Question about Garden
Scotts tractor mower wont start. new ingintion switch installed
Installed new ignition sitch....battery is fully charged...no lights on dash when key is turned. no fire and motor wont turn over
  • 8,404 Answers
Doubble check your wiring to make sure you did it correctly. Trace out each wire to make sure it is correct. Check that you start on the hot side of the start solinoid. Check your main fuse. You may need to check your switch with a volt/ohm meter to ID the functions.
Posted on Nov 30, 2012
SOURCE: Husqvarna Riding Mower won't turn over
It could be a combination of things... it could be a loose earth lead from your ignitor pack or your timing could be out, check your key way that will be in the centre part of the magneto.. too see if its ok will need to remove the magneto to see the key way if its brocken it will not fire up and sometimes will back frie through carb if its bad enough, also check your gap between the ignitor pack and magneto should be around the .20 too .25mm by feeler guage...
Jay QLD AUS
Posted on Feb 24, 2009
  • 22 Answers
SOURCE: I have a Craftsman lawn tractor mower. When I turn
replace ignition switch key switch is hanging up
Posted on Sep 02, 2009
Testimonial: "Thank you. I will give that a try. It will take a few days because the part will have to be ordered from Sears."
  • 62 Answers
SOURCE: Key start on lawn mower does not work
Check your starter fuse..follow ignition wire to starter..there is a fusable link inline. make sure u have power all throughh line to starter. :)
Posted on Sep 07, 2009
01fordeb
  • 1033 Answers
SOURCE: huskee 18.5 lawn tractor, engin doesn;t wnat to
Take the starter cover off, look at the Plastic/metal gear. Is it in the up position on the flywheel, if so, the starter is not operating as it should. The gear should come back down out of the flywheel area. When the gears stay up like this, it causes the flywheel to be in a bind. The starter has to have the bendix to shift the gear up into the flywheel to turn over the engine. This is a common problem when a mower will start sometimes and hesitate like it don't have enough of battery power to turn it over, but in reality, it's binding and will burn the starter up if you try to start it too much.
Posted on Mar 29, 2010
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
With key my riding lawn mower does not start, not even crank. Nothing happened.
Are you positive that the battery is fully charged? If so check for current reaching the starter motor. If current is there then it appears that the starter motor is no good. If no current reaches motor it is possible the ignition switch is no good.
Aug 27, 2015 | Craftsman Garden
2003 trailblazer has new battery, but will not crank but all dash lights come on
Check the starter, check the cable that goes from the battery to the starter. make sure its tight and not loose. take a hammer and tap on the starter. If the vehicle still doesn't start. Change the starter.
Sep 02, 2014 | 2003 Chevrolet TrailBlazer
Rally ride on lawn mower not starting. briggs and stratton 12 hp engine. battery fully charged but engine not turning when ignition key turned
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
May 03, 2010 | Garden
John Deere 2010 utility tractor, lights come on dash board, but it wont start. Its in neutral, PTO is okay, seat switch okay
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Nov 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Troybuilt/bronco wont start
IF YOU HAVE A NEW BATT IT COULD NEED THE VALVE LASH RE SET
Sep 19, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cant get my lawn tractor to start
IT COULD BE IGNITION SWITCH IS BAD, I REPLACED ONE ON A CRAFTSMAN THAT DID THIS,BUT ALSO COULD BE A SAFETY SWITCH IS NOT CLOSED PREVENTING STARTER FROM OPERATING,---WITH THE IGNITION SET TO ON CROSS THE TERMINALS ON SOLENOID AND SEE IF IT STARTS THE TRACTOR RUNNING, IF IT FAILS TO RUN ITS PROBALY THE IGNITION SWITCH THEN.
Apr 09, 2009 | Briggs & Stratton Garden
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
