Question about Refrigerators
LG GR-S392GC refrigerator bought 2002 - bottom fan inside fridge is freezing up.
Refrigerator 2002 model
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
yeroc
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
woodchuck789
  • 4070 Answers
SOURCE: vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Dec 17, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
LG FRIDGE model FR-S392GC periodically leaks water onto the floor
If you leave the fridge door open the fridge will condense water from the air and after a few hours a puddle will form. Make sure the door stays shut. Also it may have a defrost cycle which can cause this.
Jul 09, 2016 | LG Refrigerators
LG GR-S512GCA NOT COOLING
check and see if compressor is kicking on and off after a few sec if it is you might try a hard start on the compressor its a little switch that goes on the compressor where the wires go cost around thirty dollars be worth a try before going out and buying a new fridge
Jan 27, 2014 | Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
Model GR 382-R serial # 208MR36393 only 7 years old, not main fridge, is freezing all items in bottom, called in repairman, after 1 mo still cannot get my fridge repaired.
The damper could be sticking open or in some models, the bottom of the air tower will need to be sealed. The setting may also need to be adjusted. The recommended setting is just a normal starting point under ideal conditions. Try setting it slightly warmer. If this is electronic, it could be a board or sensor problem.
Jan 26, 2011 | LG Refrigerators
LG Larder Fridge model GR-252 SBD IS FREEZING ON INSIDE BACK PANEL A LUMP OF ICE FORMS. How can I stop it?
this is a defrost problem . either the A D C a pc board on the back side of the frig . this main board controls the temp[t and the defrost . and has failed . repl it and problem is over .. mm hope this has helped .. feed back pls ..
Jul 22, 2010 | Hotpoint RLA80 Refrigerator
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
Jul 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
I have electrocool LG MOdel# GR-382R ser# 206MR17803. my bottom fridge cooler area is freezing up.
I have the same problem.It seems that the gasket around the freezer door and fridge door are no longer tightly adhering to the fridge therefore allowing the cool air from the freezer to continiuously entering the fridge storage and making evreything freeze up. I am trying to find out if I can purchase new gaskets and install them myself.
Any recommendation on where to find these and how to install them?
Thanks.
Jun 22, 2009 | LG Refrigerators
Mar 02, 2009 | LG LFD25860
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
