Question about Proform 695 LT Treadmill
Calibrare distance i believe that when the unit reads that i have ran a mile its really only about 3/4 of a mile is there a way to calibrate the unit?
    Top Expert:
  • Proform Master
  • 12,223 Answers
Yes go to under the HOOD motor, and follow the steps for software calibration.
otherwise go to the instr.manual and see the steps and proceed according.
If you do not have the instr. manual go to
www.fitness.manualsonline.com
God bless you
Posted on Nov 30, 2012
You run from your friends house that is 3 miles away.You then walk home. What distance did you trave
You travel the distance between the friend's house and your home which is stated to be 3 miles.
Nov 05, 2015 | Cars & Trucks
What do I have to do to get proper depth readings on my hummingbird 561. Instead of reading 4ft it reads 08
read the user manual as to how to calibrate the unit
remember that it reads the distance from the sender unit to the sea bed/river bed and not from the display unit
May 28, 2015 | Hummingbird Boating
Calibrar tps sensor
The TPS is self-calibrating once it is plugged in. Remove one battery cable to clear any codes from the Quest and then put it back on after 1 minute. The TPS should work fine after.
Mar 12, 2014 | 1999 Nissan Quest
How do you calibrate a laser distance meter?
Calibrating a laser distance meter is not all that complicated. eHow.com has a really good guide. How to Calibrate Laser Distance Meter eHow
Jan 22, 2014 | Measuring Tools & Sensors
I have a ranging 100 i need the manual for
I just got one complete with manual and original box. It was not working, so I disassembled it and repaired the internal mechanism and recalibrated it for distance and vertical image coincidence.
Disassembly is easy (two screws at front and rear) and the "repair" for mine was to lubricate two pads that the mechanism rests on that were "sticky." I removed the mechanism, but that is not required -- just manual manipulation of the distancing arm should be sufficient to expose the lubrication points. Do not use 3-in-One or similar oil -- that thickens with time. Lacking the "proper" oil type (watch maker's), I would use a small drop of motor oil.
Calibration is simple -- use an object with a known distance that is about half the range of your unit. Adjust the "focus" knob to make the two images coincide (don't worry about vertical coincidence yet). Hold the thinner of the two distance adjuster knobs and turn the thicker one until the tape displaying the distance reads the actual distance to the known object. I would then adjust the image coincidence vertically by turning the screw on the bottom of the unit on the right (near the loop for a lanyard). It will be stiff! Turn it about a quarter of a turn and recheck vertical image coincidence -- if worse, turn it back the other direction a half-turn. Repeat with small turn increments until the images coincide vertically. Once that is done, recheck the distance calibration.
Dec 21, 2010 | Ranging 400 Rangefinder
Incorrect distance tracked on Garmin Forerunner 405
Could it be that the Unit for distance is set to statute and so displaying miles instead of K?
May 31, 2009 | Garmin Forerunner 405 010-00658-20
Need to know how to operate a Ranging 600. Thanks, Sam
Go to; www.konus.com, they are the maker of this rangefinder, or call them in Miami,Fl. at; 1'305-592-5500, they should be able to assist you with a Owners Manual.
Good luck. :)
Mar 29, 2009 | Ranging Optics
Ranging inc. model 50 rangefinder
I have one still in the box with manual. Do you still need one?
Oct 26, 2008 | Ranging 400 Rangefinder
Proform 695 LT Treadmill Logo
64 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
