Question about Acer At110 F2-E3-1220 E3 1220 1P
How do i install windows 2003 standard, to my new Acer AT110 F2? on Acer smart cd there's no option for 2003 server :(
  • 922 Answers
I just checked the specs and it supports Windows Server 2003 so it must be possible. They probably did not make a setup wizard for it so you will have to do it the "old fashioned" way. Load the Windows Server 2003 disk in the CD/DVD drive and boot to it as you would any Windows install. If it reaches the screen where it displays the hard disk(s) you are good to go. While the installation is running go to Acer's website on another computer and download the 2003 drivers to a USB drive. When the installation completes, install the 2003 drivers and you are ready to customize it to your needs.
If it doesn't find the hard disks, you probably purchased the optional PCIe 4-port SAS RAID card and Windows 2003 doesn't have a built-in driver for it. You will need to press F6 after Windows install starts so it will prompt you later for a driver for your disk controller. This will allow you to manually install the driver which you should be able to find on Acer's website. (F6 Info: http://en.wikipedia.org/wiki/F6_disk)
I hope this helps!
Posted on Mar 06, 2013
Hi guies the windows srever 2003 files in my hp ml370 is corrupt and i tried to fix the prblem by format one hard disk partition in my scasi disks array and installing win srv 2003 on it but whe i log on...
HP SmartStart CD x32
The utility to use to set up the ML370 g3 server is the SSCD (smart start cd) this is a guided installation cd that will help you set up the array, install drivers and diagnostic utilities and after that
will request the windows cd so that you can finish the installation.
instructions:
1. download SSCD from here
2. extract the zip file
3. burn the ISO image to a cd
4. boot the server to the cd
5. choose from the main menu the option "Deploy server"
6. follow the wizard
Oct 26, 2010 | HP Compaq ProLiant ML370 G3 Server
I want to install windows 2003 on compaq proliant ML350 G3,but I have not a disk called server guide.please help me.
1. turn the server on, when you see the smart array controller posting
hit f8 to enter the controller settings, here create the array (1, 5,0)
2. insert the windows cd and follow the normal installation procedure
or download the smart start cd from here for a guided installation
with SSCD just insert the cd and follow the directions
Aug 30, 2010 | HP Compaq ProLiant ML350 G3 Server
I need to install windows server 2003 (standard edition) on a HP Proliant ML110 G4 server but I do not have the easy setup CD (smart start CD) and it would not have me install directly from the OS...
here is the download link for the easy set up cd, this is for the ml110 g5, however it is backward compatible so it should work in the ml110 g4
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15351&prodSeriesId=3577708&prodNameId=3577715&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-d35cfe8601c74a4d89ea6a06bc
Jul 31, 2010 | HP Compaq ProLiant ML110 G4 Server
Hp ml350g4 p server hang on diagonestic screen, unable to set standard boot order(ilo)
To repair your installation of Windows, follow these steps:
1. Insert the Windows Server 2003 CD in the CD-ROM or DVD-ROM drive.
2. If the Windows CD displays the What would you like to do? menu, click Exit.
3. Turn off your computer, wait ten seconds, and then turn your computer back on.
4. If you are prompted to start your computer from the CD, do so.
Note You must be able to start your computer from the Windows Server 2003 CD-ROM to run Windows Setup. Your CD-ROM or DVD-ROM drive must be configured to do so. For information about how to configure your computer to start from the CD-ROM or DVD-ROM drive, see the documentation that is included with your computer, or contact your computer manufacturer.
5. After Setup starts, press ENTER to continue the setup process.
6. Press ENTER to select the option To set up Windows now, press ENTER. Do not select the Recovery Console option.
7. Press F8 to accept the licensing agreement.
Setup searches for previous installations of Windows.
* If Setup does not find a previous installation of Windows Server 2003, you might have a hardware failure.
Hardware failures are beyond the scope of this article. See a computer hardware specialist for more help or try the Hardware troubleshooter. For more information about the Hardware Troubleshooter, see the Windows Server 2003 Help topic "Using Troubleshooters."
* If Setup does find a previous installation of Windows Server 2003, you may receive the following message:
If one of the following Windows Server 2003 installations is damaged, setup can try to repair it. Use the up and down arrows to select an installation. To repair the selected installation, press R. To continue without repairing, press ESC.
Select the appropriate Windows Server 2003 operating system installation, and then press R to try to repair it.
* Follow the on-screen instructions to repair the installation.
Notes
o You might have to change the boot drive sequence in your BIOS settings to successfully start your computer from the Windows Server 2003 CD. Contact the manufacturer of your computer, or see your manufacturer's documentation, for more information.
o If you cannot start your computer from the Windows Server 2003 CD, you might have a CD-ROM or DVD-ROM drive failure or other hardware failure.
o After you repair your Windows Server 2003, you may be required to reactivate your copy of Windows Server 2003.
Jan 22, 2010 | HP Compaq ProLiant ML110 G4 Server
Unable to install Audio driver in Intel DG31PRI board for Windows 2003 server.
You can’t install DG31PRI board sound driver automatically it install manually
Go to cd room drive right click and open your main board driver cd
Then find sound driver then install sound driver manually. Click twice then
Next –next-finish.
Bibekpaul@in.com(india)
Apr 29, 2009 | Microsoft Windows Server 2003 Standard...
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
Step by step installing of windows server 2003 & its application features.
Windows Server 2003 installation is very much like the standard Windows installation, except you will be prompted with services options.
Depends on what you need - view guides here.
Dec 07, 2008 | Microsoft Windows Server Standard 2003 for...
Server 2003 sp1 not installing
Plz be posted , in case of server installation - it is veryu delicate the above situation may occur only for the following points .
1.intallation files were skipped by user manually (due to bad CD)
2.Improper Installation (in case root directory contained XP os and installation was overridden windows folder )
3.using a crack patch to OS for CD-KEY.
check and let us know.
Regards,
Sushil
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Acer At110 F2-E3-1220 E3 1220 1P Logo
200 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
