Question about Whirlpool Refrigerators
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
  • Whirlpool Master
  • 4,655 Answers
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Posted on Nov 30, 2012
5 Suggested Answers
  • 905 Answers
SOURCE: we have a 1996 mod.6162,ser.# 202380brbkb6, rv refridgerator
Hello Ron,
There might be a couple issues going on here.
First off, your flame sense is not working like it should. This is the electrode that partially sits in the burner flame. There is a wire that goes back to the ignitor module. Check it for continuity (electrode to connector), it should be near zero ohms. Also, check the screws on the burner housing assembly. These need to be tight and rust free because they secure the ground path for the ignitor. Make sure that your ground wires are clean and tight.
Given the history of the electric side, your power supply board may be on its way out as well. This can affect both modes (electric and gas, as well as 12volt cooling - but you are not equipped for that).
You can find a service manual at bryantrv.com. Look under the service manuals section, find the link for norcold 600
Posted on Jul 18, 2010
bobicehouse
  • 1524 Answers
SOURCE: I'm working on a Whirlpool
Drop me an e mail Bobicehouse58@yahoo.com I will send a diagram
Posted on May 01, 2011
  • 230 Answers
SOURCE: Where is the defrost timer in a GE GSS22JET
Defrost timer should be located at the back of the fridge at the bottom around the compresser, it is usually a little black box. Is the evaperator in the freezer iced up? If it is not, I would check the thermostat for proper operation or the compresser. If the compresser is very hot and not running, your compresser is on its way out, but if it is running and there is a hot line and cold line coming off of the compresser then I would say you have a plugged cap tube ( the metering device that gos into the evaperator in the freezer). In which case a repair man needs to cut about six inches off of it and re fill the refrigerant.
Posted on Sep 06, 2012
richroth
  • 9472 Answers
SOURCE: Door instalation for jenn-air mod. jrt236 refridgerator
Look at this.
Posted on Nov 03, 2012
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Whirlpool frig mod.no.g56shaxmq00-ser.no.sp3968169-frig stopped cooling-cleaned coils&unplugged-star-t.running-will run few hours-quit again-will unplug willstart again.please solve problem.MFG...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 06, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool mod. WFG361LVS 0 SER RW3911592 code : F5E2 on baker
This probably a problem with the wiring of the door lock assembly. Here is a list of Whirlpool error codes.
Mar 20, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
We have a 1996 mod.6162,ser.# 202380brbkb6, rv refridgerator
Hello Ron,
Jul 15, 2010 | Refrigerators
Diagram
ok i got it.
Please CLICK HERE and just browse the sub components and you'll get the wiring diagram..I have already selected your model in that
Jun 16, 2008 | Dryers
Whirlpool wm 1000 semi pro washing machine
if you can give a more complete mod # i can help you on the front loaders its a slow drain time the mod # you gave me dont come up look on the lid or the back of the control panel for ser plate http://www.whirlpool.com/custserv/index.jsp try here for manual
Dec 28, 2007 | Washing Machines
Refrigerators Logo
441 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
