When report is printed there in a line where the ink is not printing letters
    Guru:
  • 571 Answers
You have two possible problems:
1. The inkhead is dirty.
2. You are almost out of ink.
Here's what I can suggest.
Run a printhead clean up via the printer's control panel or clean the inkhead with a clean wet cloth. You should use a warm water to wet the cloth. Make sure that the inkhead is dry before putting it back or using it again in your printer.
By the way, I know a software that works great with any operating system. It's a technician software. What it does is it automates your computer's maintenance mechanism. If you are interested, then look up RADARSYNC in google and install it. I'm actually using it as well.
Carlo
Posted on Nov 30, 2012
jackboy
  • 2985 Answers
SOURCE: Printing is poor quality with
What printer- what Computer all information is required
Posted on Jun 17, 2008
crayzeetrayn
  • 837 Answers
SOURCE: ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Posted on Nov 23, 2008
rhoncruz
  • 134 Answers
SOURCE: #5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Posted on Dec 02, 2008
SOURCE: changed ink cartridges Kodak 5300 print blurry/missing letters
I called Kodak and they are sending me a new printer head at no charge! Can't get any better then that. Man I talked to was very nice, knowledgeable and polite.
Posted on Dec 31, 2008
leroyal
  • 2120 Answers
SOURCE: horizontal lines on printed page
You need a new Toner Cartridge
Posted on Feb 01, 2009
Brown background instead of white
You are probably out of ink in one or more cartridges. You need to do a diagnostic print and take the print to the ink supply vendor to get the correct replacements.
Oct 03, 2012 | Kodak Office Hero 6.1 All-in-One WiFi...
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
How do i know which color ink needs to be repplaced
To print a print quality report
1. Load regular, white, letter-size or A4 paper.
2. Press Setup until you see Print Report
3. Press the right arrow until you see Print Quality Report. Press OK.
Mar 05, 2010 | HP Officejet 6500 Wireless All-in-One...
Printing won't work.
Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
Oct 27, 2009 | Office Equipment & Supplies
Missing lines and some lines have only half the characters
Solution one: Make sure the paper is appropriate for the print job Using the wrong paper for the print job might cause the colors to be faded or dull.
  1. Many papers have printing and non-printing sides. Make sure to load the paper with the print side facing down.
  2. Make sure the paper type is appropriate for the project. Use HP Premium or HP Advanced Photo paper for the best results.
Solution two: Check estimated ink level Use the following steps to check the ink level.
  1. From HP Solution Center, click Settings , and then click Printer Toolbox . The toolbox appears. NOTE: The toolbox can also be opened from the Print Properties dialog box. In the Print Properties dialog box, select Printing Preferences , click the Features tab, and then click Printer Services .
Solution three: Check the print settings Use the following steps to check and adjust the print settings for the product.
  1. In the software program from which you are printing, click File , and then click Print .
  2. Make sure the product is selected from the drop-down list, and then click Properties or Preferences .
  3. Click the Features tab, and then select the print quality and paper type settings that match the print job.
  4. Click OK to accept the new settings.
  5. Click Print to send the print job.
Solution four: Check for defects using an extended self-test report Extended self-test reports identify specific print quality issues. Use an extended self-test report to determine what is causing the issue. Step one: Print an extended self-test report Use the following steps to print an extended self-test report.
  1. Press and hold the power button (c01346625.gif ), and then press Cancel .
  2. Release both buttons. The extended self-test report print
Jun 18, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer will not print after reinstall of software to macbook
yes ..if the sensor detect that there's is no ink or low ink..it display an error on the screen ..
to determine the status of the ink..
goto your desktop ..
click the printer driver software and select ink status..
good luck.
May 20, 2009 | HP Officejet 5610 All-In-One InkJet...
How much ink is left?
Tip: If you're printing invitations, you're going to use a lot of ink..get a spare set of ink.
No. There is no way to know how many more pages, because, if you think about it, printing a photo (or invitation), obviously uses far more ink than, say, a letter.
Apr 07, 2009 | HP Deskjet D4160 InkJet Photo Printer
First letter on line does not print
Check printhead possible missing pin or pin not firing. Replace as necessary.
Jan 14, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printer problem with 6210 all in one.
Try to print a self test page from the printer itself, do these:
  1. Press and hold the Cancel and the Color buttons at the same time.
  3. The Self Test Report will be printed.
and check if it is the same output, if yes then follow the steps below:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
  2. Verify that there is plain white paper in the Input tray.
  3. Press Setup .
  4. Press c00712200.gif or c00712201.gif to select Tools and then press OK .
  5. Press c00712200.gif or c00712201.gif to select Clean Print Cartridge and then press OK . The unit prints a test page.
  6. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  1. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  2. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
  3. Open HP Solution Center .
  4. Click Settings .
  5. Click Print Settings .
  6. Click Printer Toolbox .
  7. Click the Estimated Ink Levels tab
  • Replace any ink cartridge that is low on ink.
  • If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them.
  • With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
  • Allow the cartridges to dry before reinserting them.
  • Close the unit, and plug the power cord back in.
  • Print a self-test page to check the results. Follow the steps below to print a self-test page.
    1. Press Setup .
    2. Press c00712200.gif or c00712201.gif until Print Report displays and then press OK .
    3. Press c00712200.gif or c00712201.gif until Self-Test Report displays and then press OK . The self-test report prints.
    If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
    IF THE SELF TEST REPORT IS CLEAN, THEN TRY TO PRINT FROM ANOTHER SOFTWARE LIKE PAINT, NOTEPAD AND IF THE OUTPUT IS OK THEN THE PROBLEM IS ON THE SOFTWARE THAT YOU ARE USING
    Dec 19, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    18 people viewed this question
    jasbo
    jasbo
