Question about Acer Aspire 5100 Notebook
How do I darken my screen pc - Acer Aspire 5100 Notebook
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
There should be a key with a light emblem with arrow up and down. May neede to press function or alt key with it/
Posted on Nov 30, 2012
Screen won't brighten
On Battery or Plugged in? You didn't post the OS you are using, Open the Power Options, set to High Performance, open Change Plan settings, Adjust to your preference, Change Advanced settings to your preference.
Mar 11, 2013 | Computers & Internet
Gateway laptop screen darkens after boot up
Have you updated a Graphic driver? Does it Dim on battery and AC? Look at power settings. Control Panel, Power. You could Rool-Back the graphic driver to see if that changes the problem. A Gateway mt6841 has Windows XP OS, right?
Nov 27, 2012 | Gateway MT6841 15.4 WXGA SHINY LCD SCREEN
LOOKING FOR A REPLACEMENT SCREEN
Darken the screen and either move the lid forward or backwards. Laptops have Liquid Crystal Screens and moving the lid backwards or forward will give the screen a different look.
If you need to adjust the brightness of the screen it is controlled by keys on your laptop. Most times to darken the screen you will have to hit the FN, CTRL or ALT key and hold it down while you hit the key that corresponds to the screen darken key. On some computers (even on my laptop) it will be the down arrow key, so i would press FN+the down arrow key. Remember to hold the first key down while you hit the next key. The icon used for most times to denote the brightness or darkness looks like a circular sun or a washer that goes on screws.
Mar 22, 2012 | Computers & Internet
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
How do I darken my computer on the Dell Inspiron 1525
Hold the "FUNCTION" key down and tap the LEFT ARROW key to darken, tap RIGHT ARROW key to lighten the screen.
Good Luck
Jan 06, 2011 | Dell Inspiron 1525 Laptop Computer PC...
Toshiba satellite p35-s609 screen darken.
It is almost certainly the LCD inverter which is the cause of your issue. It ism ore common for the inverter to develop a fault than a backlight bulb on the LCD (I used to work in a Toshiba repair centre).
Replacing the inverter should be simple, just make sure the unit is powered off with the battery removed so you don't get an electric shock.
Hope this helps,
www.PuterCare.com
Jul 13, 2010 | Toshiba Satellite P35-S609 Notebook
Display flickers and darkens
There are two main possibilities.
1) The cable between the inverter and backlight burn on the screen is loose. You will need to open screen to reseat it.
The other is that the inverter or backlight is dying and your display will stay dark sooner or later.
If you find this helpful please rate so.
Thanks
May 06, 2009 | Computers & Internet
Screen Darkens when powercord is removed
Go to the Control Panel and then select Power Options
Nov 15, 2008 | Compaq Evo N610C Notebook
Question about my battery and screen darkening on my sony vaio laptop
i need to know what do u want to know about the battery and as far as the screen darkening go into bios and go to power options and ensure that it is set to max performance the screen will be bright if it is set to user settings it will be darker
Aug 21, 2008 | Sony Computers & Internet
Lcd darkened windex screen.
hello
try the following:
try first of all to clean the screen using a wet towel because the problem might be that the windex has made a dark layer on the screen ...
if this does not work then if u have a vacum machine that can can get the screen dry by blowing air on it...this might work
if not then you have to send it back to the manufacure
good luck
Apr 21, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 5100 Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
