Question about Sewing Machines
Why isn't my sewing foot moving
My brother sewing machine se270d the foot is not moving like it should
  • Sewing Machines Master
  • 1,564 Answers
Good grief... lol how many times are you going to ask? Your feed dogs are disengaged.... or you have it in bobbin winding mode.
Posted on Nov 30, 2012
SOURCE: BOBBIN THREAD
omyGod!! Thank you sooo much!!! I changed the tension on the top of the machine, like you said and now, it is working beautifully, God bless You!!!
sandylou
Posted on Dec 08, 2007
rizla
  • 1463 Answers
SOURCE: I need instrutions on how
hi hrkids
will anything thing here be of help XL-2600/2600i/2610:
riz.
Posted on Apr 21, 2008
  • 33 Answers
SOURCE: i have a Brother LS 15 sewing machine
raise presser foot to highest level pulling wheel toward you(counterclockwise) release the foot assembly with the lever at the back of the foot holder assembly place you quilting foot in line with the slot on the shank lower the presser foot lever on the shank if it is where it should be the bar will snap in and you should hear an audiable click or snap let me know if this helps
thanks amy
Posted on Sep 05, 2008
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
  • 76 Answers
SOURCE: brothers sewing machine ls 1520
I hope this is your machine, check it out
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_1520_EN_270.PDF
ACCESSORIES
1 Buttonhole foot (1 pc.)
2 Zipper foot (1 pc.)
3 Button sewing Foot (1 pc.)
4 Needle set (regular single needle No. 14) (3 pcs.)
5 Twin needle (1 pc.)
6 Bobbins (3 pcs.)
7 Darning plate (1 pc.)
8 Screwdriver (1 pc.)
9 Extra spool pin (1 pc.)
Parts code for zigzag presser foot: 138135-051
Foot controller: X57319-051 (110/120V Area)
XA6422-021 (220/240V Area)
XA6412-021 (U.K.)
XA6414-021 (Australia, New Zealand)
The above accessories are stored in the accessory bag inside the
extension table. These accessories have been designed to help
complete most sewing tasks.
Posted on Aug 28, 2009
Take cover off of Brother SE270D
Note--computerized machines are usually made so the covers are difficult to remove because the computer components can be easily damaged. You should probably take the machine for service.
Have you tried adjusting the presser foot pressure? Usually, increasing the pressure will resolve the issue when the feed dogs don't seem to be working properly.
Jan 02, 2018 | Brother Sewing Machines
Disney brother se270d running really slow. Do I need a new power cord or foot pedal?
Most machines have a variable speed lever or button...did you hit it by accident.?
Dec 02, 2016 | Brother Sewing Machines
I have a Brother SE270D and my top thread won't pick up my bobbin thread
Replace the needle with a Schmetz needle. If that doesn't work you need to get it serviced
Feb 21, 2014 | Brother 98-Stitch Computerized Sewing &...
Cannot adjust tension
Using the thread tension dial on the left side of the machine you can adjust the upper tension.If i; doesn't work properly see if there's a thread that stuck.Buy a brother sewing machine
Sep 22, 2012 | Brother Sewing Machines
Why isn't the needle moving on my sewing machine?
Did you wind a bobbin recently? If so please return the machine to sewing mode
Aug 06, 2012 | Brother LS-2125 Mechanical Sewing Machine
VX808/Vx809. When put pressure on foot control stop motion contro doesn't move.
I would suggest that the machine needs to be serviced to find out why it not responding the way it should.
Mar 22, 2012 | Brother Sewing Machines
Why when i put the feed cover on i cant move the fabrice at all there is no room between the foot and the cover. i am trying to quilt together my quilts. thank you brenda g
I'm assuming your machine has a little plate you put over the feed dogs rather than a knob which disengages the feed dogs from moving to do free motion embroidery or something.
If this is the case there probably isn't enough room for your quilt sandwich under the foot.
You could try using a free motion embroidery foot rather than the regular foot with the feed dogs up and see if that allows you sufficient movement.
It would look like this:
It may take some practice still to get a smooth stipple if that is the effect you are going for.
You may find some other ideas on quilting websites to get around this problem or in a Yahoo group for quilters. I've only ever quilted in straight stitch using my walking foot so it feeds the quilt smoothly for me, never tried FMQ.
Oct 24, 2011 | Brother XL-5130 Mechanical Sewing Machine
F01 trouble code when turning on my brother SE270D sewing machine
Do you have your manual? If, not just google brother.com and download one for free, also you can call Brother at 1-877-276-8437. Good luck
Jul 19, 2010 | Brother SE-270D Computerized Sewing...
Need timing instruction for brother SE270d
Your needle thread lock on the bottom of your fabric and your bobbin thread locks on top. If you are getting jamming in the bobbin it is caused by the needle thread. Thread your machine with the presser foot up this will ensure thread going between tension disks.
Oct 14, 2008 | Brother SE-270D Computerized Sewing...
Brother SE270D
there is also a single screw on the bottom of the machine as well as one behind the bobbin winder, the last 'hidden" one is on the back side of the machine behind what woudl be the reverse button.
Jan 12, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
