Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Not getting fuel
I have a reddy heater proffesional series 200t and it is not getting fuel.
  • Anonymous Jan 14, 2009
    i took the fuel pump apart to clean it and i am not sure i put it back together right.Is their a diagram i could look at
  • 232 Answers
Check the pump pressure. If 0psi, the rotor (air pump) probably broken. If not set to factory specs.
If there is some pressure, then check for air leak between the pump & the nozzle or vac leak in the fuel line, or possibly a clogged fuel filter.
Posted on Jan 12, 2009
I HAVE A 125000 PROPANE REDDY HEATER THAT GETS WORM, BUT WANT GET HOTTER.
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 20, 2011 | Reddy HEATER RH125T 125,000-BTU...
Why does a allpro 200t keep flamming out??????
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Dec 09, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Ignition starter fail
Read these troubleshooting tips. You must determine whether the failure is a fuel delivery problem or an electronics problem.
Reddy Heater troubleshooting tips
Oct 19, 2010 | Reddy HEATER RH125T 125,000-BTU...
Can you burn diesel fuel
Hi, If this heater is the Reddy 170,000 b.t.u. heater, model # 170t professional series, then yes you can.It is a multi-fuel heater. Fuels it can use are Kerosene, JP8, Jet A fuel, 1&2 Diesel fuel, and 1&2 fuel oil. It must be this model 170T.
Sincerely,
Shastalaker7
Jan 19, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater has problem staying on
Check the foam filters located in the back, their is also a primary air adjustment slot in the back try adjusting that each time you fire it to see if you can get it to stay on.
Can you see the fuel oil coming out of the nossle? If
not clean it. If it has a cad cell that could be bad or dirty, you might have to bypass it to see if that is the
problem.
Jan 15, 2010 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
I can't get my reddy heater to light. No fuel
If there is NO fuel then the pump rotor is probably broken. http://www.reddyparts.com/rotor%20replacement.htm
If there is SOME fuel then set the air pump pressure. http://www.reddyparts.com/pressure.htm
Nov 02, 2009 | Desa International Reddy Heater R40 40,000...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
131 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
