Question about PressurePro Pressure-Pro Home Owner 2500 PSI Pressure Washer
What type of oil to use in pressure pro 2500 - PressurePro Pressure-Pro Home Owner 2500 PSI Pressure Washer
    Sergeant:
  • 402 Answers
Engine 10w30 hd pump is 30w non detergent
Posted on Dec 30, 2014
Why is oil leaking from air cleaner?
this is usually due to an oil overfill situation. You most likely added the full quart of oil into the crankcase on setting it up without checking the actual oil level periodically as you fill it. Recheck and drain out the excess as needed.
Jul 14, 2014 | Briggs & Stratton 020324 3700 PSI Pro...
Will a faulty oil pressure sensor shut the truck down/2007 dodge ram 2500 5.7 hemi
Yes,here it is.http://www.autozone.com/autozone/parts/Duralast-Oil-Pressure-Switch/2007-Dodge-RAM-2500-3-4-ton-2WD/_/N-jq7tpZ8znc6?itemIdentifier=715966_0_8537_
Nov 17, 2012 | Dodge Ram 2500 Cars & Trucks
What type of fuel is to be used? oil/gas mixed? pls advise
Check to see whether 4 stroke is written on engine. If this is the case, regular gas can be used.
Feb 19, 2011 | Karcher 2500 PSI Pressure Washer
What type of oil is needed for a Honda GC160 Power Washer? Honda 2500 PSI x 2.3 GPM.
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
May 27, 2010 | Honda Pressure Washer PSI 3000
2001 dodge ram 2500 v10 oil pressure drops to 0 then back up
you need to put an oil pressure gauge on it and see what happens.what you will find is that the sender unit is no good.
May 18, 2010 | 2001 Dodge Ram 2500 Truck
Engine knock hard over 2500 rpm
Does the oil light come on or the knock occur during the engine warm up after a cold start?
There could be a couple of problems causing the issue. You could have an oil pressure pump or pump pressure regulator sticking. I would have a mechanical oil pressure gauge installed and verify oil pressure at idle and 2500 rpms to make sure oil pressure is in normal ranges.
You could also have excessive piston rod bearing, crankshaft bearing or cam shaft bearing wear that will cause oil pressure to drop too low to prevent the rod knock your hearing at 2500 rpm.
You said a knock and not a ticking noise,so I don't believe a lifter is the issue at 2500 rpm.
Start with the oil pressure check and go from there.
Let me know.
Regards,
Aug 22, 2009 | 1996 Dodge Stratus
I have a Honda 2004 CRV - the repair ( OBD II) code is P2647 - what does that mean?
P2647 VTEC Oil Pressure Switch Circuit High Voltage - With Automatic Transmission Basicallly the sensor has gone bad or an oil passage has become blocked.
**. Locate the Variable Timing Electronic Control (VTEC) pressure switch on the end of the cylinder head. Honda has had problems with the VTEC oil pressure switch, there is an updated part number for the vehicle (37250-PNE-G01). On this vehicle the VTEC oil pressure switch can fail at any RPM.
2. The VTEC oil switch is normally closed, and grounds the reference voltage from the Engine Control Module (ECM) on the Blue/Black (BLU/BLK) wire. If the code sets at idle - 2500 RPM - and the Brown/Yellow wire has a good ground, then suspect a faulty VTEC oil pressure switch.
3. At approximately 2500-4000 RPM and when driving the vehicle, the VTEC system should turn on. To turn on the system, the ECM energizes the VTEC Solenoid valve and it allows oil pressure into the intake valve rocker arms, the oil pressure opens the VTEC oil pressure switch so the Engine Control Module (ECM) can verify that the VTEC did turn on correctly.
4. The code will set at idle to 2500 RPM if the reference voltage is not grounded. The code will set above 2500-4000 RPM if the VTEC oil switch does not open.
5. If the code sets at 2500-4000 RPM or higher, the problem can be a low oil level or pressure, or a malfunction in the VTEC assembly.
Potential Causes: Low Engine Oil
Plugged Oil Passage
Insufficient Oil Pressure
Plugged Oil Screen
Insufficient Oil Volume
Malfunctioning VTEC Oil Pressure Switch
Defective VTEC Solenoid
Jul 13, 2009 | 2004 Honda CR-V
Need to know what type of oil is to be used in a pump assembly for a karcher G 2600 ph
Hello:
10W30 oil but make sure it is NON DETERGENT. Also be sure the reservoir is only 1/3 to 1/2 full
Jun 30, 2009 | Karcher 2500 PSI Pressure Washer
KARCHER K210
If your discussing the crankcase, you can use regular non detergent SAE 30 wt. Do not use the new types of oil as they have additives that may cause harm to the engine.
Mar 16, 2008 | Karcher 2500 PSI Pressure Washer
PressurePro Pressure-Pro Home Owner 2500 PSI Pressure Washer Logo
141 people viewed this question
Top PressurePro Garden Experts
Dennis Key
Dennis Key
john h
Are you a PressurePro Garden Expert? Answer questions, earn points and help others
