Question about Brother SE-270D Computerized Sewing Machine
The rough piece under the foot on my sewing machineis not working
The piece under the foot is not moving
  • Brother Master
  • 1,564 Answers
Behind the machine by the sewing area is a slide switch for the feed dogs. Make sure it's in the "sew" position
Posted on Nov 30, 2012
Walking foot not walking.
Most people don't realize that the moving parts of a walking foot could use some periodic lube. Take the foot off and manipulate it with your fingers and see where metal parts move against metal parts and apply a small drop of good quality sewing machine oil or Tri-Flow Synthetic Lube (if you have it). Make sure to wipe off any excess oil and test it again on a piece of scrap fabric.
If oil doesn't help, it could be that the walking foot has been damaged.
Mar 06, 2017 | Sewing Machines
My janome 9000 won't sew forwards it just moves on spot
Make sure the stitch length is set higher than 2. Also make sure the feed dogs have not been inadvertently dropped for darning. If the feed dogs are up and moving back and forth, they are working okay but may have a lot of lint and dust inhibiting them from biting the fabric.
Are you sewing very fine or slick fabric? Frequently, that will cause the fabric to slip under the presser foot. Check your machine to see if you can adjust the pressure on the presser foot. If not, then try laying a piece of wax paper or vellum with the fabric. It can be easily removed after stitching.
Dec 11, 2015 | Janome Memory Craft 9000 Computerized...
How to set singer machine for strechy fabric
Hello, Most often if the machine sews fine on a regular material, cotton, denim, ect.....then the material...in this case "stretchy" is moving up and down with the needle...this is called "flagging" the material moves ever so slightly and this cause the hoop that the hook would pick up to be either not the right size or just a fraction out of line with the travel of the hook. On most industrial machines you can increase the presser foot pressure and cure it. From time to time the size of the hole in the middle of the presser foot can allow movement... so you might try applying a sturdy tape or material to the under side of the foot in order to reduce the hole side.
Hope this helps!!
Sep 02, 2014 | Singer Sewing Machines
How can I get my Bernina 750 to feed the top and bootom fabric pieces for quilts evenly
Try using a walking foot. The issue most quilters face when working with any sewing machine is that there is a force being applied to move the bottom fabric but the top fabric is only moving based on friction with the bottom fabric. This can cause the bottom fabric to move quicker than the top. A walking foot helps solve this issue by placing a second set of feed dogs on the top of the fabric to mirror the force being applied on the bottom, allowing both pieces of fabric to move evenly.
Hope that helps!
Jun 15, 2014 | Bernina Activa 140
The piece that looks like sharp metal under the foot dose not work
That is called your feed dog. Remove any embroidery attachments and check for a switch that allows you to lower the feed dogs. It should be on the back side of the machine directly behind the sewing area.
Another possibility is that you have it in bobbin winding mode.... but then your needle wouldn't work either.
Nov 30, 2012 | Brother SE-270D Computerized Sewing...
Cant embroider on toyota quiltmaster 50
The Quiltmaster 50 can only do free-hand embroidery. Use the darning foot. Set the machine for a satin stitch with a stitch length of 0 and lower the feed dogs. Manually move the hoop to stitch your design. (Trace the design on the fabric and place on a stabilizer if needed. Center the design in an embroidery hoop and move the hoop under the needle. In my limited experience, all fabrics need stabilizers. Some require multiple sheets of stabilizer.)
Personally, I have trouble moving any fabric under the pressure foot. This is mostly a matter of practice. You have to make a lot of scrap piece trials.
This site has the manual for the Quiltmaster 50 (European version): http://www.home-sewing.com/WebRoot/Store/Shops/homesewing/4AAF/95FA/5ED9/1505/56BA/4D44/240A/754B/QUILT50_0020_EFNI_0020__0020_679111-CEA10.pdf . See page 37 (49 of the PDF).
I hope this helps.
(who actually cheats: I either use an embroidery sewing machine or I use a late 1960s Singer Sewing machine with its Monogramming accessory. This has pre-programmed designs on little discs. That's why I don't practice free-hand stitching.)
Jun 15, 2012 | Sewing Machines
Thread keeps breaking, Silk Fabric bunching u[
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
Most machines can use generic Schmetz needles. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric. make sure the correct needle for silk is being used.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
also clean under the needle plate & in the bobbin area for lint or loose
threads
check to make sure the feed dogs are completely in the up position
if none of these suggestions work then it's possible that the machine
is out of time & would have to retimed at a sewing machine shop
Apr 15, 2012 | Necchi 4595 Mechanical Sewing Machine
I have a Kenmore 14 stitch sewing machine that I haven't used in years - when I try to use it, the thread and bobbin thread seems to catch and it won't sew forward
take out the thread and bobbin. run the machine with the pressure foot up and watch the feed dogs (toothy things under the pressure foot that move the material through the machine). if they are not rising up above the plate, then you are sewing multiple stitches in one place and that's what spools up the threads. take the plate over the feed dogs off (it just pops up). get someone to remove the two screws holding the feed dog on (it's a torx #10). the piece the feed dogs was screwed to rides up and down on a short piece of polished rod under it. the rod has gummed up to its bearing. bright light, look for this and get some oil (3in1) on the rod above the bearing and force the feed dog mount up and down until it frees up.
Nov 29, 2009 | Kenmore 744-08BH Mechanical Sewing Machine
Parts fell out
WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
Apr 18, 2008 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
