Question about Panasonic 55 TCP55ST30 551 3D HDTV Plasma TV
Panasonic plasma tv tc-p55st30, no power, no screen; number of blinks is 14. please diagnose
TV is 18 months old. past the 1 yr. std. warranty.
SOURCE: 42" panasonic viesta plasma tv cuts off after about 30 minutes
Adjust the automatic shut off settings on the set using the menu system. the newer models are programmed to shut down to avoid the burn-in problem associated w/ plasma scenes.
Posted on Dec 30, 2008
JomasTech
  • 66 Answers
SOURCE: I bought my plasma tv over 1 year ago but only set
it's a defect. we call it red blinking death. the boards inside the tv has gone bad.
Posted on Oct 17, 2009
gopakumarg43
  • 74473 Answers
SOURCE: PANASONIC PLASMA TC-P50C2 The tv
Hello
Your TV is in warranty period I thinks. If so, company is liable and will repair it free fo charge. There is "repair,replace, refund gurantees. Your gurantee card and broshure will tell you that. Look at it.
For what you are going to take the risk.
Posted on Mar 24, 2011
  • 100 Answers
SOURCE: plasma tv dead; 7 blinks of red light on a
there is a loose solder on the parts..check on it..
Posted on Mar 31, 2011
sodeep
  • 3267 Answers
SOURCE: I have a Panasonic Model TC-P50S1 plasma TV and
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
Posted on May 28, 2011
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
I have a panasonic viera TC-P55st30.It popped and now nothing can turn it on or off, other than unplugging.I replaced A main&P board.To no avail. It powers up and when i hit power button, 14 blinks.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 22, 2015 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Panasonic TC-P55ST30 had 14 blinks. I followed the shop Jimmy testing video and there were no shorts. The next step was to power on and push button and if light flashes you need an Aboard if it's so
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jan 21, 2015 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Panasonic Plasma TV, Model #TC-P42S30 ourchased in May, 2011 stuck in shutdown mode with 14 blinks
My nook won't show the picture I just have the sound what would cause this?
Jan 07, 2014 | Televison & Video
Panasonic TC-P55ST30 red light blinks 7 times next to the on/off switch please diagnose, no power
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link
Dec 06, 2013 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic TC-p55st30. no power, no screen; number of blinks is 7 , please diagnose
Dec 06, 2013 | Panasonic 55 TCP55ST30 551 3D HDTV Plasma...
Panasonic Viera TC-P46S30 14 blinks
14 blinks won't occur to Panasonic Plamas. Just count the number of blinks once more.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Blinking codes for Panasonic Plasmas are described in detail. Search the site with patience. You will get a solution.
Nov 11, 2012 | Panasonic 46 TCP46S30 Plasma TV
Oct 17, 2009 | Panasonic TH-50PX75U Plasma HDTV
Panasonic 55 TCP55ST30 551 3D HDTV Plasma TV Logo
290 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
