Question about Cell Phones
It gets overheating and dont turn on - Cell Phones
  • Cell Phones Master
  • 14,641 Answers
Dear Costomer:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Posted on Nov 30, 2012
What is the name of the liquid to put in the radiator to stop the overheating.
that would be coolant or anti freeze,but it dont over heating it helps keep the cooling system rust free and helps prevent overheating but it dont keep it from overheating,if your overheating there is a problem you need to deal with,check the water level,check the thermostat,are the fans turning on,is there signs of leaking around the water pump?
Apr 25, 2010 | 1991 Lexus LS 400
Son has a 1997 contour with 2.0l overheated
hard to get to and difficult job...are you sure you dont have cracked head? is there water in the oil....does the oil look milky? look in the radiator is there oil residue in the coolant........
Nov 08, 2009 | 1997 Ford Contour
I dont get a picture on my tv when i turn my xbox
This is because the scaler chip on the back of the Xbox 360 motherboard is overheating, it deals with all the display.
You can actually fix it yourself by stopping the heat build up or you can send it in to Microsoft
Nov 05, 2009 | Microsoft Xbox 360 Console
1996 honda civic dx is overheating after long highway drives. Is leaking coolant from top hose as well. Hoping it is that easy of a fix. Thoughts? Thanks for help!
try making sure cooling fans are working by jumping them to the battery and see if they turn on. also could be the thermostat not opening and building up pressure.
Aug 27, 2009 | 1996 Honda Civic
96 acura tl 3.2l is overheating+signals wont work
Start with the easy one (hopefully). You probably have to replace your turn signal flasher. It's located behind the dash, driver side of steering column in the relay block (just pull out to remove).
Your overheating problem: Are you losing coolant, or is the car just running hot? Any leaks, puddles?
Check the cooling fans to make sure they are kicking on as the engine temp rises. If not, you may have a bad switch that is not telling the fan to go on. If fan(s) are operating ok, check the thermostat. If it isn't opening properly, it could be the cause of the overheating. If you have a leak in the system, then when it gets too low, it starts to overheat. Many possibilities, So, let me know the answers to the above so I can help further if needed.
Jul 22, 2009 | 1996 Acura TL Series
Overheating 97 dodge caravan sport
i had the same problem, i dont remember the name of the piece but its mounted right in between the driver side headlight and the radiator. its a relay that turns the fans on when the car gets hot. its mounted on the body of the car. there should be wires leading from the radiator to the piece im talking about.... good luck I also paid about 35 dollars for the piece
Feb 04, 2009 | 1997 Dodge Caravan
Slimline
check the back see if the you have the ps2 8.5v ac adapter if you dont then get one and plug it in and if you do have one then try pluging it in and out
Jan 12, 2008 | Sony PlayStation 2 Slimline Console
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
