Question about Tappan TMT104E1 Microwave Oven
My Tappan TMV 151FS (2008) microwave is not working.
When we open the door, the power turns on. When we close the door, the power turns off. In the past, it would start working after opening and closing it a few times. Tonight, we couldn't get the power to turn on when the door closed, and couldn't use it. Help!
  • Tappan Master
  • 9,098 Answers
You likely have a door switch or mount. See a handy help file on door switches here.
The service manual for the TMV151 model series is here, and the parts manual is here.
You can order Tappan parts from the Pros here.
Posted on Dec 01, 2012
4 Suggested Answers
  • 72 Answers
SOURCE: Tappan microwave starts when door is opened
you have a bad door switch
Posted on Feb 04, 2010
GodBlessU
  • 3513 Answers
SOURCE: I have a Tappan Model
Hi
The turntable is operated by a motor under the bottom of the cooking cavity. A plastic coupling that slides over the motor shaft, and that's what turns the turntable. In some ovens the coupling is a separate small piece that the glass tray sits on. Other models use a large wheeled plastic ring that rotates the tray.
The usual reason the turntable stops is that the coupling breaks or wears out. The motor shaft is D-shaped, and sometimes the plastic coupling cracks so it doesn't grip properly. Or the plastic wears so that the opening gets rounded and won't grip the shaft. Then even though the motor is running, the coupler doesn't turn. You can usually lift the coupling off the shaft to check it. In some ovens the coupler can only be removed by taking out the turntable motor.
Another probability is that the turntable motor has failed. In most ovens there is an access panel on the bottom that comes off to get at the motor. You can check the motor with an ohmmeter across its terminals to see if it's good. If the motor checks OK ,you can check for power at the motor when the oven is running. This is a little more difficult because it means there will be AC line voltage present, so caution is to the control circuit board.
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 24, 2011
diodeic
  • 1622 Answers
SOURCE: I have a Tappan Microwave
Not a problem, but it sounds like you may have a bad magnetron or bad high voltage diode according to this:
"When the microwave won't heat, but you hear a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. We recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding..
I hope this will help to solve the problem....
Posted on Sep 17, 2011
My tappan microwave won't shutoff
I would first check the door switches and mounts. My door switch help file is here.
If those are good, then you likely have a shorted relay on the control boar, which I can repair for you. Details are here.
FixYa doesn't notify us when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Tappan Microwave Ovens
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
I have a Tappan Model 56-9338-10/04 Microwave. The microwave stays on when you open the door! Can someone help?
  • Don't operate an oven if the door does not close firmly or is bent, warped, or otherwise damaged.
  • Never operate an oven if you have reason to believe it will continue to operate with the door open.
  • As an added safety precaution, don't stand directly against an oven (and don't allow children to do this) for long periods of time while it is operating.
Nov 28, 2009 | Microwave Ovens
Tappan microwave turns on but will not heat at all....still cold after heading for several minutes.
Test your door safety interlock switches. If you are like me, you 'turn it off' by opening the door. This causes arcing at the little contact in these micro switches. Eventually, the contacts inside burn up and cannot make contact. If they cannot make contact, the machine doesn't know if the door is open or closed.
Unplug the machine - do not touch the silver thing inside - potentially lethal! - check with a volt-ohm meter. The switch should read "open" when the door is open and "closed" when the door is closed. If it reads open when the door is closed, the microwave doesn't know the door is closed so it will not turn on the magnatron.
Yes, everything else will work except the magnatron if this $10.00 switch is broken. Buy a replacement at a electronic parts or appliance place. Be ready to give make and model of your machine.
Let me know how this works for you.
A
Sep 13, 2009 | Electrolux Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Tappan microwave keeps running
Usually only the fan will continue to run, as the microwave power supplies has redundant circuits to prevent its operation should the door be open. Usually a fan running when the door is open is due to either a worn out door switch, or a misaligned door switch, which if you fix it for them is an hour of screwing around including ordering the switch, plus $15 for the switch itself. However, there can be other parts like relays which could have failed... and at 25 years old, its really questionable how long the power supply or magnetron is going to keep on running. Alas if you have some skill and don't mind spending $20, maybe you can fix it and then can get another few years of use out of it,
If you call in an appliance guy, the service call alone is likely to approach the cost of a low end under cabinet microwave. Granted, if there are wooden trim pieces and such, a low end microwave may require some custom wooden brackets which can get pretty spendy too.
Oct 19, 2017 | Westinghouse WST3501 Microwave Oven
Filter replacement
That's covered on page 20 & 21 of your owner's manual under the heading"CHARCOAL FILTER REPLACEMENT"
1. Unplug oven or turn off power at the main power
supply.
2. Open the door.
3. Remove the two vent grille mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number from the tag on the oven here.
Feb 16, 2009 | Tappan TMT104E1 Microwave Oven
When door is closed, light and fan comes on
The Problem you Having is dirty Door Switches,Get some Electronic Contack cleaner from the Hardware Store,Make sure it has the little straw to Extend the Spray,Open the Door of the Microwave Look at where the Door Closes youll see Tiny Micro switches,*Note UNPLUG POWER FIRST
Jul 25, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
160 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
Mark Gough
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
