Question about RCA P46924 46" Rear Projection Television
TV won't turn on.
The TV stopped working a long time ago. Power button on front panel or remote won't turn on the TVThe trouble shooting section said that the problem might be that the parental controls were used to lock out the front panel buttons and to use the remote to unlock the panel buttons. Replaced batteries in remote no resposne to power or menu buttons. Manual suggested also unpluggin TV and leaving it off for two minutes...no change. Can it be as simple as a problem with remote and parental lock out of front panel or should unpluggingit have eliminated that problem. What shoulkd I try next?
Kimi
  • 277 Answers
SOURCE: Remote sensor in the TV
First Inspect the remote batteries. also make sure TV is not on a LOCK ON option... now, the sensor is a small smoothly part near the TV front buttons, you can clean it carefully FYI, exposing unit remote sensor to direct fluorescent or outdoor light may cause signal interference.
Posted on Nov 16, 2005
  • 236 Answers
SOURCE: TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Posted on Feb 04, 2007
SOURCE: Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Posted on Mar 18, 2007
SOURCE: RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Posted on Jan 05, 2008
SOURCE: RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Posted on Jan 18, 2008
Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
Mar 02, 2013 | Samsung Televison & Video
1990 panasonic tv model# CTM-2783S won't turn on
the tv need for servicing, the cause is either bad regulator transistor in the power supply section or shorted horizontal output transistor. that is why the main circuit board doesn't get to turn on. to do the repair just ensure you have knowledge in repairing tv.
Nov 17, 2012 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Sanyo DS27530 won't come on
if no any power indicator at the front panel what you can do is to remove the back cover of the tv then look for a blown fuse at the power supply section. if ok, at this time a trouble shooting must be applied if you want to do it with your own just let me know and i can give you further solution good day.
Sep 18, 2012 | Televison & Video
VIZIO VS470 WON'T TURN ON
do you mean the power indicator at the front panel doesn't light.ok this kind of trouble is in power supply section since the stand by doesn't work. the first place to be check is the fuse if blown. if blown with darkened color that was an indication that has other component part that get shorted. at this time you will need a proper trouble shooting using the a device like a digital or analog tester. if you don't have enough idea on how to do the job and necessary tools, just send it to the trusted service shop to fix the problem.thanks for using the fixya.
Aug 13, 2012 | Vizio VO370M LCD TV
TV won't turn on power light flashes 10 times
Switch off the TV from remote, then switch off the on/off button on the TV, remove the plug pin from the power outlet. Cool off for 48 hours and then retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Panasonic Televison & Video
Tv won't turn on
if no any light indicator at the front panel of the tv, the cause is either failed in the primary power supply section or their is a shorted line at the horizontal section. you must need a trouble shooting which you need a proper device and tools.
Jul 18, 2012 | Televison & Video
I turned tv off with remote, now it will not turn back on. i have tried remote and button on front of tv.
Check the remote with new batteries. If it do not work, remote control has the trouble. You can't switch the set ON by its front panel power switch, as it has been shut down by remote command.
Mar 31, 2012 | Symphonic WF20D4 TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My tv wont come back on fpa lock on
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy.
Deva
Apr 21, 2011 | RCA 20F420T 20" TV
RCA P46924 46" Rear Projection Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
