Question about Garden
PULLEY FOR RIDING MOWER BLADE IS CAUGHT ON SOME NYLON ROPE AND APPEARS TO BE FROZEN
I want to free up the pulley and take off the blade to clear all of the nylon threads away and remove them
  • 8,404 Answers
Remove the blade, the pulley should free up so you can clean it.
Posted on Nov 30, 2012
mowerman1857
  • 389 Answers
SOURCE: The mower deck drive belt slipped off the idler
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Posted on Sep 30, 2009
mickey813
  • 472 Answers
SOURCE: Riding Mower Variable Speed Pulley Locked Up. How to remove belts
ya it can be freed up with some W-D40 if you pah the cluch down then try to get the belt off i can get you a new pulley let me know
Posted on Oct 15, 2009
  • 78 Answers
SOURCE: I changed the blade mandrel from my 42 inch cut
Ok Go to partdirect on the Sears website. Enter the 917. xxxxx number that will bring up the drawings and should show you were the spring goes. As for the lock nut its 9/16-18 .You should have gotten a new locknut with the new mandrel.
GOOD LUCK
MIKE
Posted on Oct 22, 2009
  • 146 Answers
SOURCE: MTD 42" CUT MOWER MODEL 42A707 TYPE 1238 01
I think either the bolt holding the left blade onto the spindle is loose, or the cup washers under that bolt are flattened or missing. As a result, the blade is slipping on the shaft and probably making a squeal or squawk. Take off the deck, flip it over, and remove the blades. Note if the bolts seem tight. And look at the washers stacked under the bolts. Replace any missing washers, or flattened cup washer. Make sure the cup washer faces the right way (hollow side toward the blade). Tighten things back up securely - it takes a hefty pull on the end of a 2 foot long wrench to get enough torque.
Posted on Jun 18, 2010
  • 5370 Answers
SOURCE: Need a belt diagram for
So as per your explanation, it indicates that , your mower has 6 pulleys.------ 1 motor driven pulley,3 blade pulleys and 2 accessory pulleys.That in total comes to 6.So for belt routing diagram for Murray 46" 6 pulley.Click this link below and see the belt routing diagram:---
http://technoanswers.blogspot.com/2011/09/belt-routing-diagram-for-murray-pro-16.html ----------- this will help.thanks.Helpmech.
Posted on Sep 05, 2011
Stalls when mower deck is engaged
Try turning your blades by hand & feel for binding. Inspect the underside of your deck & look for wire, rope, or twine wrapped around the blade spindles. A piece of wood can get wedged between a blade and the deck. Check the pulley shields for grass & debris.
If everything is clear, then clean your carburetor's air filter & clean the float & needle valve/seat; your carburetor may not be getting enough gas.
Mar 08, 2016 | Garden
Tip
Replacing Riding Lawnmower Blade Belts.
I discovered on a Craftman Riding 3 bladed mower that there is an easy way to replace the belt for the blade pulleys.
The mandrel cover of the Left side blade is the only part you need to remove to replace the belt. You can insert the belt under the right side mandrel cover and onto the clutch pulley before finishing on the left side of the mower.
The tensioner or idler pulleys will contract when you pull on the belt. When you get to the left blade pulley you can turn the pulley with one hand and guide the belt with the other hand. The belt will walk right up onto the pulley. Attach the cover and you're done.
I like my method because you can stay away from a hot engine and replace the belt without waiting for the motor to cool off. You are also not fighting the mower clutch or drivebelt with my method.
on Dec 16, 2010 | Garden
I replaed the blade drive mandrel and reattacheed the blade and the blade does not freelyturn t is so bound up tht I cannot turnit manually
okay check see if brakes is on the mower, not the tractor but the blades of the mower deck if not then take belt off of the new mandrel side and try turning blade by hand. should turn freely if not mandrel is bad but unlikely. sounds like you changed wrong side mandrel I presume you have 2 blades and mandrels. or when you installed it back on. the belt may be bound up between a guide and pulley just kind of look things over before a tear apart. and then do your tear apart one step at a time then check blade to see if it turns does not seem serious you may have put belt on wrong, I have done it my self. hope this helps major note do not do this with engine running cut you hand off in a flash.
Aug 13, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Grinding noise in mowing deck when engaged
the bearings in one of the blade houseing r going out
Jul 01, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ignition/no spark on ford GT85 riding mower with a kohler M18QS gas engine. I need the electrical schematics for diagnostics.
follow this steps and fix it. GOD BLESS YOU
If grass is poorly or unevenly cut, try mowing at a slower speed and adjusting the engine speed with instructions in your owner's manual. Scrape away any dried grass and other debris caked under the mower deck. Sharpen or replace dull or bent blades 0fbc95da-10ce-4268-a804-bcc52ffe7dcf.jpg. Check and replace a worn belt.
