Front load samsung washer will not drain, i cleaned the lines, replaced the pump, still will not drain
Cleaned the line and replaced the pump. pump will not turn on or pump. check pump with multi meter is ok.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
  • 1314 Answers
SOURCE: Washer-Kenmore front load belt drive model #417.40042990 (Won't final spin on any cycle.)
frigidaire did you get to the pump from the front or back
Posted on Jan 22, 2008
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
ginko
  • 19396 Answers
SOURCE: washer does not drain
ND error means no drain. When this happens it is usually a problem with the drain pump assembly, located under the bottom panel, inside the machine.
check the drain hose and the drain lines, ensure they are not obstructed. Probably the drain pump need replacement.
Posted on Oct 12, 2008
barkencoa
  • 3463 Answers
SOURCE: washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Posted on Jan 19, 2010
Testimonial: "I will tell repairman from Sears ( coming Friday ). i'll ask him to check brushes before he pulls motor. "
  • 662 Answers
SOURCE: Duet Sport Whirlpool front loading washer is
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
Samsung WF209ANW front load washer -- ND error code. I cleaned debris filter and all hoses, however it still will not drain. How can I tell if the drain pump needs to be replaced? Is there a diagnostic...
Hello & Welcome to FixYa
ND error in your Samsung Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Sep 25, 2011 | Samsung WF328AA Front Load Washer
My washer stopped in midcycle and posted the F2 error message. What does that mean? Thanks
You have something in the drain lines. Possibly a coin or other objects.
Here is what you need to do:
- Clean out the drain pump catch.
- Pull the suction boot off the drain pump, clean out any gook.
- Blow through the drain hose starting from the connection at the pump.
- Verify operation or replace the drain pump
Feb 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F2 message appearing on washer, what does that mean
Something clogging the pump or drain line. Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- If all else checks out, replace the pump.
This is how to clean the drain pump catchment: Remove the bottom front panel to see a white plastic catch basin with a removable-by-hand, large facing forward lid (peanut butter container sized) Remove it and clean out.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MY WHIRLPOOL DUET FRONTLOAD WASHER BEEPS AND CUTS OFF 2 MINUTES BEFORE CYCLE ENDS DISPLAYING F 02 CODE?
The F 02 error code is a long drain problem. It could be that there is something clogging the drain line or a kink in the line, the drain pump trap is clogged, something lodged in the drain pump or the drain pump not working properly.
Here is some info I found on this site to help me clean out the drain pump trap and to replace the drain pump if cleaning it out doesn't work for you.
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Aug 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water standing still in tub after load is done!
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Aug 04, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
LG front load washer has blocked drain line which is located in
take top off remove three srcews in back ..remove 4 screws hold control console ,,dont remove connection just flip console on top of drum,,make sure unit is unpluged..your looking at 4 screws across to panel remove them open door remove spring wire clip around the out sid bellows where almost there..now careful down in the filter acess panel remove the frist screw the filter cover comes off after the cover is out remove the pump filter housing screw..and last remove thebottom panel screw,,remov panel,,pump on left is drain pump..pump on right is recrulation pump
Dec 13, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer does not drain
Oct 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
