Question about Hardware & Accessories
GE 6-ft 6-Outlet 14-Gauge Outdoor Extension Cord with Built-In Circuit Breaker Model #: 58170LO. How do you set the timer on the remote. I want it to come on at dusk and stay on for 6 hours and repeat each day.
  • 16 Answers
SOURCE: resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Posted on Jan 12, 2009
  • 2841 Answers
SOURCE: Hello, I have a Timex Heavy
Alan there is a few problems with what you want to do. First off you should never run an A/C on an extension cord. Secondly the A/C will draw more at startup than after it gets going. You may be fine with this 15 amp timer but make sure that the A/C does not require more than 1875 watts at startup. If you must use an extension cord then buy one that is just long enough to reach and purchase at least a 12 gauge one. 10 gauge would even be better. I would recommend you leave the A/C on all the time and just set the thermostat to a temperature of say 78 degrees. By turning it off entirely it will work very hard at startup to cool not only the air but the furniture walls and everything else in the area it is located in down to a comfortable temperature. I personally would forget the timer and just use the A/C thermostat. Of course if you want the home comfortable when you arrive and do not want it running at all when you are not there then a timer is the answer. I just do not think you will save much money in that manner as the A/C will have to work so hard to cool everything down and will run continuously for hours. You could check it both ways and see which was the most cost effective.
Posted on Sep 07, 2010
SOURCE: lights continue to go off
Maybe the lights are causing photoelectric eye to sense that it's no longer dark.
This is called feedback.
To check this, set timer for 2 hours.
Put black tape over photoeye.
Check if timer turns on-and-off.
If timer continues to blink, then timer is suspect. Return it for another one.
If feedback is causing the problem, then turn timer away from lights or place obstruction between timer and lights.
Posted on Dec 14, 2010
SOURCE: I have a Woods Outdoor
http://waterheatertimer.org/Woods-timers-and-manuals.html#yard-stake
If this is not your timer, add a comment.
A number of folks are writing in about dusk-dawn-timers flashing.
The manufacturer suggests turning photo-eye away from all lighting when installing timer.
Always aim photoeye toward dark region of yard.
I would unplug the timer and let it reset.
Try timer again, turned away from lights so there is no feedback.
Put black tape over photeye and see what happens.
If timer still doesn't work, then timer is defective.
Maybe photoeye circuit was overwhelmed by intense light converted to electrical input.
I test timers, and 4-6% arrive defective, and most last just a season or two, and then you buy another, but the price is affordable.
Local Home Depot sells the GE 15107 outdoor yard stake or wall mount.
I bought one tonight for testing.
It has no photo eye
It has a dial timer where you set exact on-off times by moving plastic segments on dial perimeter.
For example set timer for ON at 5:30 and OFF at 6:00 am depending on your latitude north or south.
geno_3245_189.jpgphoto eye on yard stake timer
Posted on Dec 16, 2010
Testimonial: "Thank you so much for your feedback to my question. I will try your suggestions. If they fail, I will buy the type of timer you recommend! :)"
SOURCE: Outdoor lights timer: Intermatic HB851 photo timer
Intermatic make HB51 timer.
If this is not your timer, then add a comment.
To set for ON at dusk, and off 8 hours later, rotate dial to the number 8.
Timer turns on automatically at dusk.
Timer set to 8 hours will start countdown when timer turns ON > and 8 hours later timer will turn off.
Make sure timer is turned away from lights so photo-eye doesn't receive feedback.
Feedback is when the photo eye gets too much light, and then timer thinks it's dawn, so lights turn off, and a moment later photo eye thinks it's dusk again and lights turn on again.
Feedback from lights will cause timer to reset the 8 hour countdown.
A car pulling in the driveway can cause feedback.
If the timer resets because of feedback, it begins the 8 hour countdown again, so the lights will not turn off until dawn.
You can test timer by putting black tape over photo eye, and then timer will turn on.
Set timer for 2 hours for example and then check if timer turned off 2 hours later.
If timer is not functioning correctly, then timer is defective.
Posted on Dec 19, 2010
GE 6 outlet model 58170LO
Copy following link for GE timers and all brands power-strip timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#powerstrip
For more outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
If you do not have timer, add comment and describe product in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 27, 2012 | Hardware & Accessories
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
Hardwire the orbit outdoor sprinkler timer
Reset the timer? This will sometimes resolve many problems.
Are you sure the conduit has 120Volt? Is the timer connected to single breaker?
Or is circuit 240V? Timer connected to double breaker.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
What do you mean green wire to negative?
What else is on the conduit circuit?
Motors, fluorescent lights, and other electronics can interfere with electronic timers.
Run extension cord to timer from another electrical source and see if problem continues.
Re-post question with model number so timer-electricity expert can read the troubleshoot section of manual.
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/pdf/Rona-91026-water-timer.pdf
Aug 01, 2012 | Orbit Hardware & Accessories
Brand new saw trips 20 amp breaker every time I turn on the saw. It starts to turn and after about a second the breaker trips. Have tried different plugs on a different breaker. Still it will not start....
How long of an extension cord are you using? Is it at least a 14 gauge wire? It should be 12 gauge. If it 16 or a long 14 it will cause the problems that you mention.
If this is occuring when its plugged directly into the outlet then it is likely a problem with the saw. Before you take it back tho try another outlet on a a different circuit.
Jun 30, 2011 | Dewalt DW744XRS 10-inch Job Site Table Saw...
MY BREAKER BUTTON WILL NOT RESET ON 2 TIMERS AT THE SAME TIME?
You posted under Intermatic plug-in outdoor timer.
If I understand correctly, you have two of these timers plugged into outdoor outlet, and the breaker for this outlet will not reset.
Cause can be 3 different problems
1) Load exceeds breaker capacity. Add up total watts and divide by 120V to see if breaker amp size is correct.
2) Loose wire or short in timers, outlet or wires going to Load. For example a broken outlet, or loose wire inside outlet box, or extension cord is under snow or water. Unplug everything, including timers, and try re-setting breaker again. Plug everything back in one at a time to observe when breaker trips.
3) Bad breaker: Move breaker wire to another same-size breaker and see if problem contuinues.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 06, 2011 | Heavy Duty INTERMATIC 6 Outlet Outdoor...
I have a holiday living 6 outlet yard timer and i lost my directions....Model # lx28006
Woods brands sells timers that are packaged and sold under various names and numbers.
For example GE sells same yard stake under their brand.
Woods 6-outlet yard stake manual:
Add a comment and say if this is your timer manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Dec 05, 2010 | Hardware & Accessories
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Jul 10, 2010 | GE Refrigerators
Remington electric tiller circuit breaker goes off
For about $20.00 you can buy 50 feet of 12 guage 3 wire yellow extention cord. You will then get all the amps you need to run your unit. If it still fails, you have a problem inside the tiller.
Tom MN
Jan 30, 2009 | Remington 109312 - 01 Garden Wizard...
Hardware & Accessories Logo
172 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
