Question about KitchenAid Kitchen Ranges
How do you install a kitchenaid filler strip in the rear of the slide in range when the filler strip isn't wide enough to fasten to the side of the cabinets
2 Suggested Answers
  • 111 Answers
SOURCE: new ge908 slide-in range
The 30" is the widest you can get. I suggest getting a piece of stainless steel and having a metal shop cut and smooth the edges
Posted on Dec 20, 2008
Once we leveled our Electrolux slide in gas range, using it's feet, it created a gap between the left side and the countertop. Is there a filler (removable when necessary) we could use for th
Thank you for your post, Wendy Berg!
I understand that you are searching for a filler piece to go between your Electrolux range and countertop. I was unable to locate any type of filler piece I see the manufacture has a side trim kit, rear filler panel, and backguard kit but nothing specific to your request. I hope this information is helpful. -Matt
Sep 27, 2014 | Electrolux EI30GS55LW | 30" Slide-in Gas...
How do i remove rear fender on night rod special
To remove a 2011 VRSCDX rear fender FIRST remove the main fuse under the right side cover first, then remove the tail light open the seat, remove the seat pillion, remove the fasteners and the passenger pillion, remove the electrical caddy and the six fasteners and the washers from the fender, remove the fender from the inner fender by lifting upward and sliding the fender back, remove the inner fender by removing the rear shocks and fasteners.
To install a 2011 VRSCDX rear fender FIRST install the inner fender and fasteners, tighten the fasteners to 95-110 Nm (75-81 ft-lbs), install the rear shocks using shock mount fasteners and tighten the fasteners to 41-68 Nm (31-50 ft-lbs), install the rear fender by sliding it into the slot on the tail lamp panel and aligning the fender with the bolt holes on the inner fender, install the six fender fasteners and tighten them to 4.5-7.5Nm (40-66 in-lbs), install the tail lamp, install the passenger pillion and its fasteners. And tighten them to 20-26 Nm (15-19 ft-lbs), install the main fuse, install the right side cover and ensure that the headlamp, tail lights and stop lamp and turn signals are operating properly.
Jun 04, 2014 | 2011 Harley Davidson VRSCDX Night Rod...
I have a kitchenaid side by side refrigerator model #KSSC42MFS05 and the freezer isn't getting cold enough to freeze ice cream and the ice maker isn't working.
Look at the rear wall of the freezer for a layer of frost building on the outside of that panel. If yes the refrigerator may be missing defrost. That would explain why the feezer temperatures are warming. If the ice maker is above 5 degrees F it will not be able to make ice. Things to check are the=> 2162044 Defrost Timer
The=> 2000631 Defrost Heater
and the=> 4387499 Defrost Thermostat
I would like you to locate the defrost timer and turn the center with a flathead screwdriver slowly clockwise until compressor and fans turn off. Leave like this up to 30 minutes. This will cause the defrost to begin. If timer does not restart the compressor an fans after 30 minutes simply turn the timer again slowly clockwise until the compressor and fans restart. If the timer need to be turned like this then this would indicate that the defrost timer is defective and will need replaced. Let me know if you have questions Thanks Sea Breeze
Sep 25, 2012 | KitchenAid Refrigerators
How to replace igniter on kitchenaid slide-in gas range
Awesome igniter install vidoe by matt matt:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 22, 2012 | Kitchen Ranges
How to remove rider seat 2011 dyna wideglide
Hi Anonymous, seat removal can range from the simple and obvious to the complex and baffling for the novice new Harley Davidson owner. Seems like the more expensive the bike is the harder it is to remove the seat. So let's start with the most expensive. 99% of all Harley seats have a male tounge in the front that slides into a female reciever that is either bolted or welded to the frame just behind the fuel tank. For this reason when ever you are removing a seat you must always slide it backwards 3-5 inches. Next they may may have a bolt on each side usually under a flap on the seat. Then there is the seat strap that is secured on both sides, only one side needs to be removed. A single phillips head bolt can secure it to the rear fender or it may have a bracket with two studs secured by nuts or knobs to fasten the rear portion of the seat. On newer model short seats there may be a "T" stud that locks in the rear portion of the seat just a few inches in front of the rear seat bolt, you have to push forward and lift up after you remove the bolt. If you have a pillion pad or passenger seat that snugs up against the front seat there can be a bolt securing the two to the rear fender, you have to get your hand in between the two seats and force seperation of seat material to see and gain acess to the bolt. Finally there is the rear seat bolt in the back that is the caboose of seat fasteners, usually a large chrome bracket, that screws into the rear fender. Care must be exercised in covering this shinny bauble with your hand during the sliding back procedure so as to NOT scratch the tour pak. So when all the hidden and mysterious fasteners have been removed, it's lift up in the rear, slide backwards a few inches and bingo you have mastered the impossible. Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 24, 2012 | 2011 Harley Davidson FXDWG Dyna Wide Glide
