Question about Reddy R60A Utility Heater
The heater ran out of fuel, when i turned it back on it popped.
The heater will not ignite, it is spraying fuel but wont ignite, if i hit the fuel with a flame the unit will run.
would it be the cirit board?
It would probably be your igniter. it is probably not producing a spark
Posted on Jan 10, 2009
96 toyota camry. Replaced fuel pump, strainer and filter. Will crank if you spray starting fluid in it, but wont run. Any ideas?
Check for spark. Start at the coil, spark at the plug, Could be the coil or crank position sensor. Check codes.
Jun 28, 2016 | 1996 Toyota Camry
Turn on heater, it does not ignite, but the fan kicks in and sprays fuel out the front
It sounds like you either have a bad ingitor or bad ignitor adjustments. I'd suggest calling a service tech.
Dec 03, 2014 | Heating & Cooling
Not sure what type heater you are asking about. If oil furnace, then the igniter rods need to be resharpened and adjusted into proper alignment.
Heater will not start
Does the blower motor start when you plug it in/turn it on? It may take around 5 seconds if your heater has a HSI(hot surface igniter). If it does you need to check the igniter and the fuel flow. Either way, remove the top of the heater. You will be able to see the fan, igniter, and fuel nozzle. Turn the fan by hand to see if it turns freely. If it does, watch out for the fan and turn the heater on. Look for the igniter to start sparking (spark plug type) or glowing (HSI type). Next, use a flashlight to look for fuel spraying from the nozzle. If fuel isn't spraying, try cleaning the fuel nozzle and check the fuel filter. Watch out for the HSI, if you have one, they are very brittle and easily broken. If you still don't have fuel flow after cleaning the nozzle and the fuel filter, you may have an air pressure problem. Let me know and I will tell you how to check it. Don't forget to rate the answer if it works.
Jan 03, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a 60,000 btu kerosene heater its getting fuel and the glow plug turns on but still wont fire up n shuts down. what would cause this?
Well it is getting fuel but is it atomized in very small droplet form? If so is your igniter close enough to ignite the fuel? You see these spray a very fine conical mist under high pressure, if the mist is not defined or conical it sprays past the igniter. If it is fine and cone shaped it could be the positioning of your igniter. Please check both by removing the top section of the heater and watch what is going on in there. My thoughts are a bad nozzle and if you replace it pay attention to spray angle and GPH rating printed on the side of the nozzle.
Dec 22, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Our Troy bilt lawn tractor wont start. It seems like a short
Unless something catastrophic has happen internally, fuel and spark are about all you need. If you are sure of the fuel supply, pull the spark plug lead and let it arc to ground so you can check ignition health. You should have a bright blue spark visible. If you do, then pull the plug and replace it; the insulator may be cracked and robbing some of the high voltage. If it still doesn't start, you may have flooded it and when this happens to me, I make sure no spilled gasoline is present but I then pull the plug and use a charcoal or fireplace lighter and place it in front of the sparkplug hole. It should pop and help exhaust the excess fuel.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Heater turns on for a few seconds then goes out
Absolutely K1 or diesel can get old in a hurry, the ultra-low Sulphur diesel has been tinkered with so much that it turns to book varnish much faster than before 2010. Most of those heaters spray fuel past the igniters using a siphon much like a spray paint gun, the suction tube may have dry rot or a small air leak and it it takes but a tiny air leak to kill the siphon effect. Check the tube from the nozzle all the way down to the fuel tank or replace it if you're not certain it is not compromised or dry rotted.
Oct 12, 2017 | Reddy Heater-30-55,000 BTU Variable
Have a small 35000 btu unit have fuel spray and spark but wont ignite
check to see if the ignitor has not fallen off the back of motor.it's held on by two 2 screws that do vibrate off.if they are on you need to replace the ignition modual.they cost around $80.00 to $100.00
Mar 03, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Reddy R60A Utility Heater Logo
98 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
