Question about Roper RAS6233KQ Top Load Washer
Roper ras7133kq1 leaking
Doesn't leak every wash, just on occasion.
    Top Expert:
  • Roper Master
  • 9,472 Answers
Does it leak on certain load sizes only?
Posted on Nov 30, 2012
vest6
  • 196 Answers
SOURCE: roper ras8445KQO washer
arlenekc : The water pump needs replaced.
malibu66,: Replacing the pump is not difficult at all.
In the above cases, Tilt the machine back so you have access to the bottom. (It there is a soft bottom plate you will have to remove it.) The pump it located on the bottom of the motor and is held on by two clips. Remove the hoses ant then the clips. The pump should slide off the motor shaft. If the pump does not come off then you will have to break it off. DO NOT pry on the motor or shaft. Once the pump is off check the motor shaft for any rust or build-up. This will have to be removed before a new pump is installed.
Line the pump up to the motor shaft to get it in place and put the unit back together then check the operation.
LITTLEGIRL4 Open the lid and find the water flume where the water comes in. This flume gets out of position sometimes. Start filling the machine and watch the flume. If there is water dripping or running down the sides toward the rear then the flume is not in position or has been damaged.
Posted on Jan 12, 2008
onthejob5130
  • 640 Answers
SOURCE: roper wash machine ras7133kq1
no theres something in your pump,,it up against the impeller in your pump.....onthejob
Posted on Jan 31, 2009
TheMobilian
  • 8220 Answers
SOURCE: Roper washing machine leaking water
Might be a cracked water valve or dispenser. To get to it you must remove the skin. Click HERE for info on accessing these fine machines.
Posted on Feb 22, 2009
vickygomar
  • 460 Answers
SOURCE: i am trying to get access to the top front of
this video will help you how to remove your top front washer mishine.
http://www.youtube.com/watch?v=vogysB7XOc8
Thank you
Yourratting is very important for me
Was this helpful?
Posted on May 21, 2009
smartr10U
  • 1305 Answers
SOURCE: my roper wash machine is leaking. is it worth
check when it's leaking during the cycle.
If the fill hose has become unhooked from the outer drum of the machine, it'll just dump water all over the floor... it'll leak out of the case of the machine, but it's an easy fix... you simply open the machine, reinstall the hose into the drum or you may have to replace the hose...washing machines will last a good long time...it's worth the trouble to fix...let me know if you need help opening it up.
This can happen if the machine is overloaded... I had a laundromat and this happened alot because people were cheeeeep and wanted to overstuff the machine thinking they'd get a better deal...not true...dirtier clothes and broken machines....
Posted on Aug 05, 2009
Washer leaks during spin cycles
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Dec 30, 2012 | Roper Washing Machines
Roper #ras8245eq1 leaks during spin cycles
Dec 30, 2012 | Washing Machines
I have a Roper ras7133kq1, top load washer. About 3 months ago I replaced the lid switch because it wouldn't drain or spin. Now it will ONLY spin, it won't fill with water or agitate, the only way...
If it won't fill you will need to replace the "water inlet valve" on the back of the unit. The unit will only agitate if it gets the signal from the water level pressure switch.
Here is the valve to order.
Nov 22, 2012 | Washing Machines
My roper washmachine will not drain after the wash cycle has finished then it will not spin.
It is so common that the drain cloggs and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. The dain pump /valve must be tested and if fault must be replaced.
May 18, 2011 | Roper RAS8445KQ Top Load Washer
Model ras7133kq1 puddle of water on floor after using the fill hoses and drain are fine machine is level where do i start?
so you have checked your fill hoses the next step would be to remove the cabinet and run the machine to test to see where the leak is coming from here is a video on how to replace the drain pump that shows how to remove your cabinet if you have any further questions message me back and please remember when our chat has concluded in full to rank how this opinion has helped Thanks again and heres your video
http://www.youtube.com/watch?v=DwV71h86Gxw
Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
Have a roper ras7133kq1 top loader. It will fill with water and will do nothing else. when i manually set it to spin it makes a squealing nose and the water just drains out.
go to www.repairclinic.com and enter your model number. the first part you see is what is wrong with your washer's spin. replace that and you'll be good. this is found underneath between the motor and the transmission.
Apr 03, 2009 | Roper RAS8445KQ Top Load Washer
Roper wash machine ras7133kq1
Jan 31, 2009 | Roper RAS6233KQ Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
