Royal Quiet Deluxe manual Typewriter operating book
Want the manual book
5 Suggested Answers
JUSTOLDJIM
  • 478 Answers
SOURCE: TA Royal 420 (Electric Typewriter)
I dont know where uou can find one try e-bay
Posted on Jun 14, 2008
JayBlair
  • 328 Answers
SOURCE: Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 07, 2009
Testimonial: "Thanks for the information. We don't have aninstruction book with the typewriter. The grandkids like to play with the buttons."
squipps
  • 204 Answers
SOURCE: I have an old school
If there is tension on the carriage when you push it to the right, the spring is not broke or the cord..then the problem would be in the escapement area..you would need a repairman to do this. if the carriage is loose, no tension then the spring is either broke or the cord is off or broke.
Either way not something easy....
Posted on Dec 19, 2009
JayBlair
  • 328 Answers
SOURCE: Shift lock stuck on my Royal Quiet Deluxe
Probably the lock spring is broken or just sticky. Flip it on it's back and look closely at the shift lock latch. You should be able to easily see the problem. Fix the spring or lube the latch.
Posted on Dec 30, 2009
Bobber on 1937 royal quiet typewriter does not go up and down to catch ink on spool. I can manually move it, seems like the piece is not catching on the undercarriage
make sure the ribbon selector lever is in the black position not white if that is not the trouble you may ned a repair person
Dec 27, 2017 | Royal Office Equipment & Supplies
The peice of my typewriter that is supposed to move the paper tothe left as you type doesnt move?
It's either in the carriage lock position, just check if it's locked in place.
The other reason may be that the return spring has broken. Easy to replace & is repairable sometimes.
Jul 18, 2014 | TYPE B 1957 Royal Quiet DeLuxe Typewriter
Quiet deluxe typewriter
This is called motion adjustment
I assume the "segment" or the type faces go up and down when you shift? otherwise the "platen" where paper goes goes up and down either way there are a bump stop that is adjustable. usually with a flat blade screwdriver and a 5/16" wrench. there will be a bump stop on each side that must be adjusted equally however only one may be loose causing the problem. but first you should check the linkage for bends or binds shift lock should hold it to the maximum against the stops. Let me know
David Hughes been working on TW since 1975
Jun 01, 2017 | Royal 1940s Antique "Quiet Deluxe"...
Shift Key Problem , Royal Quiet Deluxe
There is a carriage shifting screw on both sides of the typewriter. You will recognize this because it is a screw that has a big bump head with felt on it. It is being hit when you hit that shift lever. You will have to loosen the securing nut first before adjusting.
Nov 17, 2013 | Royal Office Equipment & Supplies
Shift lock stuck on royal quiet deluxe
Pull off the plastic cap and you should be able to see where it is stuck.
Nov 16, 2013 | Royal Office Equipment & Supplies
The ivory colored plastic turning knob on the right side (doubt it matters) that turns the barrel so you can insert paper (you can still turn it without, there's a small visible circular piece of steel...
Checked out eBay...
Right here in Sun City California... for PARTS
or REPAIR... (ONE of about 70 machines available)..
VINTAGE ROYAL QUIET DELUXE PORTABLE TYPEWRITER FOR PARTS REPAIR MADE IN...
Being a collector of old car parts (myself) if figure
there were plenty of collectors of Royal typewrters...
Sure enough..!! (hope this inspires).
Carnac the Magnificent
Jan 09, 2018 | Royal Quiet De Luxe Portable Typewrite...
I have an old school "Royal Quiet Deluxe" typewriter; the carriage will not move when the letter keys are pressed or when the space bar is pressed but will move to back space or to slide the carriage back...
Sep 29, 2009 | Royal Office Equipment & Supplies
Margin settings
Sep 05, 2009 | Office Equipment & Supplies
Carriage won't advance with space or letters.
You will have to take this in for service. Bad escapement
Jun 26, 2009 | Royal Office Equipment & Supplies
Jun 12, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
