Image is cropped from the HDMI input
This is the line form the computer...blog after blog says turn off the overscan, but for the life of me I can't find an overscan toggle in any of the menus. help?
5 Suggested Answers
  • 476 Answers
SOURCE: magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Posted on Feb 12, 2008
meztang
  • 112 Answers
SOURCE: Hp plasma ID5226N can get external audio input
DVI cables are usually HDMI compatible. The downside is that DVI usually doesn't carry any audio. Your computer may need a specific audio card to transmit audio/video data from your DVI output to the HDMI input on the TV. You can find one at your local computer store and ask if it is compatible with your computer
I hope this helps...good luck
Posted on Jul 18, 2010
gopakumarg43
  • 74468 Answers
SOURCE: I have an Onkyo HT-S9100THX
Hello
Without moving to a hard reset as you described, reset it by the following method, and try the rest.
To reset the AV receiver to its factory defaults,
turn it on and, while holding down the [VCR/DVR]
button, press the [ON/STANDBY] button. "Clear"
will appear on the display and the AV receiver will
enter Standby mode.
Note that resetting the AV receiver will delete your
radio presets and custom settings.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected
to the composite video or S-Video MONITOR OUT,
or the COMPONENT VIDEO OUT, use the AV
receiver's own display when changing settings.
OK
Posted on Jan 19, 2011
unders306
  • 20 Answers
SOURCE: HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Posted on Aug 02, 2012
Testimonial: "Don't know how I never considered that the PS3 output settings would have been the problem. I was so fixated on the TV settings that I completely overlooked the PS3 setup! That was outstanding advice!"
How do I enter the service menu on an Emerson EWF2004 CRT Television? (Pictures of the OVERSCAN ISSUE will be provided if needed.)
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Feb 25, 2016 | Emerson EWF2004 20" TV
White stripe on screen
Unfortunately it seems that each time I turn the tv on and off it resets the screen position and I have to adjust it each time.
I would assume that my set would remember the settings.
Use Picture Size, not Picture fit. Set it to 16:9, instead of Fit To Screen. There's a handy button the the remote for this: P-Size. And the setting sticks between shut-offs.
What you are seeing is called "overscan", extra information that most broadcast stations send, because most old TV's were set to zoom-in/crop the signal they received. So.. with new TVs, like your Samsung, you get the choice between size "Fit to Screen" which is 1-to-1, for pixel-accurate inputs like Blu-Ray and DVD, and size "16:9" which is really "support for overscan", for old, less precise signals like broadcast.
Mustang Parts.
May 28, 2012 | Samsung Televison & Video
Vchip rest. Inputs won't show HDMI
Make sure you have a good hdmi cable, and make sure you have a signal. Try another HDMI slot, and see if that helps. If nothing works, unplug the HDMI inputs and turn the set off overnight. Then plug each HDMI plug in one at at time, and turn the device on. This helped in a couple of instances I know of.
Since I don't know the model you have, the following blog may or may not be helpful to you:
http://forums.logitech.com/t5/Harmony-Remotes/JVC-TV-input-problem/td-p/241569
Good luck, and hope this helps.
Apr 07, 2011 | JVC Televison & Video
Screen is not in digital mode for display it is in analog mode. we have a 64 bit computer from HP
Has it got a HDMI cable in it or the "standard" cable?? If you buy the HDMI cable (Provided the PC has the same port) it will auto view in Dig mode.
Like this one
http://zedomax.com/blog/wp-content/uploads/2008/09/dvi.jpg
or standard like this
http://www.varologic.com/blog/images/Gold_VGA_Monitor_Cable.jpg
Mar 12, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Insignia 22'' LED HDTV screen resolution problem with VGA
This is more of an alternative than a solution... but I solved my problem by getting a dvi to hdmi adapter and connecting to my mac desktop via hdmi. Once I then turned off the overscan in the menu I got a perfect 1080p image. Hope this helps. :-)
Dec 20, 2009 | Insignia Televison & Video
Words on screen can be seen
In the picture there is a check box labeled "overscan"
Uncheck it.
If that doesn't work... What input are you using? This can also happen with the incorrect DVI or HDMI to M1-D adapter. If you are using the M1-D computer input try using the composite input. If you are using the computer with a computer source try changing to the external monitor screen resolution or aspect ratio.
Cheers
Apr 22, 2009 | InFocus X1 Multimedia Projector
Just bought at Panasonic TH-50PZ80U Plasma. On some channels we are getting a static type line across the top. Black and White. Any suggestions on how to get rid of it?
have you checked in the tv menu settings. check that overscan is turned on,as this will slightly zoom in to crop the error out. hope this helps!
Dec 02, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Magnavox 37MF337B/37 overscan only sometimes problem
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
