HOW MANY COST TO REPAIR SCREEN LCD TV SAMSUNG 52 IN
  • 933 Answers
You cannot repair but only replace the screen. A 52" replacement screen will cost you just as much if not more than a new 52" LCD. Is the screen cracked?
Posted on Nov 30, 2012
dsacco86
  • 1077 Answers
SOURCE: I have a cracked Panel that I would like to repair
Can't repair cracked panels. Only replace panels.
Not sure which TV model you have.
Here's a couple of models:
Model - 52SE94U, panel part# R1LK520D3LZ70Z.
http://www.partstore.com/GetModel.aspx?MfgName=Sharp&BrandName=Sharp&ModelNumber=LC52SE94U&ModelAliasNumber=52se94u&Page=1&SortBy=price&SortDirection=desc#PartsearchSKUList
Model - 52D82U, panel part# R1LK520D3LZ2CZ.
http://www.partstore.com/GetModel.aspx?MfgName=Sharp&BrandName=Sharp&ModelNumber=LC52D82U&ModelAliasNumber=52d82u&Page=1&SortBy=price&SortDirection=desc#PartsearchSKUList
Well, you get the idea that the part cost over $3,500. It's just cheaper and better to get a new TV at that point.
Posted on Jun 28, 2009
  • 191 Answers
SOURCE: lcd tv repair
hi best option is to change the screen
Posted on Sep 21, 2008
  • 610 Answers
SOURCE: my samsung lcd tv wont switch on the on off switch
the power supply board has failed. call 1-800-samsung for nearest service center. I think the part is around $120.00.
Posted on Nov 20, 2009
  • 610 Answers
SOURCE: Samsung 52 inch LCD - no turn on just clicking
most likely the power supply board has failed, but it could be the main board as well. call 1-800-samsung for nearest service center.
Posted on Nov 25, 2009
Testimonial: "I open the TV (Samsung 52" lcd full HD) up. I noticed 2 1000uf 10v caps has expanded at the top. I replaced the 2 caps (77pence each). TV now work."
SOURCE: 52" Samsung LCD will not turn on. Blue light is on
I had that problem--POWER SUPPLY. IT COST ME $300 to put in the fix kit, and now 27 days later, my screen is bad. it has verticle lines on the right side of the picture. the tech said it is a bad panel so go buy another tv!
Posted on Dec 29, 2009
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Cost repair screen for a nec multisync lcd5220
It will cost around 2/3rd of the total cost of a new TV; including panel price + service charges.
Gopakumar Gopalan Google
Mar 27, 2014 | NEC MultiSync LCD5220-IT 52 in. LCD TV
Samsung 52 inch LNT5265F has clicking sounds when I turn TV on. It takes about 5 minutes for TV to finally turn on. When it does turn on, it has various spots on the screen. I have to turn it off and...
This sounds similar to a known problem with bad capacitors in some Samsung TVs. Even though the TV is out of warranty, Samsung extend the repair period for affected TVs. Get your TV model and serial number off the back and then call Samsung at: 1-800-Samsung (1-800-726-7864).
Explain the problem and let them know that you have heard about similar problems and heard they were being repaired out of warranty. In my case, they sent a tech out and did the repair for free.
If for some reason they will not do it, the repair is quite simple for someone who can solder and you can find details here: http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
Aug 28, 2011 | Samsung LNT5265F 52 in. LCD HDTV
I have a 52" Toshiba
in general cracked lcd panels cost more than the tv is worth.. depending on model panel replacment run 1500 to 2000.. and physical damage is not a warrenty item. do you have a toshiba or a rca the decription says you have rca r52wm24 which is not a lcd. that is a tube tv. and if it is cracked that definatly can be fix or replaced cost effective.
Oct 27, 2010 | RCA R52WM24 52" HDTV Projection Television
Can the flat screen tv is fixed when soneone
No,the LCD screen panel are broken right?The LCD screen are 90% of the tv,will cost the same as a new tv to do the replacement of the LCD screen.Now the tv,not worth as a whole tv anymore.Tv only can be salvage for electronic boards only now.
Jun 25, 2010 | Samsung 52 in. LCD Flat-Panel HDTV
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Cost to repair an LCD tv screen
In today's electronics devices there isn't much to repair specially if the screen is damage. The cost of the repair might exceed the price of the LCD. A cheaper way to get it fix is to try to find a defective LCD(same model) with intact screen.
Sep 28, 2009 | RCA P52960 52" Rear Projection Television
Have you ssen the back light lit up? If not, the power supply may have problem. If it has back light, then the suspection are the main board, T-con and inverter. Those boards need checked to find out exact defective board.
Aug 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Left side of 52 inch Samsung flat screen tv is cracked,
You need to buy a new TV. Even if the screen is the only issue, it will cost more to repair it than to buy a new one, and it will take months since screens are in very short supply. Check with your homeowners insurance, it may be covered since i'm sure it was an accident and that's what insurance is for. Sorry.
May 23, 2009 | Samsung LN52A850 52 in. LCD HDTV
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
Electro Med Services...
