Question about Toro Genuine Ignition Switch P 27-2360 " Ignition Switch Only No Key Included"
I NEED HELP REPLACING THE IGNITION KEY SWITCH ON A 1998 HONDA PASPORT ?
DO YOU HAVE A DIAGRAM OR INSTRUCTION SHEET ?
  • 496 Answers
To remove the ignition lock:
CAUTION
You must remove the steering wheel when replacing the ignition lock. On vehicles with a Supplemental Inflatable Restraint (SIR) system, you must temporarily disable the SIR system and remove the inflator module when removing the steering wheel. Leaving the SIR system on could result in deployment of the air bag and possible personal injury.
  • Disconnect the negative battery cable, and remove the steering wheel.
  • Remove the bumper and the carrier snapring retainer from the steering shaft.
  • Use a lock plate compressor screw tool to install the lock plate compressor screw in the upper steering shaft. To keep the shaft from telescoping, tighten it to 40 inch lbs.
  • Using the lock plate compressor tool, install on the upper steering shaft, tighten it to depress the shaft lock. Remove the shaft lock retainer, the compressor tool and the steering shaft lock.
  • Remove the turn signal canceling cam assembly. Put the turn signal switch in the "N" position and remove the upper bearing spring.
  • Position the turn signal switch so the mounting screws can be removed through the holes in the switch and remove the turn signal lever.
  • Remove the turn signal switch-to-steering column screws and lift the turn signal switch. Remove the wire protector and disconnect the turn signal switch connector.
  • Use a terminal remover tool to disconnect the buzzer switch wires from the turn signal switch connector. Remove the buzzer switch assembly with needle-nose pliers.
  • Place the lock cylinder in the ACC position, then remove the lock retaining screw and the lock cylinder set.
  • To install the new cylinder lock, reverse the removal procedures.
  • Tighten the lock retaining screw to 22 inch lbs., the turn signal switch screws to 59 inch lbs. and turn the turn signal lever screw to 53 inch lbs.
  • As part of the final replacement procedures, check the operation of the switches and the steering column.
I NEED HELP REPLACING THE IGNITION KEY SWITCH ON A - f42-11.gif The steering wheel is splined to the steering column and held in place by a nut. Courtesy of General Motors Corporation - Service Operations.
Posted on Nov 30, 2012
My 1998 Honda Accord, About a week ago the battery,door & brake dash lights came on and would not go off, and then one day i shut it off and it would not crank so i turned the key off and waited a
if you have alot of keys on your key chain the weight has been known to damage a honda ignition switch, lighten the load to see if that helps. chances r though its a bad or damaged ignition switch.
Apr 01, 2014 | 1998 Honda Accord
I need a diagram to replace an ignition switch in a 1998 toyota avalon
https://www.youtube.com/watch?v=w4oJhsUo9Wc
maybe this will help
http://www.partsgeek.com/mmparts/ignition_lock_cylinder/toyota/avalon.html
Aug 07, 2017 | 1998 Toyota Avalon
How do i get to the ignition switch
I had to replace the ignition switch in my honda and the manual for the honda said that it was on the opposite side of where the key goes in (in my case the key went into the steering column, not the dash like some vehicles). I had to take apart the steering column, but once I replaced the switch, the problem that I had went away. Hope this helps. I only know where it is on a 1998 honda accord, not sure what kind of car you have.
Mar 24, 2012 | Cars & Trucks
How do i replace a ignition switch on a 1998 chevy blazer
To get exact procedure with diagram and detail.Please click on the link below and follow the instructions to replace ignition switch on 1998 chevy blazer.Click the link below:--- http://technoanswers.blogspot.com/2011/02/how-to-replace-ignition-switch-on-1998.html ------------- This should help.Thanks.Helpmech.
Feb 25, 2011 | Chevrolet Blazer Cars & Trucks
I have a 1998 honda cbr900rr my key broke in my ignition switch replaced it but not getting any spark from my coils
Did you replace it with an OEM ignition switch and connect all wires correctly?
Was the bike "ON" when the key broke?
Check your batery state if still good or replace it when it is not.
Good enough?
Jul 21, 2010 | 1998 Honda CBR 900 RR Fireblade
All electronic accessories work when key is in
test power at the starter's power wire. If there is voltage, replace starter. If there is no power, check fuses/relays, if those are fine, check ignition switch (there is a recall on this since 2002). Typical symtoms of ignition switch failure on these vehicles include: Some warning lights not lit when key is turned to ON (ABS, battery, check engine, oil light etc.), Intermitted hard start/No start, stalling while driving, intermitted guage failure. If it is an ignition switch failure, call your local honda dealer for possible free repair under the recall(have your VIN# at hand). hopefully this helps
Sep 11, 2009 | 1998 Honda Prelude
Ignition and Engine management light
Try applying a none liquid graphite lubricant into the ignition key hole, work it into the key hole with the key, DO NOT use a liquid lubricant on ignition switches it can short out the ignition switch. engine management light? bring it to autozone or advance auto ask to use thier code reader plug it in and check to see if the car is throwing a code then go from there.
Jul 02, 2009 | 1998 Honda Accord
1998 honda accord won't start
He may have locked up the pin sequence. You might need to buy a new switch not that exspensive. Stay away from the dealership or it will be.
Apr 10, 2009 | 1998 Honda Accord
Toro Genuine Ignition Switch P 27-2360 " Ignition Switch Only No Key Included" Logo
227 people viewed this question
Top Toro Heavy Machinery Experts
Tom Chichester
Daryl Gleaton
Bill Boyd
Are you a Toro Heavy Machinery Expert? Answer questions, earn points and help others
