Mx 15 ditch witch won't start
  • Computers & ... Master
  • 5,660 Answers
That's the flow chart I use working on Tanks. (M60 chassis, not Abrams M1A2)
Make sure the filter for fuel is clean, and there is no water. Make sure pickup tube/device to fuel pump is not restricted, and there are no cracks in tubing, etc, that can cause cavitation. (Air instead of fuel is being drawn in) In other words make sure the fuel pump is getting fuel.
Fuel pump line removed from fuel injector pump, run the pump, fill a clean jar. Measure amount based on time. How long to fill, how much.
(Look at your watch second hand. It is so much fuel per minute. Amount is what we're looking for here. Fuel Injector takes care of the pressure. You just want to see if the fuel pump is drawing fuel, and delivering it to the fuel injector pump )
Fuel pressure from fuel pump, could be bleeding down. Valves in fuel pump are no good. If fuel pump is not re-buildable, fuel pump is no good.
After fuel pump line is re-attached back to the injector pump, it is attached loosely. A half turn loose, or so. This is so you can bleed the air out. Allow the fuel pump to run for a few seconds, or a minute, and bleed the air out here. OR, you will be cracking each injector line loose, and bleeding air out. (No fun)
You can 'crack' an injector line loose, and check it's pressure. It is HIGH pressure now, so be forewarned. Use safety measures, and at least use a pair of safety glasses, and have a fire extinguisher CLOSE.
Shouldn't be any fires if no flames, or sparks are not present, but ALWAYS be prepared for the worse.
(Cigarette dropped in Diesel won't set it on fire. Spark near the fumes WILL)
I have seen a pickup sump line break, and drop the pickup sump for the fuel pump, down in the fuel tank. No fuel can be drawn by the fuel pump. Your fuel pump may be submerged in the fuel tank. Just offering hands on experience.
I have seen a lot of 'weird' things concerning military vehicles, and diesel engines. lol!
There is also a fuel pump (Diesel) pressure gauge you may be able to rent. Meter the fuel pressure from the fuel pump.
Fuel pump checks out the problem is the fuel injector pump, just as you have surmised.
Many have rebuild kits. They are no fun to rebuild. However cost of rebuild kit, is probably not much more than cost of rebuilt injector pump.
The military has equipment like the ditch witch. Civilian contractors use a Ditch Witch also. I do not work on them. Close as I get is a 1K Forklift. (Then 4k Forklifts, 10K, and 20K, plus all the wheeled vehicles, and track vehicles, Up To the Abrams, but Not Abrams)
Don't know if I have done any good. You seem to have your 'eye on the ball'.
Regards,
joecoolvette
[When you get everything back together, bleed the air out. Crack the fuel pump to fuel injector pump line, first. Air bled out here, then crack each injector line, ONE AT A TIME, and bleed the air out.
We 'cheat' sometimes. We have a fuel cap with an air valve mounted in it. Car tire air valve. Air is pressurized in fuel tank, of around 20 lbs, (Usually a 'guess-timate'), and forces air through the fuel system, and out. Takes a while, but I usually don't have to crack any lines to bleed air out.
Regards,
joecoolvette
Posted on Nov 30, 2012
  • Brian Richards Dec 02, 2012
    Thank you very much for your in depth reply.
  • joecoolvette
    joecoolvette Dec 02, 2012
    Thank you for the rating!
wingfighter
  • 6 Answers
SOURCE: my desktop computer display black ,but CPU light
you posted several problems and some are resulted in your trying to diagnose the problem. IF the monitor is black yet you can see the cpu lights meaning it is reading but does not power up all the hardware. In my years of experience in solving hundreds of computer. This is primarily cause by memory or video card. Just re-install or re-insert the memory or video card. This will likely solve the problem. IF just in case the problem still exist replace the memory (RAM) or the video card to check which of which has the defect.
In regards to your computer performing disk scan, this is part of windows utility to fix the hard drive. This is usually cause by pressing the reset button. This appears because when your computer does not power up you reset it. This is normal and nothing to worry about.
