Question about Brother SE-270D Computerized Sewing Machine
The piece that looks like sharp metal under the foot dose not work
It is kinda rough under the foot
  • Brother Master
  • 1,564 Answers
That is called your feed dog. Remove any embroidery attachments and check for a switch that allows you to lower the feed dogs. It should be on the back side of the machine directly behind the sewing area.
Another possibility is that you have it in bobbin winding mode.... but then your needle wouldn't work either.
Posted on Nov 30, 2012
Walking foot not walking.
Most people don't realize that the moving parts of a walking foot could use some periodic lube. Take the foot off and manipulate it with your fingers and see where metal parts move against metal parts and apply a small drop of good quality sewing machine oil or Tri-Flow Synthetic Lube (if you have it). Make sure to wipe off any excess oil and test it again on a piece of scrap fabric.
If oil doesn't help, it could be that the walking foot has been damaged.
Mar 06, 2017 | Sewing Machines
Cant get tension correct when zig zag on really strechy material
Be sure you are using a ball-point needle. Try setting the upper tension looser. You also may need to increase the presser foot pressure on your machine (consult your owner's manual if you don't know how to do this). Using a closed-toe presser foot (vs an open-toe embroidery foot) may help control the fabric and prevent it from puckering under the needle. Also, reducing the width of the zig-zag may be helpful.
Some sewing machines have an overlock presser foot. Effectively, there is a thin piece of metal in the center of the presser foot. The needle will straddle that piece of metal in a zig-zag so the upper thread has a little bit of slack in each stitch that will let the fabric lie flat. It is a very nice tool to have especially when zig-zag finishing raw edges too.
https://www.amazon.com/Janome-Top-Load-Overedge-Foot-Brush/dp/B00KCWB2SA
C9store overlock presser foot how to video
Some sewists will increase the fabric's "body" by inserting a layer of wash-away or tear-away stabilizer. If it is only a small project, a piece of paper added to the seam (like adding machine paper) will help stabilize the fabric.
One last thing to try would be loosening the bobbin tension. However, there is a reason it is the last effort, because most sewists are uncertain about messing with the bobbin and it is also requires "minute" adjustments to effect a big change.
How can properly adjust my tension
Understanding Bobbin Tension
Jun 18, 2016 | Sewing Machines
Model 158.17550. Where does the little metal piece under the throat plate go?
Kenmore 158.17550 Sewing Machine Tutorial - YouTube
? 25:01
https://www.youtube.com/watch?v=xlPQZ9jmR9c
Apr 2, 2014 - Uploaded by Marianne D
Kenmore 158.17550 Sewing Machine Tutorial .... Why is myneedle hitting something on the plate when I try to start sewing I am getting ... Tweezers work wonders for finding small pieces in the tiny spaces you have to work with. ... I recently purchasedmodel 158.162, Pressure foot will not adjust, currently ...
Nov 25, 2015 | Kenmore Sewing Machines
The rough piece under the foot on my sewing machineis not working
Behind the machine by the sewing area is a slide switch for the feed dogs. Make sure it's in the "sew" position
Nov 30, 2012 | Brother SE-270D Computerized Sewing...
Husqvarna rose tried to run it and the pressure foot light comes flashing on and will not run. yes the presser foot is in the down position
There is a safety switch underneath the presser foot lever, its tucked away in the body cavity and its tough to see. The switch is operated by a metal spring that turns the switch off and on according to the presser foot lifter position. the spring, which kinda looks like a fork, gets compressed each time you lift the presser foot. It wears and works intermitantly. A dealer is the only solution, the back needs to come of, and its a dang tough job to replace without damaging the replacement spring.
The other thing it could be is a jammed check spring inside the tension assembly, again its a tough job as the auto tension assembly must be removed, along with the winder and loosening of the main board.
derek
Jan 15, 2011 | Husqvarna Rose
Inside the walking foot a piece of metal broke
I would contact the manufacturer and ask about it. Maybe a replacement part is available.
May 31, 2010 | Sewing Machines
RUNS ALL THE TIME
Hello, I hav no idea of what type of machine you are using but, I have two older Kenmore mechanical sewing machines and a very old Dressmaker and have fixed the same problem with mine.
If you gently remove the outer metal housing on your pressure foot control, (unplug it from both the outlet and the machine) there is a black metal coil like thing with two longer end pieces. They respond to your foot pressure, tranferring that pressure to a series of parts and copper to complete the electrical connection needed to run your machine.
Look and see if there is any rust around that black coil piece. If this is the problem, your pressure foot is getting caught and frozen in the "on" position and unable to dis-engage to stop the electrical connection to your sewing machine.
Clean any rust, (emery or steel wool works for me) check your wire connections, dry it completely and replace the foot petal housing. It may take a little tinkering but this will work if this is the problem. Best Wishes.
Dec 08, 2008 | Sewing Machines
Parts fell out
WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
Apr 18, 2008 | Brother SE-270D Computerized Sewing...
My singer simple
tension issue,,,,,upper tension assembly needs to be adjusted, either the machine is not being threaded correctly or tension assembly is bad,,,
Jan 01, 2008 | Singer 3116 Simple
Brother SE-270D Computerized Sewing Machine Logo
21 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
