Phone number for whirlpool customer servicr please
Machine has completely stopped & technician says it cannot be fixed?? & I wish to speak to whirlpool direct before taking the matter further. & I can not find a contact No for whirlpool direct
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
US: 1-866-698-2538
Canada: 1-800-688-2002
Hour of Operation:
Monday-Friday: 8:00 AM to 8:00 PM EST
Posted on Nov 30, 2012
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Top Loader Stopped working mid-cycle & rattling
It sounds like you have a broken motor coupling. If you manually advance the dial does it drain? The washer is a direct drive model that uses an electric drive motor to run the gearcase (transmission) and the drain pump. Even with the coupler broken (and worse-case scenario - the gearcase) the washer will still drain due to the way it is designed.
If the washer will fill and drain, but won't agitate or spin, this is usually a sign that the motor coupling has broken. The noise of the motor engaging, rattling noises, lack of agitation and ability to still drain are other common symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If you confirmed that the washer will not drain, you could have a pump that has something caught in it. The drain on these washers on have one moving part - the impeller. If something gets caught in it, the pump will not drain. You can access the pump by following this link:
http://www.fixya.com/support/r397094-replacing_water_pump
Use the steps in the link provided to access the drain pump and remove the hoses to check inside the pump for any foreign objects (underwires from bras, undergarments and panty hose are common items). If the wash tub is still full of water an easy way to drain it with no mess is to use a wet/dry shop vac to pull the water from the tub. Simple gravity works too by removing one of the drain hoses, but is not recommended if the washer is in your home. These wash tubs have a 35 gallon capacity. If you have no shop vac and cannot risk allowing the washer to drain by pulling one of the drain hoses, you need to bail.
If the pump is defective, the part number is 3363892 and can be purchased at appliancepartspros.com for about $42.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Sep 14, 2009
Testimonial: "Thanks! No it will not drain either. It just stopped when it hit the drain for the rinse cycle & started that terrible noise. "
SOURCE: Whirlpool WTW6600SW1 washing machine problem. The
Whirlpool WTW6600SW / WTW6600SG / WTW6600SB Top ... Whirlpool WTW6600SW1 washing machine problem. The machine starts, then beeps and stops. It flashes F1. Technician... - posted in Washing Machines
Posted on Aug 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: my machine is missing the techinician data guide.
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(((())))
Posted on Sep 28, 2010
  • 1044 Answers
SOURCE: I've got a Whirlpool Washing
There is no Service center in Nasik but you can contact the Whirlpool Customer center on your Land line by dialing 1-860-180-4558
Posted on Oct 04, 2010
Testimonial: "thank you for your valuable reply.. is there any alternative number in case i dont have a Landline."
SOURCE: My FP-65 whitemagic washing is
my FP 65 is not working Technician said electronic controling unit should replaced how can I buy it can i buy it through e-bay
Posted on Dec 15, 2010
How do I complete Facebook in windows?
To speak Microsoft Customer Support representative dial +1 (800) 204-4427 (U.S.) 6 Am to 6 Am, (24*7 hours) Pacific Time, Monday through Sunday. If you needs a technical diagnosis you can call on our Microsoft technical support team 1-800- 204-4427, which is especially open round-the-clock for online assistance.
Our highly trained and experienced technicians have deep knowledge in fixing different types of all type technical problems and have extremely high success rate in troubleshooting. To use our reliable tech support services, please call our toll-free Tech Support Number at +1-800-204-4427.
Apr 26, 2017 | Facebook Computers & Internet
Whirlpool HE front loading washer,
We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 03, 2017 | Whirlpool Washing Machines
Rew new my account
MagicJack Customer Phone Number Shortest Wait Best Support
  • Phone Number
    561-594-9925
  • Talk to a Human
    You get a recording, but do get to speak to an actual person. For billing matters only.
  • Useful tools &
    numbers to call
    Compare all options
  • Call Time
    Average Wait: 14 mins - Mon-Sat: 10am-7pm EST
  • For better help
    This may be the best phone number, but it's the #3 way overall to contact MagicJack, as recommended by other customers. Compare all options
  • Did this phone number work? Yes No Update this, please
    Help force companies to improve customer service. How
Feb 16, 2015 | magicJack pc to phone, free local & long...
Remove front plastic control panel of my Whirlpool duet dryer
Remove knobs and screws and then you should be able to pop it off
Nov 23, 2014 | Whirlpool Washing Machines
I have a fault code, NTC open call for service, on my whirlpool microwve WMH1163xvs. What to do?
Whirlpool Customer Phone Number Shortest Wait Best Support
Nov 20, 2014 | Whirlpool Microwave Ovens
Cant get my irulu to work with magic app
Nov 02, 2014 | Irulu 10.1 inch Android 4.0 Touchscreen...
I need to block a mobile number.
Wlcome to FixYa
Do Following:
  • Determine the number that you wish to block. If it's a harassing call, write down the number that appears on your caller ID. If the number is coming from an automated system, you may need to call the owner of the institution responsible for the calls, and have it corrected.
  • Call your cellular provider's Customer service department. This phone number can be found on the provider's website.
  • Avoid the automated system by continually pressing zero. With a representative on the phone, identify yourself, your account, your phone number and provide any password information if instructed. Explain your request to the representative, emphasizing the speed with which you need your request filled. Offer your phone number and the phone number you wish to block on your account. Obtain the representative's name, title and extension.
  • Contact your cellular provider's technical support department immediately after speaking with the customer service representative. This number can also be found on the provider's website. While a customer service representative may have already handled the problem, technical support can verify its completion. Provide the customer service representative's pertinent information to clarify and expedite the tech support's search. Ask if your request has been handled, technically-speaking. Obtain the tech support representative's name, title and extension.
  • Wait 24 to 48 hours. If the phone calls continue from the blocked number, contact customer service. Immediately ask to speak with a supervisor or manager. Explain to the superior your unresolved issue, provide the names and extensions of the previous representatives, and wait on the line until the number is successfully blocked. Again, ask to be transferred to technical support to verify the correction. If the problem continues, repeat until it is resolved.
So you need Assistance of Network Provider to Block...Hope you got an Idea...If this Helped you-Vote Me..Thanks for Contacting FixYa....
Jun 23, 2010 | HP iPAQ 510 Voice Messenger Smartphone
I have a Whirlpool washer model WTW5300SQ0, which had not been yused for about 3 months. It will fill with water but not go into any cycle. After filling with water, the area of the cycle selector will...
Gkdodd, We are sorry to hear about your Washer not starting a cycle. We are not technicians, we do not have technical training, or technicians here in customer service. We can offer troubleshooting. Unfortunately, we do not have the provisions to assist you with detailed technical advice, provide repair manuals, tell you how to take it apart, or advise on which parts need to be changed to repair the unit. We do not offer repair assistance in customer service. If you are unable to resolve an issue on your own, we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 09, 2017 | Whirlpool Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
