Question about Maytag Dishwasher
How to remove lower spray arm on a ge potscrubber dishwashergsd1200t03xx
huuum
  • 750 Answers
SOURCE: lower spray arm needs to be cleaned out.How do i take 0ff?
jocRDFAN43,
They do make a dishwasher cleaner that you can buy for about 5.00 and it cleans your dishwasher and also helps get rid of stains too!
This may solve you sprayer problem easier!
try it first with no dishes in the machine
bless you
huuum
please give me a good rating before you sign off
Posted on Sep 12, 2008
clancampbell
SOURCE: Won't Drain
I think you need to clean the filter under the lower sprayer...I had to do that once and worked like a charm afterwords.
Posted on Oct 31, 2008
Thunder55
  • 318 Answers
SOURCE: lower and upper spray arm will not turn
If the spray arm is not binding due to worn out plastic bushings, then it could be a lack of water pressure, because it is water pressure which makes the arm turn.
Give it a gentle tap in a clockwise direction,,does it spin easily?
If it does,,then it will be lack of water pressure that will be the cause.
Possible pump wear or failure.
Posted on Jan 30, 2009
  • 3 Answers
SOURCE: Cannot remove lower spray arm ge dishwasher GSD5911
Some spray arms out there are reverse threaded, however the one that you are dealing with should be regular threads. Should be an opening at the very bottom of the spray arm where you can stick a screwdriver through and use both hands(one on each end of screwdriver) and carefully loosen it. Make sure you get the new one on as tight as you can by hand, then check to make sure its tight by using the screwdriver again. With the screwdriver through the hole, and one hand on each end of it, just apply pressure clockwise, but you do not have to force it. Hand tight plus an ever so slight turn with the screwdriver should do it. Don't forget that anytime you are replacing the spray arm, you must always check once the new one is in place that you do not have a leak underneath the dishwasher. Also remove all water before you start replacing the spray arm to prevent water from leaking once you break the seal when loosening the spray arm.
Posted on Apr 04, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
What is wrong with my dishwasher and how can I fix it?
Check water temp. Needs to be a minimum of 120 degrees. Check all the spray arm holes for food blockage. Look closely at the holes on the spray arm ends. Those holes act like jet engines to spin the arms.
Apr 02, 2015 | GE Dishwashers
How do I remove lower spray arm
Pull out the lower wash rack. Using a flat-bladed screwdriver, CAREFULLY pry the 2 tabs at the bottom of the washarm so it can move up and over the "hold-down plate" Be careful! Those tabs have a tendency to break off, especially the older the dishwasher is. You may be forced to buy a new wash arm.
Feb 25, 2015 | GE Dishwashers
PDW7800 lower spray arm making clunking sound
1. The spray arm has an aluminum piece on the bottom side of the spray arm. It kinda separates away from the plastic arm and as the spray arm turns, it hits the inner door liner. You can see the scrape marks it makes on the door liner. You can bend the aluminum edge upwards with needle nose pliers or try to make it tight to the plastic spray arm by pushing on he tabs.
2. If you have removed the spray arm make sure the thin silver washer is still inside the hole were the spray arm inserts use a flashlight and look inside that section. If missing, it can also make a noise.
Apr 14, 2014 | GE 24 in. Profile PDW7800 Built-in...
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Top spray arms dont work.
Most likely you have debris blocking the holes in the spray arms. The spray arms can be removed and cleaned out in your sink. (blocked holes in the lower spray arm arm almost impossible to clean out)
Jun 05, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Need to clean out the upper spray arm and so would like to remove it (like I did the lower one) and clean it out. Help!
We have a PDW7800J01WW that I removed all the arms on recently.
There is a single hex-head screw that acts as the pivot at the center of the top most arm. Just remove this screw to remove the spray arm.
Be very gentle reinstalling it though as it is easy to over torque it and strip the plastic hub it screws into.
May 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
The two rotating spayers, the one at the top and the one at the bottom that pops up, are not working. How can I fix this? This is a GE Potscrubber 800 Dishwasher.
First you need to see if you are getting enough water. Let it fill and then look at the center hub where the spray arm is. The water should be at least to the top of that hub. Also you can clean out the sump which is located in the right rear corner of the tub. Usually there is a cover over this which is easily removed with a few screws. Reach in with a gloved hand as there may be glass down there and clean it out. Also look at the spray arms themselves to see if the holes are clogged. You can usually clean these holes with a toothpick or similar object. If the water fill is too low, you may to need to clean or replace the water valve which is located behind the lower access panel usually on the left side.
Apr 17, 2009 | Dishwashers
Maytag Dishwasher Logo
42 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