Have a nice day in cyberworld
Posted on Aug 28, 2009
nonontech
  • 4737 Answers
SOURCE: loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Posted on Jun 03, 2010
shibuda
  • 1812 Answers
SOURCE: i have intel chipset mohterbord. i press start
Please remove the CMOS battery.Hold the power switch and fit the cmos battery . And go to set up BIOS,and set the bios fail save default.
Follow link.http://www.pcbuyerbeware.co.uk/BIOS.htm
If the problem is same Change the DDR1 RAM from ram slot from any running pc or new if you have a spare.
OPEN the BIOS chip using any thin pin and fit again tightly.
Follow link http://dexplor.com/phpBB2/viewtopic.php?t=7747553
You can change the SMPS or use it in another pc for test ,again the problem is same please change the MOTHER BOARD.
REGARD's
SHIBUDA
Posted on Jan 05, 2011
shibuda
  • 1812 Answers
SOURCE: I have 3 Sata drives
Switch off the mother board .
Please remove the cmos battery and press power switch.for 40 seconds.
Install again and set bios for your requirement.
If same as before . change all the cable
Hope this helps
Posted on Jan 24, 2011
Testimonial: "Thnx for yr advice which I tried, finally turned out to be a heat issue with the Sata drives. New mobo on order."
xedman
  • 122 Answers
SOURCE: my dell vastro 1510 laptop
-this issue will happen if you are having overheating problem in the computer, there are 3 possible problem Processor, video card or the chip set for the motherboard it self, try cleaning your air vent or filters, may be the fan inside is not working any more..
cheers
Posted on Feb 23, 2011
1992 Dodge Stealth SOHC - no problems, running great, then I replaced the distributor (forgot to mark it) & now the car won't start up. It'll turn over, even got it to start once but won't...
put number 1 cylinder at top dead center and drop in distributor so the rotor points to number 1 on cap. may have to try several times as gear moves when lowering dist.
Sep 07, 2013 | Cars & Trucks
Hello, I have a bobcat mini excavator. Mitsubishi motor.. if I was to guess the year its maybe a 2001 or up.. it has a little over 1400 hours on it. Oil & filter was changed at 928 hours... While it...
It could be locked with oil in the cylinder. Remove the injector and turn the engine by hand to expel the oil. Top up the engine oil and refit the injector. If the engine won't turn with the injector/s out then it is seized and needs rebuilding.
Mar 11, 2017 | Cars & Trucks
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
Going70 MPH cut off & won't crank
@ items of concern spark or fuel. For spark as you crank the engine ,assuming that you have a tach on the dash.Does the tach show movement(this will be very small) if it does you have a fuel problem if it doesnt then you will need a crank position sensor
Jan 22, 2012 | 2005 Kia Sedona
1999 chevy k2500. changed spark plugs 4 times in 7 months. Runs good for a week then doesn't start. Changed spider, throttle body sensor. Still has no codes and once again won't start.
The next time it won't start ,pull a sparkplug wire and see if you're getting fire.Then we'll known whether its a ignition or fuel problem and go from there.
Jan 11, 2012 | 1999 Chevrolet K2500
1992 mx-3 v6 won't start. will hit sparaticly as if about to start but just won't catch. checked crank pos. sensor. need suggestions on how to proceed.
Check for a blue snapping spark on 2 or 3 plug wires(or all of them). If you get good spark, then ignition is likely not the problem. A weak or sporadic spark could be a bad coil or coil pack, or a bad ignition module (the ignitor).Check the coils with a volt-ohmmeter per the specs for your car. The ignitor can be tested at a parts store.
If spark is good, check fuel filter, fuel pressure, check timing marks on crank pulley and cam marks, Try a little starting fluid in the air intake and see if it runs for a moment. If so, then it's likely a fuel delivery problem. If no change, then it's likely an ignition circuit problem.
Good luck.
Dec 30, 2011 | 1992 Mazda MX-3
Computers & Internet Logo
506 people viewed this question
David Payne
David Payne