If the V-belt slips or comes off during use, clear any debris in the belt area, adjust the drive-belt tension (see below), or have the belt replaced. Adjust and tighten pulley fasteners or have a service center replace worn parts.
If the belt squeals or wears excessively, adjust the drive-belt tension (see below) and look for obstructions around the belt. If that doesn't work, take the mower in for professional service.
If the mower vibrates excessively when the clutch is engaged, scrape away any debris accumulated under the deck. Balance the blade and replace the blade if needed. If that fails, adjust drive-belt tension (see below). If you find that the drive belt, pulley, or other belt-drive part is damaged, consider having it replaced by a professional.
If the mower is hard to shift or doesn't move when the clutch is engaged, adjust the drive-belt tension (see below). Also make sure the mower is lubricated according to the owner's manual specifications. As needed, have the mower serviced for damaged or maladjusted clutch/brake pedal linkage.
If the engine doesn't start, loses power, or dies during use.
Replace a recoil starter rope:
  1. Disconnect the spark plug cable for safety.
  2. Disengage the throttle cable from the housing and remove the housing as needed to access the starter.
  3. Remove the handle from the rope, which is often held in place by a knot or retainer pin.
  4. Unfasten the other end of the rope from the starter using pliers or a cutter as needed.
  5. Knot the end of the replacement rope.
  6. Tighten the pulley counterclockwise all the way, then back it off two turns and hold it firmly.
  7. Thread the unknotted rope end through the pulley hole.
  8. Thread the rope through the housing hole and pull it taut.
  9. Slowly release the pulley, allowing the rope to wind around the pulley.
  10. Attach the handle and reassemble as needed.
  11. Reconnect the spark plug cable.
Replace a recoil starter spring:
  2. Remove the housing and the spring cover.
  3. Carefully remove the rope from the pulley to release spring tension.
  4. Remove and replace the spring as recommended by the manufacturer.
  5. Reinstall the pulley, rope, and housing following the instructions above.
  6. Reconnect the spark plug cable.
Nov 12, 2013 | Garden
When I put the power take-off lever to the on position, the mower deck belt smokes and it appears that the right hand blade wouldn,t move
You need to remove the belt driving the blades and check to see if the bearings in the blade pulleys are not frozen which I suspect is your problem. If you find a pulley is frozen then remove the mower deck from the mower so it will be easier to access and remove the pulleys.
May 14, 2011 | Garden
I own a craftsman LT 2000 17 HP it has worked well and as a rule I am pleased however recently I changed my blades and encountered a problem in that the laft bade turns slower than the right the result is...
Hi and welcome to FixYa, I am Kelly.
You assessment of the problem is pretty much on the mark. Here is what you should do to check the bearing.
1. Remove the belt from the suspect deck pulley
2. Reach under and try and teeter the blade by gripping the end of the blade and lifting it up and down. (None allowed but compare it to the good blade) Watch both the under side of the mower deck for movement and the upper side pulley of the mower deck for movement.
3. Spin the blade by hand and feel the blade bearing upper housing as it spins You should NOT feel any rumbles, strange vibration or odd noises as the blade is rotated.
4. Wrap a nylon rope around the drive pulley like a starter recoil tightly, tie it off and try and rotate the blade. Reverse your nylon rope wrapping direction and do this again. If the blade moved and the pulley does not move most likely the shaft key in the blade adapter has sheared or is missing. (You can try this test with the belt on....also vs using a rope. I find that I still have to tie the belt together to keep is from rotating.)
By doing this you are going to identify the problem.
Thanks for choosing FixYa,
Kelly
Apr 13, 2011 | Craftsman Garden
I have a Craftsman LT riding lawnmower and for some reason the one of the blades is a very loud noise. I have tried going under the deck and tighten up the bolt that holds it in place but it still making...
Check for foreign objects caught under the deck, as well as for a bent blade. If that's not the problem, look at the mower deck belt - is it burnt or worn in a spot? Take it off, and see if you can turn the blade spindles and idler pulley freely. If they scrape badly or are frozen in place, that's the problem.
Jun 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an older mtd yard machine that throws the belt whenever the engine is started. It appears that the belt is very tight the blades turn free when the belt is not connected so they are not locked up....
I had an MTD riding mower, when the mower started the belt should not have been engaging the blade spindle. They're is a clutch lever which goes down to a simple spring tensioner which engages the blade. You may have the tensioner misaligned which will allow the belt to be desheaved. My old manual told me to hold a straight edge along the engine pulley and the driven pulley, like on a table saw. There should be some deflection in the belt, 1/2" over two feet.
Apr 28, 2009 | Garden
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
