Looking for a FK 36 fan kit for model DV 36 fireplace
3 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Fireplace Fan Replacement
Well a blower replacement requires some knowledge of electricals. i have found a manual showing the blower replacement. Its not the same model as yours but i think it will be helpful.
12.153.20.72/tech/manuals/108321-01A.pdf
Posted on Jul 11, 2008
  • 139 Answers
SOURCE: I have an Insta Flame Canadian Fireplace
sounds as though you need to get the thermocouple(copper wire that sits in the pilot flame) replaced, check first to make sure it is tight at the gas valve end, as they can loosen over time due to expansion and contraction.
Posted on Sep 07, 2011
Looking for a picture diagram of a Bm36Hc fireplace
[PDF]deluxe 36 manufactured home fireplaces - Hansen Wholesale
www.hansenwholesale.com/images/fireplaces/.../Intertherm_BM36HCII.pdf
36" Wood Burning Fireplaces. P/N 800,019M REV. B 04/2002. BM36HC. BM36HCD..... Refer to the minimum system height chart. WARNING: DO NOT PACK ...Missing: picture
Intertherm BM36HC Installation Instructions Manual
www.manualslib.com > ... > Indoor Fireplace > BM36HC
View and Download Intertherm BM36HC installation instructions manual online. DELUXE 36. BM36HC Indoor Fireplace pdf manual download.
Dec 20, 2015 | Heating & Cooling
I am needing a new blower for Charmglow propane ventless fireplace #cgn300tq
I can't find an owner's manual anywhere for this fireplace, but you are welcome to see if any of these universal fan kits look similar: Universal Fireplace Fan Kits.
Nov 30, 2012 | Heating & Cooling
Need a blower
My guess is that you will need a GZ550 found HERE.
Alternatively, you could use a universal fan kit like THIS ONE.
The universal fireplace fan kit will be an easier installation and utilizes an electronic speed control.
Nov 25, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Konica Minolta bizhub 200 Printer
I am looking for an installation manual for Model FUBSK blower motor kit. We bought a new home and the Lennox Superior wood burning fireplace Model BC-36 has a switch that should force heat out into the...
The fan should be installed behind the bottom grill, and then it should blow air around the firebox which then exits out the top grill. Now saying that, let me explain the actual problem you will face. Because you have a open faced wood fireplace, you will not get the heat your looking for, the fire needs 400 cubic feet of air per hour and that air is taken from your opening. Also the inner box doesn't heat up enuff to produce alot of heat on the skin so if you have the fan blowing full blast, it will only cycle the air and not allow it time to heat up as it cycles around the box. I suggest turning the fan speed down so its 1/2 way on or lower, this allows the air time to heat while cycling around the box, but in the end you still won't have a good heater as the fireplace itself isn't one, you should look at having it converted to direct vent gas or ripping it out and replacing it with a airtight wood.
Jan 03, 2010 | Superior Lennox Blower Thermal Sensor -...
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
Does this fireplace use a cirulating fan? Model number 794031B
it has a fan as an option safe to use without! fan are located on very back if you look in bottom door, if it is an insert the fan may be located behind a panel behind the logs. if vented through a wall fan is underneath and has a heat sensor and comes on after fp runs for 10 minutes
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
