Question about Teac CD-Rewritable W216E CD-RW Burner
Windows xp does not rrecognize
In my hardware list i have a yellow question mark. Windows cannot initialize the device driver for this hardware. (Code 37) de-instaled and re-installed nothing.
    President:
  • 2,961 Answers
Run REGEDIT, open up the following folders: HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325 -11CE-BFC1-08002BE10318} After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side: "Upperfilters" "Lowerfilters" Click on each of them, press DELETE and click YES. Hopefully the hardware should be recognised
Posted on Jun 06, 2007
Webcam e239136
1st You download Webcam Driver.
Webcam Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Ezonics Camera Drivers for Windows XP Vista Windows 7
Dec 13, 2013 | Ezonics Computers & Internet
Tip
How to check if your system needs drivers
WINDOWS XP
Goto Start > Run > type "devmgmt.msc " without quotes and hit the enter key. You will get Device Manager opened. Now see if you see any yellow exclamation mark. If you see yellow icon that means the current drivers are corrupted or the drivers are not installed.
To fix the issue use windows update site and install all the hardware updates.
WINDOWS VISTA & WINDOWS 7
Goto Start > In Search type "device manager " without quotes. > Now locate device manager and open it. Now see if you see any yellow exclamation mark. If you see yellow iconthat means the current drivers are corrupted or the drivers are notinstalled.
To fix the issue goto control panel and open widows updates and install all the hardware updates for your system.
on Dec 08, 2009 | Computers & Internet
What is PCI bus, device 16 function 1 Code 28
While I do not know exactly what would cause your computer to display that code, I can safely assume that you are using a pci sound card if you are getting a pci error, and your sound is not working. In short, yes, the pci problem is almost definitely related to your sound problem.
Sep 14, 2009 | Microsoft Windows XP Professional
I dont know what driver to download after re-installing winows xp
Helena,
General installs of a new windows system come with generic driver to most standard hardware devices.
if you can however, be more specific i can help you further.
AndystUK
Sep 02, 2009 | Computers & Internet
I have installed Windows XP on my PC. However, after initializing the PC, I have found that there is no sound coming & an error is encountered while Bad DirectSound Driver, please install proper...
so, you should install your sound driver  follow the step below to reinstall it.
start/ right click my computer/ choose Properties in system properties, choose Hardware tab. Click Device Manager check if there's yellow question mark in it. If so, that's where the driver perform not normal. Delete it, and restart your windows to reinstall that driver.
May 14, 2009 | Computers & Internet
Sound problem
Hi thr,
If u r runnin Windows XP, Go to control panel. click on system->hardware->Device Manager n check to see if the sound drivers r installed properly. If the lists shows a yellow exclamation mark on PCI DEVICE, It means u need to install microsoft universal audio articeture drivers first. u can search for it on yahoo or any other searchengine to get the link. download and install microsoft uaa drivers, Uninstall the PCI device from device manager and re-install the audio drivers. I hope it works this way. Thank u
Nov 06, 2008 | Compaq Presario 700 470024-192 Notebook
Installing windows xp on hp pavilion dv 6516 tx
I'm not sure solution #1 is very explanatory, so....
IF you want to install XP on your computer, Windows XP will load most of the drivers you need automatically.
For the drivers that are specific to your HP pavilion
you will be able to download device drivers from HP website
or, request a driver CD
When XP is installed [assuming you or someone can do that]
you can:
Go to the 'My Computer' icon [right-click]
Choose:
  • 'Properties'
  • Then Choose 'Hardware'
  • Finally, choose 'Device Manager'
Here you will have a list of all your hardware
If you have any drivers that need to be installed, there should be
a yellow (?) question mark by the name of the hardware
Most devices/hardware will be handled by XP SP2
The default drivers will be loaded automatically
For example, your keyboard:
Above you see the window that opens if I double-click on
the 'Keyboard' icon.
For XP to function, you only have to worry about the ones
with the yellow (?) question mark
Or, if you want to add a specific driver, like a Video or Sound driver, but you don't see a yellow (?) question mark
you can still install/update the driver at the 'driver' tab
[second tab in the picture above]
If you need more specific help I can do that too
Feb 20, 2008 | Microsoft Windows XP Professional With...
Display drivers
look in control panel , system, hardware,device manager. see any yellow question marks? remove all of them, reboot and windows will find your hardware again the display driver cd it will ask for it. or if lucky pick it from a list.
Aug 17, 2007 | Microsoft Windows XP Professional With...
Teac CD-Rewritable W216E CD-RW Burner Logo
82 people viewed this question
Top Teac Computers & Internet Experts
k24674
Argospete
Argospete
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
