Question about Kitchen Ranges
The broiler on my Whirlpool Gold oven is stuck on. Yesterday it read "Fault Detected" and the oven would not turn on at all. We unplugged and plugged in again. I thought the problem was fixed as th
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
  • 1 more comment
  • Jennifer Rosendahl Nov 30, 2012
    GFE471LVS We now think it is the temperature sensor, part number W10181986. Does that seem reasonable?
  • Richard Roth
    Richard Roth Nov 30, 2012
    I don't think so. I don't believe the broiler works on the probe. But you can test it. Ohm the oven sensor to make sure it ohm's between 1060-1100 ohms. More then 10% tolerance then you need to replace it.
    Jennifer Rosendahl May 20, 2014
    Odd but true, same problem started yesterday. We replaced the temperature sensor in 2012, and it fixed the problem...until now. The broiler unit turns on automatically and stays on when the oven is in use. No error codes are given. I cannot seem to find information regarding this problem. Please help. Thanks!
  • 1073 Answers
SOURCE: oven burnout
replace the oven control
Posted on Apr 25, 2008
  • 4 Answers
SOURCE: Whirlpool GY396 Oven not working at all
Call him back out. Bad panel. It happens!
Posted on Mar 12, 2009
farfield
  • 462 Answers
SOURCE: broiler element broke and was burning as if it was being welded
Probably none. The sparking going on after you turned it off was probably the ground side of the element. Replace the element then re apply power and see if you have any trouble then.
Posted on Apr 06, 2009
  • 126 Answers
SOURCE: Oven wont heat up.
after ignitor glows burners should fire within 30-60 seconds .if not your ignitors are weak (drawing less than 3.5 amps) and should be replaced Hope this helps ,please rate my solution :)
Posted on Jun 26, 2009
mbnataraj
  • 84 Answers
SOURCE: Oven & broiler not heating on our Maytag
May be the heating coil is bust?
The control panel is in parallel usually so as long as the controls are getting power they will turn on. But if the coil is gone you wont get heat. If you want to try fixing it, you may need a multimeter, or a continuity tester.
Posted on Jul 08, 2009
Hi, whirlpool stove gold series model #YXFE710H0BB0 OVEN IS OVER HEATING AND SCREEN SHOWS FAULT DETECTED WHAT IS WRONG?
Possibly oven sensor is bad. Most test at around 1080 ohms at room temperature with a multi meter set to ohms setting
Nov 13, 2017 | Whirlpool Kitchen Ranges
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
Indesit oven keeps heating
Tappan gas range, TGF334BCWB. I can NOT stop the broiler burner from lighting. I have unplugged the 110 power and I light top burner with a striker. However when stove is plugged in to the power the broiler burner lights and continues to burn. The oven knob is turned OFF. The only way to stop the broiler is to unplug the power.
Mar 11, 2014 | Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchen Ranges Logo
288 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
