How can i reset my edimax router if the reset button doesn't work. I can't access the router because i forgot the username & password.
  • 7,627 Answers
Press and hold for 30 seconds .
Posted on Nov 30, 2012
  • 556 Answers
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Posted on Dec 06, 2007
SirHanz
  • 145 Answers
SOURCE: forgot passwrd on a us robotics router
Generally you have to push and hold the reset button, i suggest for 30 seconds, this should completely reset the unit, including passwords and settings.
Posted on Jan 29, 2008
pamthegreek
  • 148 Answers
SOURCE: I forgot the router's username and password.
Try admin, admin. If that doesn't work press the reset button and it will restore the factory settings. You will have to reconfigure the router.
Posted on Jul 17, 2008
Silverblade
  • 173 Answers
SOURCE: forgot password and username
Yes there is.
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the power off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if the LED light flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
Posted on Nov 24, 2008
SOURCE: i lost my network security key, router is not working.
try this
username admin
password none
good luck
Posted on Jun 10, 2009
I forgot my password
you can reset the router to factory default by pressing the Reset button at the back of EW-7206APg for 15 seconds. This will erase all the setting in EW-7206APg and restore the factory default. after that
  1. Open Internet Explorer, at the address bar, type http://192.168.2.1 and press Enter.
  2. It prompts for username and password.
  3. The default username is admin. The password is 1234. Click on Login. You will get the configuration page of the EW-7206APG.
    setup new password
Apr 01, 2013 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
Can't connect to my edimax ar-7284wna router
theres a temporary solution... reset router and change the date on your computer to 1 febrauary 2010 and you will be able to login. you can set all your details and even if you change your date back to current it will not affect your settings however to log back into the router you need to set back your date to feb 2010..
Hope this works.
May 30, 2012 | Edimax Computers & Internet
I forgot my paswordhow do i reset it
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Apr 19, 2012 | Linksys WRT54G2 Wireless-G Broadband...
How to change password of dlink router 600 without reset
the default dlink password is password or 1234
if that doesn't work then the password has been changed and you will need to reset the router to factory defaults. hold the reset button for 30 seconds while powered on.
Mar 04, 2012 | D-Link DIR-600 Router
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I installed my DIR-615 router about 2 years ago and set it up with wired, not wireless, connections. I have forgotten my admin password and can't get into the router firmware to reconfigure for...
If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Jul 07, 2011 | D-Link DIR-615 Wireless Router
I forgot my wep key and router username/password
Use first the default username and password according to your router's manual. If it doesn't work reset the router. Look for the reset pin hole on the back of the router. Press and hold it down for 1 seconds.
After that use the default username and password for sure this time it will work. As soon as you are able to access the configuration page of your router please setup a new WEP key to keep you network secured.
May 21, 2011 | Linksys WRT160N Wireless Router
I cant acces to 192.168.2.1
If I'm not mistaken, you can't get to the user name password page unless you have already accessed the edimax setup page after typing 192.628.2.1, thus the solutions provided by some of our friends might not be of help.
Jan 09, 2009 | Edimax BR-6104K Router (br6104k)
I cant access my router(EDIMAX BROADBAND ROUTER)
Then
I hope this helps.
Dec 02, 2007 | Edimax BR-6104KP Router (BR6104KP)
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