I need a diagram to replace a fuel tank on a 1987 vw cabriolet
1987 Volkswagen Cabriolet 1.8L FI SOHC 4cyl
1985-89 Scirocco and Cabriolet
  1. Disconnect the negative battery cable and drain the fuel tank.
  2. Remove the rear right wheel housing cover.
  3. Disconnect the large breather hose from the filler neck.
  4. Pull the gravity valve down leaving the hoses connected.
  5. Unbolt the fuel pump bracket from the body and lower the pump.
  6. Remove the fuel tank screw.
  7. Disconnect the fuel pump hose and pull the blue hose from the return line.
  8. Disconnect the brake hoses from both sides of the rear axle and plug them.
  9. Disconnect the rear axle from both sides of the body and allow it to swing down and rest on the handbrake cable guides.
  10. Unhook the rear muffler support lugs.
  11. Disconnect the filler hose from the tank.
  12. Support the tank, remove the tank fasteners and lower the tank enough to disconnect the fuel gauge sending unit wires and breather hoses.
  13. Remove the fuel tank.
To install:
If installing a new or used tank, make note of where the old foam strips were installed, and install new foam strips on the replacement tank in the same locations.
  1. Raise and support tank. Connect the small breather hoses and fuel gauge sending unit wires. Install the tank fasteners.
When connecting the breather hoses, position the hose clips so that they do not make contact with the body.
  1. Connect the filler hose to the tank and connect the rear muffler support lugs.
  2. Raise the rear axle off the handbrake cable guides and install.
  3. Connect the brake hoses and bleed the brakes.
  4. Connect the return line and fuel pump hose.
  5. Install the fuel tank screw.
  6. Raise the fuel pump and attach the fuel pump bracket to the body.
  7. Put the gravity valve back into its original (raised) position.
  8. Connect the large breather hose to the filler neck.
When connecting the breather hose, position the hose clip so that it does not make contact with the body.
  1. Install the right rear wheel housing cover.
  2. Fill the tank and connect the negative battery cable.
Fig. 1: Fuel tank assembly used on the Rabbit Pick-up. Other models are similar
Hope helps (remember to rate and comment this).
Sep 21, 2010 | Volkswagen Cabriolet Cars & Trucks
I am trying to remove my fuel tank from a 96 chevy suburban and replace the fuel pump
ok i'm going to guess that you have a gasoline engine with a side tank like in a pickup truck. if you have a diesel let me know, things might be a little different. here's the step by step for a gas side tank. before you start, disconnect the battery negative cable.
1. drain the fuel from the tank (they don't tell you how, just get as much out as you can)
2.raise and safely support vehicle (get it high enough that you can get under it to work on it)
3.loosen the fuel neck hose at fuel neck and disconnect filler neck from tank
4.support tank and remove tank support straps and insulator strips
5.remove frame mounted bracket
6.lower fuel tank shield
7.lower fuel tank enough to gain access to fuel and electrical connections
8.disconnect fuel feed and vapor hoses
9.disconnect electrical connectors
10.remove fuel sender assembly and seal ring
now to install new tank
1.install NEW seal ring and install sender
2.raise tank enough to connect fuel feed /vapor hoses and electrical connector
3.raise tank fully
4.install fuel tank shield
5.connect fuel tank filler neck and tighten clamp
CAUTION tighten fuel strap fasteners in steps, alternating between straps, until proper torque is reached. failure to properly follow this step can cause bottom of tank to deform. fuel gauge may read improper level if this occurs
6.install fuel tank brackets and insulator strips
torque nuts to 115 in-lbs
7.install fuel tank filler cap
8.connect battery negative cable
9.turn ignition switch off and on and check for leaks
it's pretty much the same for rear tank, just different location, may have off-road shield in back and torque spec is 47 ft-lbs, not 115 in-lbs. you still have to alternate when you torque straps or you risk deforming tank. hope that helps
May 29, 2009 | 1996 Chevrolet Suburban
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
New ge908 slide-in range
Dec 20, 2008 | GE Profile 30" Slide-In Gas Range -...
Filler Panel
do you have the instalation and conversion instructions if not you can get them here if need futher help contack me http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KGRS807SSS&siteCd=KAD
Jul 22, 2008 | KitchenAid KGRS807SSS Gas Kitchen Range
Kitchen Ranges Logo
408 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
