Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
Wiring for a Honeywell RTH2310B
We are replacing an old Automag thermostat, which controls just gas hot water baseboard heat in an upstairs zone.  There are 3 wires --Red (R), White (W), and Green (hooked up to B).  The new thermostat has R,Y,W,G, and Rh.  How do we connect our wires?
    Guru:
  • Honeywell Master
  • 588 Answers
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Posted on Sep 13, 2009
  • 232 Answers
SOURCE: Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Posted on Sep 20, 2009
Testimonial: "Thanks! Worked out great!"
boanhtgclg
  • 34 Answers
SOURCE: program manual for honeywell thermostat model T8700C1005(1)
try holding the up and down arrow, down, at the same time, see if the time or temperature starts flashing. also the cover should lift up so you can change from heat to cool, there should be a program button or a set button to hold down. all you should have to do is adjust the time and temperature for the 4 settings during the week and the two on the weekend. should be really easy, let me know if you need some more help
Posted on Nov 13, 2008
tborn6
  • 700 Answers
SOURCE: I bought a rth2310b honeywell
on rh and w
Posted on Jan 26, 2009
FixinFax
  • 3085 Answers
SOURCE: I lost my RTH2310B manual
http://customer.honeywell.com/techlit/pdf/69-0000s/69-2229ES.pdf
Posted on Nov 07, 2009
SOURCE: need to hook up a honeywell rth2310b with only 2 wires!
In some situations the wall plate has no markings, there are just two terminals hooked up to the control wire for the heater. I just installed this thermostat on my gas fireplace. I connected the black wire to the Rc terminal and the white wire to the W terminal. With the thermostat set to heat it works perfectly. Thanks to johnptaylor for the help!
Posted on Jan 16, 2010
Honeywell thermostat
The wiring is correct but you have a programmable thermostat that needs to have a program to operate. The manual for this particular stat is straight forward and uncomplicated. Enter the times and functions with the right button and up/down arrows then press "DONE" (Left Button) to get it started. Hope this helped. Roger
Jan 30, 2014 | Heating & Cooling
Hot water baseboard, third level heat not working
Raise water pressure to 12 and bleed out of the return pipe for that zone until you get all the air out!
Jan 09, 2014 | Honeywell Armstrong Gas Furnace Flame...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
I have a new Honeywell Round Non-Programmable Heat Only thermostat MFG # T8775A1009. I turned it down to 50 degrees. The room temp. is reading 70 degrees and heat is coming out of my baseboards. Why is...
Make sure the switches on the back of the thermostat is set for hot water heat. If you have more then 1 zone you may a stuck zone valve or a short in the wiring somewhere keeping the boiler on.
Apr 02, 2010 | Honeywell Programmable Thermostat Heater
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
Honeywell T86F thermostat (controlling oil-fired hot water baseboard heat system) comes on on demand but will not cycle back on after zone cools - or it just takes too long???
T-Stat started smoking when activated last night. I swapped it out with one from another zone and have ordered a replacement. - www
Nov 24, 2009 | Honeywell Heating & Cooling
Furnace firing. Plenty of hot water. No heat.
Most Boiler and zone controlled systems I can remember working on with up to 8 or so zones, the Bell&Gossett circulating supply pumps or pump ran all of the time to keep the upstairs baseboards warm.If you have a relay that controls the pump, see if you can bypass it and if it comes on, replace it. Be sure all of the coils on the zone valves are energized and opening, if it is set up that way.Get back to me and let me know.
Sincerely, Shastalaker7
Nov 06, 2009 | Heating & Cooling
One zone not working; another is partly working
i would check my water pressure on boiler sounds like lack of pressure or air in system they can be related. if you have bleeder on baseboard try to bleed.
Feb 20, 2009 | Honeywell Programmable Thermostat Heater
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
5,276 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
