The agitator on my GE washer barely moves back and forth. No force. Will not agitate clothes.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
  • 27 Answers
SOURCE: Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Posted on Nov 02, 2007
  • 20 Answers
SOURCE: Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Posted on Jan 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: ge toploading washer will not agitate
Simply pull up on it very hard.
It will come off.
Posted on Mar 15, 2009
SOURCE: GE Profile top load washer - Agitator rotates very slowly with li
Agitator coupling is worn out. Replace coupling underneath the agitator (WH43X10032)
Posted on Oct 14, 2009
FixinFax
  • 3085 Answers
SOURCE: GE washer model WJRE555OH1WW - agitator free-wheels.
You need a new agitator dog. Ask your appliance parts guys about it.
Pull off the softener body, remove the cap and remove the 7/16" nut and pull the agitator top off.
You might have to use some penetrating oil and a block of wood to tap the top half before it will come off.
Transmissions are pretty tough and usually don't break.
Posted on Oct 22, 2009
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
My washer works fine just no agition goes though cylces just fine fills and drians fine but agitator does not move
80040 dog kit is all you need. The upper portion of the agitator has four dogs mounted inside. As the transmission moves the agitator back and forth these dogs catch the side of the upper agitator. This rotates the fins and makes the clothes tumble on top of each other forcing them into a downward motion. When the facing of the agitator dogs wear smooth the upper agitator will cease to function.
Video:
I have a service manual and more videos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 10, 2011 | Kenmore 24032\24036 Top Load Washer
Everything on my GE washer works but the agitator.It barely moves.
New design to be gentler on clothing agitator moves 180 degrees 1 direction and then back 180 degrees
Feb 17, 2010 | GE WBSR3140DW Top Load Washer
Agitator not working properly; it barely moves back and forth and very slowly goes in a circle. The clothes are not pulled under the water as it agitates.
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded# Use this video attached to show how to replace the agitator dogs in top of the agitator.
Dec 02, 2009 | Kenmore Washing Machines
Agitator moving just a little.
If it is a Whirlpool or Kenmore make washer you probably stripped the "dog ears" in the agitator. They give you the duel agitation that makes your clothes cycle from top to bottom of the machine. Should only rin you around $8.00 or so. Hope that helps.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Does wash clothes
depending on what washer u have this could be a sign that your carbon brushes are on there last legs not much to replace them but need to know what make off washer it is hun peter
May 27, 2008 | Washing Machines
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
Jun 11, 2006 | Whirlpool LSQ7533JT Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
