Question about Brother Sewing Machines
What is the clutch on my sewing machine - Brother Sewing Machines
  • Brother Master
  • 1,564 Answers
The clutch engages and disengages the sewing parts/needles/feed dogs, etc for when you want to wind a bobbin.
Posted on Nov 30, 2012
The clutch will not release in order to fill a bobbin. Past owners have been directed to remove the clutch knob. How do you remove the clutch knob?
Hi Victor, In general all sewing machines have the same basic design. So, if you take hold of the big 'wheel' on the right of the machine with your left hand and take hold of the knob in the centre of the wheel with your right hand you should be able to turn the knob anticlockwise. That's the cluch disengaged. You should now be able to fill a bobbin. Don't forget to engage the clutch before sewing (just reverse the process).
Jul 16, 2015 | Brother Sewing Machines
Disengage clutch kenmore sewing machine
http://www.shopyourway.com/manuals/9253 is the manual. Turn the center of the handwheel knob toward to you to disengage the clutch.
Dec 26, 2013 | Kenmore Sewing Machines
My singer 20U73 sewing machine has a reliable motor, the light is blinking green and it won't sew. Can someone please help me?
Do you know if your Reliable brand motor is a Clutch or Servo motor? I suspect that if it is a clutch motor ... the safety clutch has been tripped.
Dec 05, 2012 | Sewing Machines
Singer quantum xl-600 bobbin case spinning
sounds to me like you need a professional cleaning and timing adjustment.
Jul 09, 2012 | Singer Quantum XL-6000 Computerized Sewing...
I have a New Home xr-vii sewing machine, the balance wheel is very hard to turn. The repair shop I took it to said the clutch needed to be adjusted. Got it back 8 months later and it still has the s
if the sewing machine repair shop knew the machine needed a clutch
adjustment, then why didn't they fix it. or if they said they did & it's not
fixed, I'd call them & ask them why the machine is still doing the same
as it did?
May 03, 2012 | Sewing Machines
Clutch won't release
the machine needs to be serviced by a sewing machine repair shop
Jan 25, 2012 | Kenmore Sewing Machines
I have a kenmore sewing machine model #385.1249180. I cannot disengage the clutch knob from the hand wheel when I spin my bobbins, therefore the needle moves up and down as the bobbins spins thread. Do You...
Usually when you pull the clutch knob out it disengages the sewing machine needle shaft. At least, that is how my 2 Kenmore's work. You can always take your machine into Sears sewing department and ask the sewing machine salespeople for help, they are really helpful in my area and more than happy to help you for free. Good luck
Dec 23, 2010 | Sewing Machines
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
118 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
