Question about Lionel Bronx Zoo Giraffe Car 3376 "yellow Letters"
Lionel 3376 bronx zoo toy train How to get the cam attached to the track to make the giraffe go down
Can't figure out how the cam gets attached to the track?
SOURCE: lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Posted on Dec 25, 2008
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Posted on Dec 27, 2009
TKahill
  • 89 Answers
SOURCE: I have a Lionel War
From the impact of the train when it hit the ground, it has probably damaged the sound system beyond repair. There are multiple problems that could've occurred, such as the wires breaking/loosening, or the sound box could have broken. There isn't a realistic way to fix this, really.
Even though it may not have been your fault, you should try to prevent things like this from happening in the future.
As to the 042 switches, this is likely the same problem. You can order replacement switches online to test them and make sure for relatively cheap, however.
There is hope for you, however. Go to the link below to go to Lionel's customer service page. There, you can find replacement parts and service stations that can replace/repair your train for you, for a small price compared to the value of the train itself. Good luck getting it fixed!
http://www.lionel.com/CustomerService/
Posted on May 03, 2011
  • 13 Answers
SOURCE: is lionel 40 watt transformer from toy train
need a larger out put transformer 90 watt or greater....
Posted on Nov 20, 2011
Where can I get a wiring diagram?
NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS ...
www.faqqq.com/.../need-wiring-diagrams-for-lionel-1055-texas-lionel-doll...
Question Product: Lionel Dolls, Playsets & Toy Figures Question Details: NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS NEED WIRING DIAGRAMS ...
treadmill wiring diagram Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > treadmill wiring diagram
Ask your treadmill wiring diagram doll, playset and toy figure questions. ... need a wiring diagram for a massey ferguson 135 tractor lookin for a complete wirng ...
pactrol p16 wiring diagram Dolls, Playsets & Toy Figures ..
Jan 17, 2016 | Toys
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Lionel train desk lamp not working consistantly.
There are 6 rubber foot pads that under each one is a screw. I had the same problem and we found out that there were screws under the rubber foot pads. Once we were done we glued the rubber foot pads back on the lionel lamp. (Lionel Train Desk Lamp)
Apr 21, 2013 | Toys
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
http://www.lionel.com/ContactUs/
Dec 22, 2012 | Toys
The gate stays down when the power to the train is on
The breaks should be on one of the outside tracks along with a wire to the gate and the ground wire from the transformer is attached to the other outside track. Power wire is attached to the center track and the power terminal on the crossing gate. When the train passes the break the metal wheels connect the ground rail to the rail with the break that is wired to the gate. This completes the circuit and the gate goes down. Once the train passes the other break the connection is lost and the gate goes up.
Dec 04, 2011 | Lionel Auto Crossing Gate
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
3 year old Lionel 4-4-2 (road number 8632) that will not run on antique track. Does anyone have any insight into whether this locomotive needs a digital power source or if it would have an issue running on...
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Jan 02, 2011 | Toys
Need help setting up Lionel North Pole Central Christmas Train 6-30068--how do I attach the transformer to the track? It is on O gauge track and is transformer that came with set. Our manual is lost and...
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Nov 26, 2009 | Northpole Lionel 6-30068 North Pole...
Lionel Bronx Zoo Giraffe Car 3376 "yellow Letters" Logo
55 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
