Question about Fleetwood 1996 96
I cant find the brand name of the furnace in my 1996 euroway fv
Serial number is 0393977 model number is 8531-111dclp cicuit breaker is w58-xv1 aaa-10
The modal number and serial # for my furnace is MODEL # F+RPQ24HQ6A SERIAL # EEGS13264Q OUR FURNACE IS IN A METAL BOX AND WE CANT SEE THE BRAND NAME IS WE JUST BOUGHT THIS HOUSE BACK IN DECEMBER 2016
That's an older YORK product. The serial numbers are all coded by the alphabet. York or Luxaire parts house can help you. Probably about a 1980's unit. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Our furnace is in a metal box and all we have is a serial number and a modal number how can we find out the name brand of our furnace with just this information
Post that info, maybe someone has seen it. Also, look at and/post the other info that's on the name plate, if it has any. Model numbers may look familiar.
Fans kick in after just a short run and heaters not working
Is the heater a gas furnace? Do you know a brand name . Possibly a model number. If a Trane a serial number too. Why type of unit package or split system. Can you be more specific?
Feb 20, 2017 | Heating & Cooling
I have a furnace with model # C9MPD100J14A1 I want to know the brand name
Take the front panel off on the side left or right you should see a data badge with make model etc the name is there somewhere .
Dec 12, 2016 | Heating & Cooling
Missing nameplate on gas furnace category 1 gas furnace I have serial number or model number need to know who makes this furnace
Call a store that sells gas heaters and ask them.
Since most stores sell only a few models, you may have to call several before you find one that sells that particular brand.
You might also call your local gas company for assistance, they may also know.
God bless your efforts.
Oct 25, 2016 | Heating & Cooling
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
Feb 26, 2014 | Emerson Lennox Ducane Armstrong Furnace...
No heat just blows cold air
The furnace may be locked out on a fault, go to the furnace & see if there is a peephole window so you can see if there is a flash code. If so, count the flashes and the model & serial number along with the brand name so we can better stermine what may be going on.
Nov 02, 2010 | Heating & Cooling
Looking for age of Furnace. Model number appears to be 3010 100n. The serial number appears to be cn3 d108 50972 7055.
Not knowing the Brand, I am taking a educated guess, but it looks like it was made in the 50th week of 1997, 100,000 BTU furnace.
Good luck,
Paul Gibson
Apr 06, 2010 | Heating & Cooling
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Where is the driver side power window cicuit breaker.
check the wireing to the window motor an at the conector as well where it comes thru the door =- i have seen them break there an its covered === also check the circuit breaker in the fuse pannel position number 16 in the breaker for the window motors ok
dennis
Nov 23, 2008 | 1996 Chevrolet Cavalier
Fleetwood 1996 96 Logo
20 people viewed this question
Top Fleetwood Car Audio & Video Experts
xxxxxx xxx
mike simpson
Are you a Fleetwood Car Audio and Video Expert? Answer questions, earn points and help others
