This Samsung doesn't work because the temp is flashing red while lamp flashes green continuously.
  • 85 Answers
Possible lamp issue
Posted on Nov 30, 2012
SOURCE: Power Led Flashing red 6 times....
the thermocoupler fuse is what it is called by the way. i also saw that it could be the "power board" which could or could not be synonymous with the thermocoupler. anyway, again it is a common problem with these models. Scott Jackson, MS
Posted on Jan 26, 2007
  • 231 Answers
SOURCE: Lamp light flashes red
if lamp LED is blinking then replace lamp ..
Posted on Nov 30, 2007
rlamkin
  • 44 Answers
SOURCE: Samsung
Replace the lamp - they only last about 2 years with 4 hours use per day.
Posted on Jul 03, 2008
  • 184 Answers
SOURCE: 13 red flashes on lamp indicator.
Take the lamp out and examine it. Look for deformities in the thin glass tube that runs down the center of the bulb. Don't overlook the obvious. Most failures in TVs that employ a mercury vapor lamp to make a picture are in the lamps.
michtech
Posted on Feb 13, 2009
  • 8457 Answers
SOURCE: last night and today, screen goes black, and both
How did this guy become a Guru and a Sony Expert there no lamp in LCD tv,only in projection tv have lamp.Ur main video backlight board is dead,must be replaced.
Posted on Oct 19, 2009
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Samsung dlp HLN437w (GREEN lamp and RED temp)-same time flashing. lamp and housing has already been replaced whats next?
If the Ballast board is not working Lamp will not come on,if the Lamp Fan is defective Lamp will not Light or stay on.
Go to Encompass Parts Distribution and Look up your Model#
they have free service manual for this TV.
Dec 28, 2010 | Samsung Televison & Video
Picture won't come on. light flashes green continually, after 3 or 4 minutes the light flashes red continually. bulb is less than 6 months old. any ideas?
Hi:
This model was notorious for fan failure. The most common failure was the lamp temp fan. Its use to keep the lamp a constant temp. Also if one of the fans fail the unit will not start, This model is also known for Ballast failure also. The ballast is use to light the lamp. The best thing you can do is have a service technician come out and diagnostic the set for a minium fee.
Nov 09, 2010 | Panasonic PT-50LC14 50" Rear Projection...
KDS-R60XBR1 no sound no picture continuous green flashing a pause 6 green flashes then continuous red flashes from the lamp indicator. Is it the lamp or something else?
It is lamp that is dead/ broken, replace lamp to get back tv in working.
Lamp replacement procedure is written in user manual and its easy.
Thanks.
May 11, 2010 | Televison & Video
2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
Sep 21, 2009 | Samsung Televison & Video
Have replaced Lamp and still does same thing.
I replaced the ballast, a solution not even mentioned by the 3 Experts I was referred to.
May 14, 2009 | Samsung HLR6178W 61" HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
