server. I can if I connect direct to the printer. excel and powerpoint print normal through the print server. Is their a...
Start > Devices & Printers > Add a Printer > Add a network, wireless or Bluetooth printer
> The printer I want isn't listed (unless it is!) > Add a printer using a TCP/IP address or hostname
> Device Type = Autodetect / Hostname or IP address: 192.168.XXX.XXX (The 1260's IP assigned by
your router - make it a static IP beforehand) / Port name: [the autofill IP is fine] > Additional port
information required = Standard "Network Print Server (2 ports - USB)" > Select the driver for the printer
you want to use...
Once the install is complete go to the Devices and Printers screen and click on the new printer.
Click Customize your Printer, change the name if you prefer and then on the ports tab. Mine is
set to Protocol "Raw", Port Number 9100, Community Name "public". The only other thing I may be
doing differently is that I have set the printer to auto-show the print preview before printing.
Yes, its an additional click but it seemed to have made all the difference in my case. It also
gives you the chance to correct something like printing a second page with just a header URL, etc.
I realize that time is a luxury and not everyone has a lot of it, especially for trivial tasks
like addressing antiquated equipment compatibility issues after an upgrade, but I firmly believe
if you say can't enough, you WON'T. But for those who enjoy a challenge occasionally I hope this
points you in the right direction. Good luck
Jan 10, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Canon P1-DHV Calculator Logo
143 people viewed this question
old marine
old marine
