Question about Pinnacle Dazzle DVD Recorder
No picture on computer
I have the audio coming thru the computer but no picture (blacked out screen).thought it was a bad video cord VCR(tried 3 diiferent ones nothing) So I connected the video camera & still had sound but no picture.Un-installed program then re- installed nothing changed
  • avp555 Jan 11, 2009
    Mointer is working fine/ the picture on the little screen is blacked out.It lets me go thru the steps.Maybe I explained it wrong I forgot to mention that the 1st time I plugged the video cable in for a very brief moment I had a picture as the same as I had on the TV then it went black(no pict) but still had sound.Thats when I tried 3 diifferent video plugs No change
  • miffy123 Jan 17, 2009
    no picture or sound on the mini screen on instant dvd recorder.why?
    Genius:
  • 2,920 Answers
I think you have a bad mnitor
Posted on Jan 10, 2009
I have sound but no picture. The screen is black
can you see any any menus or the volume bar or channel indicator?
Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Vcr/tv
Either the video cable is bad, or the video input on tv or output on vcr has a bad capacitor is bad. You can test with an ohmmeter for both.
Or try using coaxil cable or different video cable and do make sure tv is on the right channel for video and audio
Oct 13, 2009 | Televison & Video
It doesn't work on my ps3 no picture only audio
If it works on other televisions, than the video cord must be good. Is the television on the right input channel? If it is, the video input may be bad. You should test the video input with a dvd player or vcr. You can always plug ps3 into a vcr, and vcr up to televison.
May 23, 2009 | Beko 142746 TV
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
Computer monitor problem
power supply is most likely going could be capacitors on the vga /inverter board also needs to be checkd out at a service location
May 01, 2008 | Gateway FPD2275W LCD Monitor
AKAI Black TV screen, but still have audio
I think your Video Drum needs to be replaced since it's bad. You can get replacement Video Drums on the Internet.
Mar 10, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
No sound and picture or video
please help !!!! is it an expensive fix ? yes it is too expensive to fix it better to buy new one. as even you fix it , it will always give you problem. good luck
Oct 06, 2007 | Sony KV-27FS13 27" TV
Pinnacle Dazzle DVD Recorder Logo
484 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
