It wont shut off with the power button the door will not unlock
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
1995 ford futura doors wont lock
Inside the door is an electric motor that pulls the door lock down to the locked position, either the rod has come off to the door latch from the door lock motor or the motor has failed. Remove the door panel and check it for power when the button is pressed for the power locks, if it gets power then it is most likely the motor that is the problem.
Nov 01, 2012 | Cars & Trucks
I have a 2007 Toyota Corolla type S. My problem is that when I press the unlock button on my remote the doors unlock and the lights flash however when you open the door the alarm sounds. It has been...
This sounds like a bad alarm module, the doors unlock but the alarm doesnt shut down, so it wont let you start it because its not shutting down, the light flash and door unlock put starter disable and horn stay active, most good alarms have liftime module warranties, if you take it back to who installed it and ask them or if it was already in the car when you bought it then you will need to disable or replace it. hope this helps, also to disable it just trun key on then open a open try key off and within 10 sec push the button under the dash its a small red button this will put it in vallet mode.
Nov 10, 2010 | 2003 Toyota Corolla
1993 Nissan Altima The security light is blinking and the car wont turn over. it has a good battery. Is the flashing security light preventing the car from turning over?
Yes, the security system shuts power to the starter and fuel pump. You can try disarming by unlocking and locking the doors the power door locks switch (depends on model). Place the key in the ignition and set to ON, ALL doors closed!! Cycle the locks using the power locks button on the driver's door "lock" then "unlock" if this doesnt work, try same method with the ignition OFF. Otherwise your security system is malf.
Sep 26, 2010 | 1993 Nissan Altima
Car alarm went off while unlocking the door, now
you need to reset alarm/immobiliser.lock car with remote, hold button down for 30 secs,then press/hold down unlock button,should reset.another way is with key in ignition/turned on, press alarm button down and hold for 30 secs.this resets immobiliser.toyota
systems vary..depending on market.
Mar 30, 2010 | 1991 Lexus LS 400
My alarm wont turn off. my car wont start. its a 2004 tiburon.
With alarm activated your ignition is disabled.Find the combination to disable it.With GM's you hold opposing buttons on the fob till it beeps twice. The dealer should help for no charge.
Feb 28, 2010 | 2004 Hyundai Tiburon
My power door locks lock but not unlock the doors
first thing to check is the wireharness under the passengers floor mat,you wiil probably find a mass of corrosion and bad connections,been there done that!
Jul 29, 2009 | 2002 Chevrolet Venture Passanger
Drivers door power lock wont work.
Either the wring going to that motor or the motor itself is bad.
Mar 08, 2009 | 2000 Toyota 4Runner
Control lock is on but door opens it finished the cycle but the control lock wont shut off can you help thanks
Try some WD40 spray on the door
lock; on machine, not on door. And open & close for a few times with the power off.
Apr 13, 2008 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
