Question about Sunbeam COFFEEMAKER 10C BLACK DR13
Bad tasting coffee
I'm having problems getting my sunbeam coffee maker to make great tasting coffee. I'm trying to make it so I can drink my coffee practically black instead of having to load it up with cream and sugar to make it palatable. It tastes burnt if I make it the correct strength and it tastes weak/watered down when I try to make it weaker then the recommended strength.
I'm using a reusable metal filter (gold color) because my local area doesn't carry the brown paper filters I love anymore. I'm not sure if its the filter because it was the same issue - just not as bad with the paper filters.
I know its not the coffee being stale because my cupboards are chilly (old style & lack of insulation so its cold) and I always seal the containers well.
My mother has a different coffee machine (the kind with metal coffee pot), she uses brown paper cone filters, the same coffee pretty much as I do, and tap water.
I've tried using filtered water. It doesn't help.
Any ideas on how to make my coffee taste better? I really don't want to have to buy a new coffee maker or resort to the old fashioned method of making coffee if I don't have to.
Please help if you're able. I'm getting really frustrated with bad tasting coffee. :(
  • harvestsun
    harvestsun Jan 12, 2009
    I'll try descaling my machine and see if that helps and I'll post the result.
  • 2,039 Answers
Tell what does it taste like is it to hot burn let me now but i would descale it first not with venagar but with coffee maker descaler start with that and let me now what the taste
Posted on Jan 10, 2009
Machine produces a bad burning smell when making coffee and the coffee also tastes very burnt. The machine is 5 years old
Sorry but if it were mine I think I would discard and buy a new one.Personally LOVE my bunn . not a fancy expresso maker but really good American coffee
Jun 17, 2015 | Sunbeam Cafe EM6910
Coffee tastes bad in old and new coffee makers
Have you tried first just running distilled water through it, then again with spring water and then test with enough coffee for 1 cup to see how the cofee taste then. Also you may want to use distilled or spring water when making that one cup of cofee to test.
Dec 17, 2013 | Mr. Coffee Coffee Makers & Espresso...
Coffee doesnt taste good anymore
To brew correctly the temp in the machine has to be correct, good filter and good water. All these together should give you a great cup of coffee. I would try distilled water first and see if that helps
Jul 24, 2012 | Bunn NHB Coffee Maker
Keurig bad taste
I had that bad Keurig taste/smell for the first few months I owned it and almost returned it, but then someone suggested I run vinegar (1/3) and water (2/3) through it as though it was time to clean it and flush with just water for 3 cycles (see instructions)... and it worked!!!
Feb 08, 2012 | Keurig Coffee Makers & Espresso Machines
We have a sunbeam peace and quiet kettle ke7500s it is approx 3months old. When we reboil the water there's always a tainted water taste in the tea and coffee .The taste is so bad we tip out the hot...
As you know friend, some water when it is boiled it really taste bad so I suggest use a water purifier to filter other out dirt, dust, other particles in a water street supply. Sure when you drink the water (not boiled) it doesn't taste bad, that's normal because we can't distinguish it easily. Also try to clean your kettle using baking soda it will eliminate tainted taste.
I hope my advice help you with your problem.
Mar 23, 2011 | Microwave Ovens
Coffee is only lukewarm and tastes terrible. can the element bemodified to produce more heat
No, but you could replace the element with a new one.
First unplug and make sure the wires have a good clean connection.
You may discover a loose connection and be able to put the unit back in operation.
However if you replace the bad element with a new one.
You might find buying a new coffee maker is not much more than the element. Typically when these little monster go bad. Toss and get another one. Plus the bad taste could be coming from tainted water.
Lukewarm water will grow bacteria over night.
and be safe!
Dec 04, 2009 | Sunbeam DR4/AR4 4 CUP Coffee Maker
My cuisenart 12 cup thermal coffee maker makes bad coffee. I can't return it as it was a fathers day gift. coffee always tastes bitter and burnt. at work we use the same coffee in a 20 dollar sunbeam...
The quality of the water is responsible for the flavor of the coffee. If you have had this coffee maker for a while it is probably coated with lime. Run a couple of cups of vinegar through it followed by a couple of pots of clear water. That will clean up your machine.
Once it is clean, try making a pot with bottled water, or water that you run through a water filtering pitcher.
You will be amazed at the differenct.
Jun 11, 2009 | Wega Mininova EPU Espresso Machine
Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Feb 09, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Tassimo
Have you tried using bottled water? I had the same problem and found that Spring water tasted the best.
Jan 14, 2008 | Braun Tassimo Espresso Machine/Coffee...
Sunbeam COFFEEMAKER 10C BLACK DR13 Logo
605 people viewed this question
Top Sunbeam Coffee Makers & Espresso Machines Experts
ray gallant
Gil Shultz
Are you a Sunbeam Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
